Yordan Yanakiev Posted yesterday at 07:26 AM Posted yesterday at 07:26 AM Hello. I'm trying to communicate with i2c ( i've connected ADS1115 on it if this maters ), but even without anything connected on it - it shows 0x30 on it, and I am not sure how to make it works. Please help ! 😐 0 Quote
Ryzer Posted 23 hours ago Posted 23 hours ago Hi Yordan, Are you sure you have correctly enabled the i2c overlay on your board? what is the output of cat /boot/armbianEnv.txt? If something is showing up even with nothing apparently connected they your are likely targeting a different bus. It is possible what you are seeing is the address of the internal pmic although this normal shows up as UU. Best of luck Ryzer 0 Quote
Yordan Yanakiev Posted 20 hours ago Author Posted 20 hours ago I've added trough the armbian-config the current, but no joy. Tried a few from ChatGPT - no joy as well. I am not into this, since it's my first ( so far only ESP32 ), and honestly I had no idea that this requires this much stuff just to run a basic feature😐 Any help is greatly accepted. This is the /boot/armbianEnv.txt : verbosity=1 bootlogo=true console=both disp_mode=1920x1080p60 rootdev=UUID=f5d36c6f-cd6a-4f3b-a0a8-b0e85ac089e5 rootfstype=ext4 overlay_prefix=sun50i-h616 overlays=sun50i-h616-i2c0-pi sun50i-h616-i2c1-pi usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 0 Quote
kris777 Posted 19 hours ago Posted 19 hours ago maybe add manually in the file /boot/armbianEnv.txt the entry: overlays=i2c0 i2c1 i2c2 0 Quote
Ryzer Posted 19 hours ago Posted 19 hours ago oh right, then maybe there is a few things you can help me with in future as I still getting to grips with my esp32. Don't worry it look difficult at first but gets easier. Now I believe I know what the problem, on the overlays line modify it to i2c0-pi and i2c1-pi. This appears to be a common problem with armbian-config overlay functional. My own A10 and A20 systems also has this problem as well. 0 Quote
Ryzer Posted 17 hours ago Posted 17 hours ago (edited) My mistake I was suggesting based on prior comments found on the Orange Pi Zero3 thread but after reviewing again it looks like the port part of the overlay is no longer necessary either so as Kris777 suggested just the interface name should hopefully now suffice. According to wiki, the main i2c interface should be i2c3: https://linux-sunxi.org/Xunlong_Orange_Pi_Zero2 Edited 17 hours ago by Ryzer 0 Quote
Yordan Yanakiev Posted 16 hours ago Author Posted 16 hours ago so, how should be looking my armbianEnv file ? 0 Quote
Yordan Yanakiev Posted 16 hours ago Author Posted 16 hours ago Is this the changes ? I got still the same 😐 0 Quote
Solution TRay Posted 5 hours ago Solution Posted 5 hours ago I confirm that armbian-config has problem with add ovelay prefix to overlays= please look on: https://github.com/armbian/configng/issues/592 So i must add manually devices in amrbinaEnv.txt and for OZPI v3 to use I2C i have overlay_prefix=sun50i-h616 overlays=i2c3-ph 0 Quote
Yordan Yanakiev Posted 3 hours ago Author Posted 3 hours ago Good lords. i2c3-ph is actually i2c-1which is i2c-0 since it is on pin 3 and 5. LOL ! This is literally a total mess. 0 Quote
TRay Posted 2 hours ago Posted 2 hours ago 1 hour ago, Yordan Yanakiev said: i2c3-ph is actually i2c-1 Yes in overlays i2c3-ph is on system is i2c-1 on OZPI v2/3 boards on pins 3 and 5 So you can check connected devices on pins 3 and 5 i2cdetect -y 1 0 Quote
