Hello everyone, today I would like to show you how to compile CoovaChilli and Freeradius for a Wifi Hotspot with captive portal on an Orange Pi PC  (or PC Plus). I'm writing this because I couldn't find anything related to this topic on the internet, so I wrote this not very detailed guide.
wget https://raw.githubusercontent.com/ua3nbw/opihotspot/master/opihotspot_debian.sh
chmod +x opihotspot_debian.sh
./opihotspot_debian.sh
Russian version https://ua3nbw.ru/all/orangepi-coovachilli-and-freeradius-for-a-wifi-hotspot-with-capt/
i got problem is after run script and wait a moment and loop to reboot the system ,can you fix?
"Please reboot and run the script again"
Expand
Upgrading the packages. Please be patient
execute_command "apt-get upgrade -y --force-yes"
here last message
::: Checking if wlan0 interface already exists
::: Wifi interface not found. Upgrading the system first
::: Upgrading the distro. Be patient
Expand
and maybe proccess not completed and phpmadmin, daloradius never seen..
  On 11/11/2017 at 8:35 AM, Valery Rezvyakov said:
show the output of iwconfig
Expand
here sir,
root@orangepipc:~# iwconfig
lo        no wireless extensions.
wlan1     unassociated  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
wlan0     unassociated  Nickname:"<WIFI@REALTEK>"
          Sensitivity:0/0
          Encryption key:off
eth0      no wireless extensions.
root@orangepipc:~#
Expand
any mistake?
"i will try again"
update:
if debug $LAN_INTERFACE value is "wlan0 wlan1"
You first need to figured out what is the chip used in your USB WiFi. To do so, issue the "lsusb" command to figure out which manufacturer it is.
Required condition: a board with onboard or supported 3rd party wireless adapter on USB
If you know what is your wireless SSID:
nmtui-connect SSID
If you don’t know, you can browse and then connect
nmtui-connect
Please describe your setup as best as possible so we know what your operating environment is like.
Name of your board:
Name of the image you installed:
Logs, when you can boot the board: armbianmonitor -u (paste URL to your forum post)
Here my opi spec
Board: Orange PI PC
Image: Armbian_5.30_Orangepipc_Ubuntu_xenial_default_3.4.113_desktop.img
Usb Wifi: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Usb Lan: ID 0fe6:9700 Kontron (Industrial Computer Source / ICS Advent) DM9601 Fast Ethernet Adapter
Is there something wrong?
all usb interfaces that have been tested to connect to the internet
my question
1.during the installation process which interface should be connected to the internet?
2.how to config how to eth0 source (internet) and eth1 captive portal (I prefer to use 2 ethernet)
hey you, it works. ;)
thanks a lot of support.
solution is i use hardcode for variable
WAN_INTERFACE=`ip link show | grep '^[1-9]' | awk -F ':' '{print $2}' | awk '{$1=$1};1' | grep '^e'` # WAN interface (the one with Internet - default 'eth0' or long name for Debian 9+)
LAN_INTERFACE=`ip link show | grep '^[1-9]' | awk -F ':' '{print $2}' | awk '{$1=$1};1' | grep '^w'` # LAN interface (the one for the hotspot)
Expand
::: Congratulation ! You now have your hotspot ready !
::: - Wifi Hotspot available : OPIhotspot
- For the user management, please connect to  http://192.168.1.103/daloradius  or http://OPIhotspot.local/daloradius
  (login : administrator  / password :  radius  )
- For phpmyadmin, please connect to  http://192.168.1.103/phpmyadmin/
  (login : root  / password :  orangepi  )
Time started: 22:39:21
Time started: 22:52:33
Total Runtime (minutes):  13.20
Expand
