saddestboy Posted April 25, 2025 Posted April 25, 2025 I'm new to boards with linux and this is my very first attempt to install linux systems on board so there might be something that I cannot be aware of. I tried to install armbian v6.12 on the SD card but after I finish configureing the setup, the wifi doesn't work. Unfortunately I have no wires to connet to the board so now it is unable for me to connect the board to the internet. The problem is exactly the same as the post Wifi module AX210 - Orange Pi 5 Plus - Armbian Community Forums. I can see the network controller through `lspci -v`: And the dmesg shows that iwlwifi cannot find suitable version to use: And I indeed have the firmware I need under /usr/lib/firmware: (the one ended with 59) Unfortunately I have no wires to connet to the board so now I cannot use apt to update and upgrade the system and the firmware in it and cannot use Armbianmonitor. 0 Quote
Solution saddestboy Posted April 25, 2025 Author Solution Posted April 25, 2025 (edited) Update: get it work by downloading a new verision of firmware-iwlwifi from https://packages.debian.org/sid/all/firmware-iwlwifi/download Seems that I'm a fool Edited April 25, 2025 by saddestboy 0 Quote
AlbertoJ1 Posted May 19, 2025 Posted May 19, 2025 On 4/26/2025 at 3:44 AM, saddestboy said: Update: get it work by downloading a new verision of firmware-iwlwifi from https://packages.debian.org/sid/all/firmware-iwlwifi/download Seems that I'm a fool Tubidy Finally someone has the question I wanted to ask right now.. Thank you for the solution you found. I will try it sir.. 0 Quote
