chymian Posted September 30, 2017 Share Posted September 30, 2017 hello dear armbian developers, building jessie or stretch with btrfs-root ends up in an boot-loop. this is due to an wrong entry in boot.ini setenv rootfstype "ext4" changing it manually to "btrfs" fixed the Problem the config I used: KERNEL_ONLY="no" # leave empty to select each time, set to "yes" or "no" to skip dialog prompt KERNEL_CONFIGURE="no" # leave empty to select each time, set to "yes" or "no" to skip dialog prompt CLEAN_LEVEL="make,debs,oldcache" # comma-separated list of clean targets: "make" = make clean for selected kernel and u-boot, # "debs" = delete packages in "./output/debs" for current branch and family, # "alldebs" = delete all packages in "./output/debs", "images" = delete "./output/images", # "cache" = delete "./output/cache", "sources" = delete "./sources" # "oldcache" = remove old cached rootfs except for the newest 6 files DEST_LANG="de_DE.UTF-8" # sl_SI.UTF-8, en_US.UTF-8 # advanced KERNEL_KEEP_CONFIG="no" # do not overwrite kernel config before compilation EXTERNAL="yes" # build and install extra applications and drivers EXTERNAL_NEW="prebuilt" # compile and install or install prebuilt additional packages CREATE_PATCHES="no" # wait that you make changes to uboot and kernel source and creates patches BUILD_ALL="no" # cycle through available boards and make images or kernel/u-boot packages. # set KERNEL_ONLY to "yes" or "no" to build all packages/all images BSPFREEZE="" # freeze armbian packages (u-boot, kernel, dtb) INSTALL_HEADERS="" # install kernel headers package BUILD_DESKTOP="no" BOARD=odroidxu4 BRANCH=next RELEASE=stretch ROOTFS_TYPE=btrfs FIXED_IMAGE_SIZE=1888 should I open a bug on github for this? thanks a lot guenter Link to comment Share on other sites More sharing options...
