dr.vovanrus Posted May 1, 2025 Posted May 1, 2025 I'm a beginner and I'm really afraid that my work won't be wasted and I won't have to set everything up from scratch again. I installed on the BPI-M5 Armbian_25.2.1_Bananapim5_noble_current_6.12.13_ubuntu-server. But I need the server to simply log in when it reboots and start working without my participation. Please tell me if it would be correct to set up autologin as described below??? Step-by-step manual configuration of autologin, user "pi" Step 1: Verify that the pi user exists If you haven't created a pi user yet, do it.: sudo adduser pi If there is already a user, proceed to the next step. Step 2: Create an override for the getty@tty1 service Do it: sudo systemctl edit getty@tty1.service This command opens the editor (nano or vim by default) and creates an override.conf file. Step 3: Paste the following contents into the opened file: [Service] ExecStart= ExecStart=-/sbin/agetty --autologin pi --noclear %I $TERM 📌 Explanation: ExecStart= — an empty line resets the standard getty launch. The second line is a new startup command with an autologin for pi. Step 4: Save the file and log out In the nano editor: Press Ctrl+O, then Enter to save. Press Ctrl+X to exit. Step 5: Restart systemd services sudo systemctl daemon-reexec sudo systemctl daemon-reload Step 6: Make sure the service is enabled sudo systemctl enable getty@tty1.service Step 7: Reboot the system sudo reboot ✅ Result After restarting, Armbian will automatically log into the console (tty1) under the user pi, without asking for a password. 1 Quote
Solution dr.vovanrus Posted May 24, 2025 Author Solution Posted May 24, 2025 (edited) No one answers...... 🤐 I got tired of waiting and set up autologin according to these instructions. Everything is working.😁 You can use it.💯 Edited May 24, 2025 by dr.vovanrus 0 Quote
