How to configure the default settings of non-stop screen and non automatic screen lock??
Go to solution Solved by IBV,
hi,Kind hearted people
ubuntu22 gome desktop
I tried to execute:
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
it can only solve the problem of not entering sleep mode!!!
But the screen will still go black,
So how to set the default black screen never???
help ,help
In Gnome settings-> power there should be a "Automatic Screen Blank" toggle which you can switch to disabled. I checked this in a quite new Gnome version (48), not sure what version you have.
 I am Wayland Gnome Ubuntu 22
I executed the command you gave me, but it didn't work
sudo gsettings set org.gnome.desktop.session idle-delay 0
(process:36816): dconf-WARNING **: 12:28:47.991: failed to commit changes to dconf: Cannot autolaunch D-Bus without X11 $DISPLAY
Edited by lay
  • Solution
It only works when you are already logged in Gnome, just for your session (no sudo).
If you want global settings, you could try setting this via /etc/profile.d/. Create a script like:
/etc/profile.d/disable-screen-blank.sh
With the contents
#!/bin/bash
if [ "$XDG_SESSION_TYPE" = "wayland" ]; then
fi
and make it executable
sudo chmod +x /etc/profile.d/disable-screen-blank.sh
I tried it and it works for my Gnome 48 test system.
