RSS Bot Posted June 5, 2025 Posted June 5, 2025 Description config-prepare: Initialize an empty KERNEL_DRIVERS_SKIP array unless it exists If the array exists in this location, initializing an empty array will destroy all the data that was stored in it. Do not initialize an empty KERNEL_DRIVERS_SKIP array if it exists. This allows us to create an array anywhere in the script, including the user configuration, in a secure way. patch: misc: uwe5622: fix timer api changes for 6.15 (only sunxi) How Has This Been Tested? The sequence of patch application is defined here: lib/functions/compilation/patch/drivers-harness.sh I have created an array in the user configuration file. declare -g -a KERNEL_DRIVERS_SKIP=( # driver_generic_bring_back_ipx # driver_mt7921u_add_pids # driver_rtl8152_rtl8153 # driver_rtl8189ES # driver_rtl8189FS # driver_rtl8192EU # driver_rtl8811_rtl8812_rtl8814_rtl8821 # driver_xradio_xr819 # driver_rtl8811CU_rtl8821C # driver_rtl8188EU_rtl8188ETV # driver_rtl88x2bu # driver_rtw88 # driver_rtl8852bs # driver_rtl88x2cs # driver_rtl8822cs_bt # driver_rtl8723DS # driver_rtl8723DU driver_uwe5622 driver_rtl8723cs ) This allowed the build system to apply only those patches that go up to driver_uwe5622 and therefore allows me to make fixes by applying patches for driver_uwe5622 manually. As ./compile.sh test kernel-patch Here, the test is the name of my custom configuration. [x] Test build kernel for sunxi64 this pull request must be combined before doing this 8270. View the full article
