km1kze Posted September 13, 2017 Posted September 13, 2017 Hello people, I'm using Armbian 5.30 - kernel 3.4.113 on a Nanopi NEO. and I'm relatively new to this stuff, so please bear with me. I successfully managed to install an LCD screen on SPI (ILI9341) using this command: sudo modprobe fbtft_device custom name=fb_ili9341 gpios=reset:1,dc:201,led:6 speed=16000000 rotate=90 bgr=1 So far so good, but the resolution of the screen is too little and can't load anything - for example Dosbox. I would want to replicate the trick that already exists on Raspberry/Raspbian, and that is to framebuffer a higher res screen (at least 640x480) on the tiny LCD's resolution of 320x240. This is the program that is used for Raspberry, for reference: https://github.com/tasanakorn/rpi-fbcp Can someone please tell me if is possible? Thank you
