lay Posted yesterday at 09:59 AM Posted yesterday at 09:59 AM hi,Kind hearted people ubuntu22 gome desktop How to configure the default settings of non-stop screen and non automatic screen lock?? I tried to execute: sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target it can only solve the problem of not entering sleep mode!!! But the screen will still go black, So how to set the default black screen never??? help ,help 0 Quote
IBV Posted 12 hours ago Posted 12 hours ago Hi, On 5/12/2025 at 11:59 AM, lay said: ubuntu22 gome desktop In Gnome settings-> power there should be a "Automatic Screen Blank" toggle which you can switch to disabled. I checked this in a quite new Gnome version (48), not sure what version you have. 0 Quote
lay Posted 9 hours ago Author Posted 9 hours ago Thank you for your support. but, Where is the file configured? I want to pre-set it in advance 0 Quote
IBV Posted 8 hours ago Posted 8 hours ago You can try to change the value via cli: gsettings set org.gnome.desktop.session idle-delay 0 I don't think you will find text config files for gnome, you should use gsettings or dconf editor. Take a look here: https://wiki.archlinux.org/title/GNOME#Configuration 0 Quote
