Falood Posted July 21, 2025 Posted July 21, 2025 I got a radxa rock 5t and trying to install armbian(https://www.armbian.com/radxa-rock-5t), arimbian NOT boot and I can see the indicator light on the board is showing a steady green light. I boot with the official image https://docs.radxa.com/en/rock5/rock5t/low-level-dev/maskrom/linux and insert the sd card(with armbian img), and run such command, then I can boot armbian from SD card sudo dd if=/dev/mmcblk0 of=working_idbloader.img bs=512 skip=64 count=8000 sudo dd if=/dev/mmcblk0 of=working_u-boot.itb bs=512 skip=16384 count=8000 sudo dd if=working_idbloader.img of=/dev/mmcblk1 bs=512 seek=64 conv=notrunc sudo dd if=working_u-boot.itb of=/dev/mmcblk1 bs=512 seek=16384 conv=notrunc BTW, it seems there's no rock-5t tag, so I selected the 5b one 0 Quote
laibsch Posted July 22, 2025 Posted July 22, 2025 not sure, but sounds like a boot order issue? @meco, I believe you are the maintainer for this board, aren't you? 0 Quote
Falood Posted July 23, 2025 Author Posted July 23, 2025 I also tried sudo dd if=official_rock5t_image.img of=working_idbloader.img bs=512 skip=64 count=8000 sudo dd if=official_rock5t_image.img of=working_u-boot.itb bs=512 skip=16384 count=8000 sudo dd if=working_idbloader.img of=armbian_image.img bs=512 seek=64 conv=notrunc sudo dd if=working_u-boot.itb of=armbian_image.img bs=512 seek=16384 conv=notrunc then burn the img into the SD card, also be able to boot. I got the official image from https://github.com/radxa-build/rock-5t/releases but there's another issue, the hardware acceleration does NOT work in armbian, Mali-G610 is not in use 0 Quote
swthpk32 Posted August 6, 2025 Posted August 6, 2025 Same here, just downloaded this image for the Rock5T https://dl.armbian.com/rock-5t/Noble_vendor_server and put it on a SD card with Etcher, 5T Wont boot, wont do anything. 0 Quote
laibsch Posted August 8, 2025 Posted August 8, 2025 On 8/2/2025 at 9:20 PM, meco said: I'll look into this Just came across this and thought maybe it can help you guys in getting better board support. No idea ;-) 0 Quote
