RSS Bot Posted April 26, 2025 Posted April 26, 2025 Description Use same uboot for current and edge builds, so that we can remove redundant lines. Add sata spi image to current, edge uboot builds. It is a bit hacky, but it works. Also add selection for SPI images like https://github.com/armbian/build/pull/8123 GitHub issue reference: Jira reference number [AR-9999] Documentation summary for feature / change Please delete this section if entry to main documentation is not needed. If documentation entry is predicted, please provide key elements for further implementation into main documentation and set label to "Needs Documentation". You are welcome to open a PR to documentation or you can leave following information for technical writer: [ ] short description (copy / paste of PR title) [ ] summary (description relevant for end users) [ ] example of usage (how to see this in function) How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Tested sata spi image boot. [x] Tested sata doesn't boot with normal spi image. Checklist: Please delete options that are not relevant. [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
