[Armbian build PR] - rockchip64-6.14: Add missing opp nodes
Description
This PR adds missing Operating Performance Point (OPP) nodes for lower frequencies to the RK3588 device tree. by enabling the CPU clusters to scale down to lower frequencies when under light loads.
The changes add OPP nodes for 408MHz, 600MHz, 816MHz, and 1008MHz (for cluster1 and cluster2 only, as cluster0 already had 1008MHz).
How Has This Been Tested?
  • [x] Tested with RK3588-based board (NanoPC T6-LTS) and verified CPU frequency scaling works correctly
Checklist:
  • [x] My code follows the style guidelines of this project
  • [x] I have performed a self-review of my own code
  • [x] My changes generate no new warnings
View the full article
