jdugat Posted September 14, 2017 Share Posted September 14, 2017 I have a wifi dongles that aren't showing up with the usual wlan0/1 identifier, below is what I've discovered so far, but if anyone can shed some light on this, I'd be much appreciative. ifconfig -a I get the following: wlx20e816006af8 Link encap:Ethernet HWaddr 20:e8:16:00:6a:f8 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 if I do iwconfig wlx20e816006af8 essid myhomesid channel 6, I get no errors, however, when I do the iwconfig wlx20e816006af8 commit I get the following error: Error for wireless request "Commit changes" (8B00) : SET failed on device wlx20e816006af8 ; Operation not supported. if I try to to do ifconfig wlx20e816006af8 IP 192.168.1.100, I get unknown host. the only policy rule that I have in the /etc/udev/rules.d directory is as follows: 71-axp-power-button.rules Below are the output from lsusb, lsmod and login info: LSMOD Module Size Used by mt7601u 53248 0 sun8i_codec_analog 24576 0 snd_soc_core 122880 1 sun8i_codec_analog mac80211 335872 1 mt7601u snd_pcm_dmaengine 16384 1 snd_soc_core cfg80211 204800 2 mac80211,mt7601u sun8i_ths 16384 0 snd_pcm 77824 2 snd_pcm_dmaengine,snd_soc_core rfkill 24576 3 cfg80211 thermal_sys 57344 1 sun8i_ths uio_pdrv_genirq 16384 0 uio 16384 1 uio_pdrv_genirq usb_f_acm 16384 1 u_serial 20480 3 usb_f_acm g_serial 16384 0 libcomposite 40960 2 g_serial,usb_f_acm uas 20480 0 LSUSB Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 002: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 002: ID 0781:5571 SanDisk Corp. Cruzer Fit Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Armbian version ___ ____ _ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) |__ /___ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | / // _ \ '__/ _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | / /| __/ | | (_) | \___/|_| \__,_|_| |_|\__, |\___| |_| |_| /____\___|_| \___/ |___/ Welcome to ARMBIAN 5.32 user-built Ubuntu 16.04.3 LTS 4.11.5-sun8i System load: 0.10 0.04 0.01 Up time: 55 min Memory usage: 10 % of 242MB IP: 192.168.1.118 CPU temp: 68°C Usage of /: 9% of 15G [ General system configuration: armbian-config ] Last login: Thu Sep 14 12:42:33 2017 from 192.168.1.135 Link to comment Share on other sites More sharing options...
jdugat Posted September 14, 2017 Author Share Posted September 14, 2017 With ARMBIAN 5.32 user-built Ubuntu 16.04.3 LTS 4.11.5-sun8i, you will need to do the following to change the name of your wifi-dongle adapters: nano /etc/udev/rules.d/70-persistent-net.rules Add the following line (example shows both wlan0 and wlan1) SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<put your wifi dongle MAC address here>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan1" SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<put your wifi dongle MAC address here>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0" if your wifi-dongle MAC address is 78:df:32:3d:0c:af then the line for wlan0 would look exactly like this: SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="78:df:32:3d:0c:af", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0" Save the 70-persistent-net.rules file (for nano type ctrl-o, enter key, ctrl-x) and reboot your board. I hope this helps. Link to comment Share on other sites More sharing options...
