TV Box Name: Sunvell T95Z plus Octagon shaped box (I wrote it before – but Beware – apparently a lot of variants)
CPU Amlogics S912
Armbian build file name: Armbian_community_25.8.0-trunk.277_Aml-s9xx-box_noble_current_6.12.34
DTB file used: meson-gxm-t95z-plus.dtb – (my other T95z uses meson-gxm-vega-s96.dtb)
Kernel Version: 6.12.34
Distribution Installed (focal, buster, etc): Noble
Working Ethernet (Yes/No): Yes
Max Ethernet Speed that works (100/1000): Not sure how to determine...
Does wifi work (Yes/No): No
Does bluetooth work (Yes/No): Not tested
Does HDMI audio work (Yes/No): Yes
Additional Comments (provide any additional information you feel is important):
This is my second T95z plus box build. Using as headless server and both seem solid. Confirming what others have said – the build is different inside. This has a different wifi card and eemc. I have a 3rd T95z plus that has the dreaded NAND chip too. Having fun and learning. Using as a simple NAS now with a ZFS pool and works just fine.
