[Armbian build PR] - add imb3588 board support
Description
Add support for IMB3588 board. This board based RK3588 SoC, with 4G/8G/16G/32GB LPDDR4 & 16G~128G emmc, 2x 1Gbps Ethernet, 1x HDMI 2.1 output, 1x eDP, 1x mipi display, 1x LVDS, AP6275P wifi 6 & buletooth 5.1 module.
IMB3588 board info: https://www.sunshine-tek.com/productinfo/1989232.html
Documentation summary for feature / change
  1. Only support vendor 6.1 kernel, build with mesa-vpu extensions will get mali GPU worked.
./compile.sh BOARD=imb3588 BRANCH=vendor BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base ENABLE_EXTENSIONS=mesa-vpu EXPERT=yes KERNEL_CONFIGURE=no RELEASE=noble
  1. IMB3588 debug uart, uart2 3.3V ttl ( must remove sp3485 chip to let uart2 RX work )
remove sp3485 debug uart
How Has This Been Tested?
I have built an image for my board, it boots and worked fine except bluetooth. %E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_202
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
