RSS Bot Posted June 4, 2025 Posted June 4, 2025 Description Fix Type-C DP altmode on some rk3399 boards. Currently only on rockchip64-6.15. The old implementation is tricky, and only works in normal orientation. If the plug is flipped, there will be only USB2.0 connectivity. With the proposed changes, the type-c ports on related rk3399 boards should work in both orientations. A few patches from Megous are picked(some of them already present in sunxi64 kernel patches). The tricky part is how to notify rk3399 cdn-dp driver about DP HPD(hot plug detection), and a workaround is written. A caveat is that the c port has to be OTG mode, otherwise it will behave very similar to the old implementation if DP is enabled. I'm not sure if orange pi 4 / 4 LTS support this, so there's no change to their dts yet. Apart from the work above, the missing fan node is added to tinkerboard 2's dts. list of changes fix type-c dp altmode Megous' glue driver and related improvements are imported this involves enabling the driver in defconfig CONFIG_TYPEC_EXTCON=m a workaround for notifying DP HPD to cdn-dp is written(not merged anywhere) related device tree files/patches are updated accordingly(what about orangepi 4?) add missing fan node in tinkerboard 2's dts along with some minor tweaks How Has This Been Tested? [x] build tinkerboard-2 with edge kernel [x] test on tinkerboard 2s with a hub [x] hub alone works in both orientations [x] hub with display connected works in both orientations [x] when hub is connected, display hot plug/unplug works [x] USB 3.0 type-c drive works in both orientations [ ] test with a DP-only dongle [ ] test on pinebook pro [ ] test on nanopc-t4 [ ] maybe test on orangepi 4 (need dts change) [ ] maybe test on orangepi 4 LTS (need dts change) Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
