phiser678 Posted June 16 Posted June 16 (edited) Hi I have upgraded an existing x86 Armbian system with kernel 6.6.63 and zfs 2.3.2 to the suggested kernel 6.12.32-current-x86, but I cannot get the zfs kernel module loaded after the latest updates to Armbian 25.5.1 noble. I also tried on other kernels, only the old 6.6.63 seems to work. Normally when you select a different kernel in the armbian-config menu, it should automatically compile the zfs modules if it is activated. It just skips it. But you can of course compile it with the provided DKMS system: Quote dkms build -m zfs -v 2.3.2 -k 6.12.32-current-x86 the build just finishes fine, without any error, also the install, but when you try to load the module: Quote modprobe zfs it responds with: Quote modprobe: ERROR: could not insert 'zfs': Exec format error dmesg: Quote [Mon Jun 16 12:40:38 2025] module spl: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time I have zfs 2.3.2 on kernel 6.12.32-current-bcm2711 running just fine on a Raspberry Pi 4, so I tested what would happen if I just build a small kernel driver module: root@armbian:/usr/src/dummydriver# cat dummydriver.c Quote #include <linux/module.h> #include <linux/version.h> #include <linux/kernel.h> static int __init driver_init(void) { printk(KERN_INFO "Goodbye World!"); return 0; } static void __exit driver_exit(void) { printk(KERN_INFO "Hello World!"); } module_init(driver_init); module_exit(driver_exit); MODULE_LICENSE("GPL"); MODULE_AUTHOR("dude"); MODULE_DESCRIPTION("driver"); root@armbian:/usr/src/dummydriver# cat Makefile Quote obj-m = dummydriver.o KVERSION = $(shell uname -r) all: make -C /lib/modules/$(KVERSION)/build M=$(shell pwd) modules clean: make -C /lib/modules/$(KVERSION)/build M=$(shell pwd) clean So when I run this on the Raspberry Pi 4, I can load the module and unload Quote insmod dummydriver.ko rmmod dummydriver But when I run this on the x86 machine I get the same error: Quote root@armbian:/usr/src/dummydriver# insmod dummydriver.ko insmod: ERROR: could not insert module dummydriver.ko: Invalid module format root@armbinan:/usr/src/dummydriver# [Mon Jun 16 12:13:21 2025] module dummydriver: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time root@armbian:/usr/src/dummydriver# modinfo dummydriver.ko Quote filename: /usr/src/dummydriver/dummydriver.ko description: driver author: dude license: GPL srcversion: 4510E7795B8BE551B44A0E5 depends: name: dummydriver retpoline: Y vermagic: 6.12.32-current-x86 SMP preempt mod_unload modversions root@armbian:/usr/src/dummydriver# gcc --version Quote gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0 Copyright (C) 2023 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. I also tried gcc 11.4.0 Here is my armbianmonitor -u: https://paste.armbian.com/orepumazam Any help welcome! Philippe Edited June 16 by phiser678 0 Quote
phiser678 Posted June 17 Author Posted June 17 Hi ok, I got a bit deeper. I installed the Armbian build framework and compiled the kernel. ./compile.sh build BOARD=uefi-x86 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=yes RELEASE=noble ENABLE_EXTENSIONS= Then I got 3 deb files: - Quote rw-rw-r-- 1 ubuntu root 551588032 Jun 17 11:08 linux-image-current-x86_25.08.0-trunk_amd64__6.12.33-Se03c-Dd997-P0000-C999999Hf8af-HK01ba-Vf5f1-Ba566-R448a.deb -rw-rw-r-- 1 ubuntu root 103751872 Jun 17 11:08 linux-headers-current-x86_25.08.0-trunk_amd64__6.12.33-Se03c-Dd997-P0000-C999999Hf8af-HK01ba-Vf5f1-Ba566-R448a.deb -rw-rw-r-- 1 ubuntu root 7649472 Jun 17 11:08 linux-libc-dev-current-x86_25.08.0-trunk_amd64__6.12.33-Se03c-Dd997-P0000-C999999Hf8af-HK01ba-Vf5f1-Ba566-R448a.deb I installed the first 2 (libc-dev was complaining) and then I could compile and load the zfs module (and also the dummydriver)! At first I used KERNEL_CONFIGURE=no with the compile script, and gave me 3 deb files from the ghcr.io/armbian/os/ repository without compiling the kernel, but these don't work! Quote -rw-rw-r-- 1 ubuntu root 95467896 Jun 17 10:35 linux-image-current-x86_25.08.0-trunk_amd64__6.12.33-Se03c-Dd997-P0000-Ce553Hf8af-HK01ba-Vf5f1-Ba566-R448a.deb -rw-rw-r-- 1 ubuntu root 14898368 Jun 17 10:35 linux-headers-current-x86_25.08.0-trunk_amd64__6.12.33-Se03c-Dd997-P0000-Ce553Hf8af-HK01ba-Vf5f1-Ba566-R448a.deb -rw-rw-r-- 1 ubuntu root 1395792 Jun 17 10:35 linux-libc-dev-current-x86_25.08.0-trunk_amd64__6.12.33-Se03c-Dd997-P0000-Ce553Hf8af-HK01ba-Vf5f1-Ba566-R448a.deb Notice also the sizes of the deb files are much smaller. I compared the 2 .config files of the one from the repository and the one that was compiled: Quote diff linux-headers-6.12.33-current-x86-orig/.config linux-headers-6.12.33-current-x86/.config 24c24 < CONFIG_PAHOLE_VERSION=0 --- > CONFIG_PAHOLE_VERSION=125 138a139 > # CONFIG_SCHED_CLASS_EXT is not set 11911a11913,11917 > CONFIG_DEBUG_INFO_BTF=y > CONFIG_PAHOLE_HAS_SPLIT_BTF=y > CONFIG_PAHOLE_HAS_LANG_EXCLUDE=y > CONFIG_DEBUG_INFO_BTF_MODULES=y > # CONFIG_MODULE_ALLOW_BTF_MISMATCH is not set 12134a12141 > CONFIG_PROBE_EVENTS_BTF_ARGS=y 0 Quote
phiser678 Posted June 18 Author Posted June 18 (edited) I think I solved it! In the upgraded system there was no package pahole! After I installed the pahole and reinstalled the package linux-headers-6.12.33-current-x86, I got the BTF stuff as described above in the .config file and I can compile modules! Pfff, finally! I checked the Raspberry Pi 4 version, I see no pahole package installed there, and I can compile modules and zfs. I don't see any BTF stuff in the .config there also. So, I don't know what is really going on here, I should install pahole on arm64 systems as well? And should pahole not be included when you upgrade your system to 25.5.1 ? Edited June 18 by phiser678 0 Quote
rpardini Posted December 4 Posted December 4 Yes. We should add `pahole` as a dependency of the linux-headers package, otherwise during headers install, the `.config` is different from the image build, leading to all kinds of sad. While we might fix the future, unfortunately, installing pahole manually (and removing/re-installing the linux-headers package) is the only way forward for versions already out of the door. 0 Quote
