Context: new Banana Pi M4 zero (rev 2) is using Wifi/BT over SDIO, which requires an sdio overlay. Thanks to Armbian team for providing it. Editing armbianEnv.txt to add "overlays=bananapi-m4-sdio-wifi-bt" did the trick for Wifi but BT is still not available (neither in standard or rolling builds)...
@c0rnelius I know you tried to figure out why, I'm missing technical knowledge to help... Digging the Internet I saw similar bluetooth issue for radxa zero 3w with aic8800, resolved using hciattach / hci up, but needing an available /dev/ttyS1 (UART1) we are missing here... Do you know why? Could it be the problem for banana pi m4 zero and if yes could an overlay activate it?
Denis
Here is a more vanilla build of the kernel.
patrick@bananapim4zero:~$ ls /dev/ttyS*
/dev/ttyS0  /dev/ttyS3  /dev/ttyS5  /dev/ttyS7
/dev/ttyS2  /dev/ttyS4  /dev/ttyS6
patrick@bananapim4zero:~$ sudo rfkill
ID TYPE      DEVICE      SOFT      HARD
 0 bluetooth hci0   unblocked unblocked
 1 wlan      phy0   unblocked unblocked
patrick@bananapim4zero:~$ bluetoothctl
hci0 new_settings: powered bondable ssp br/edr le secure-conn
Agent registered
[CHG] Controller AC:6A:A3:3B:D9:D6 Pairable: yes
[bluetoothctl]> exit
patrick@bananapim4zero:~$ uname -a
Linux bananapim4zero 6.12.32 #1 SMP Sat Jun  7 17:23:51 EDT 2025 aarch64 GNU/Linux
patrick@bananapim4zero:~$ dmesg | grep brcm
[    9.007064] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    9.007614] usbcore: registered new interface driver brcmfmac
[    9.303238] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[    9.303576] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
[    9.430799] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.sinovoip,bpi-m4-zero.hcd' Patch
As you can see the Bluetooth works fine.
If I add these two patches it breaks bluetooth on this kernel build.
drv-rtc-sun6i-support-RTCs-without-external-LOSCs.patch
drv-rtc-sun6i-Add-Allwinner-H616-support.patch
I'm still investigating in my spare time, but I'm not 100% on anything. Could be I need to take another approach to the bluetooth node in Armbian? So this is where am at. If anyone has any thoughts I'm all ears.
The issue appears to be two things.
These two patches and the current defconfig(s) being used.
When I disable those patches and use my own defconfig everything works as it should.
https://paste.armbian.com/tixixocubu
The hard part here would be figuring out exactly what in the defconfig(s) are either breaking things or missing. Also if I disable those patches, what does it break on other units? I'm under the impression these patches were rejects from the original h616 bring up in mainline. But I could be wrong?
Hi @c0rnelius, I did some tests with your image, connecting bluetooth audio earbuds, installing XFCE, chromium,...   it works (and also wifi, hdmi/audio, ...)!!
But some problems (side effects of disabling the 2 patches?) :
- hdmi audio (working fine despite the following errors)
"hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported!
"hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22
- i2s  (despite I don't use it, following error in log)
"ahub_plat-i2s-hifi: ASoC: error at __soc_pcm_open on ahub_plat-i2s-hifi: -22"
- WiFi (working fine despite the following errors)
"brcmfmac: brcmf_set_channel: set chanspec 0x100e fail, reason -52"
"brcmf_p2p_send_action_frame: Unknown Frame: category 0xa, action 0x8"
- display lags / windows repaint problems, seems to appear only after using GPU to decode videos, following errors in log)
panfrost 1800000.gpu: gpu sched timeout, js=0, config=0x7300, status=0x8, head=0x10061d80, tail=0x10061d80, sch$
panfrost 1800000.gpu: Panfrost Dump: BO has no sgt, cannot dump
panfrost 1800000.gpu: gpu soft reset timed out, attempting hard reset
panfrost 1800000.gpu: gpu hard reset timed out
panfrost 1800000.gpu: error powering up gpu L2
panfrost 1800000.gpu: error powering up gpu shader
panfrost 1800000.gpu: error powering up gpu tiler
panfrost 1800000.gpu: gpu sched timeout, js=0, config=0x7300, status=0x8, head=0xd0bd0c0, tail=0xd0bd0c0, sched$
panfrost 1800000.gpu: gpu sched timeout, js=0, config=0x7b00, status=0x8, head=0x11195d80, tail=0x11195d80, sch$
This last one is the main problem. Also strange GPU is activated without adding gpu to overlays...
Hope this helps.
Denis
dmesg.txt armbianEnv.txt
