RSS Bot Posted June 13, 2025 Posted June 13, 2025 Description Fix Raspberry Pi 5 DSI functionality. Context: A display connected to the DSI connector of Raspberry Pi 5 does not work. Dmesg reveals the following information: [ 13.283052] mipi-dsi 1f00118000.dsi.0: deferred probe pending: mipi-dsi: supplier 2.reg_bridge not ready [ 13.283060] platform 1.panel_disp: deferred probe pending: platform: wait for supplier /axi/pcie@120000/rp1/i2c@88000/reg_display@45 The problem could be traced back to a missing I2C Driver. See: https://forum.armbian.com/topic/50963-dsi-display-does-not-work-on-raspberry-pi-5/ Documentation summary for feature / change Add module to kernel configuration: CONFIG_I2C_DESIGNWARE_CORE How Has This Been Tested? Local build of armbian bookworm minimal and test if DSI display works [OK] kernel linux-bcm2711-current [fail] kernel linux-bcm2711-edge [fail] kernel linux-bcm2711-legacy Both edge and legacy images failed to build, but the failure seems unrelated to the change. Checklist: Please delete options that are not relevant. [not applicable] My code follows the style guidelines of this project [OK] I have performed a self-review of my own code [not applicable] I have commented my code, particularly in hard-to-understand areas [OK] My changes generate no new warnings [not applicable] Any dependent changes have been merged and published in downstream modules View the full article
