swthpk32 Posted August 8, 2025 Posted August 8, 2025 (edited) Trying the Armbian Radxa Rock5T 25.5.1 / 6.1.115 Ubuntu server image for the Rock5T and I can't get the Quectel M2 EM12-G WWAN card to be recognized at all. I was previously running the Joshua Reik image and the card showed in lsusb on that image and worked, but I can't figure out why it's not working on this image. I'm kind of new to all this. I did find this similar thread but never found a resolution. https://forum.radxa.com/t/rock-5b-wwan-support-hardware-bug/25780 Hopefully someone can help as to what could be going on. Edit: Armbian Monitor Here: https://paste.armbian.com/avusulewax Edited August 8, 2025 by swthpk32 Update 0 Quote
laibsch Posted August 8, 2025 Posted August 8, 2025 Hello @swthpk32 The Radxa Rock 5T in Armbian is maintained by @meco, maybe he will have something to say. I don't have the board, so I will only be of limited help. Have you tried some of the commands given in the thread you linked and what was the result? Can you confirm that your modem shows up for a second and then disappears? Can you compile your own image with a vendor kernel? nmcli -m 0 sudo dmesg | grep usb 1 Quote
swthpk32 Posted August 8, 2025 Author Posted August 8, 2025 I dont have much experience with this stuff. qmicli: command not found and dmesg doesn't reveal anything that sticks out to me. I dont see it show up even for a second. I did do the armbian monitor and posted a link to that. Compiling my own image/kernel is way over my head. 0 Quote
laibsch Posted August 8, 2025 Posted August 8, 2025 Compiling your own image is actually quite easy. https://docs.armbian.com/Developer-Guide_Building-with-Docker/ https://evilolaf.github.io/docupreview/Developer-Guide_Build-Preparation/ https://www.youtube.com/watch?v=kQcEFsXEJEE The name of your board is "rock-5t" and you will want to try out the vendor kernel, try something like "./compile.sh BOARD=rock-5t BRANCH=vendor RELEASE=noble BUILD_MINIMAL=yes KERNEL_BTF=no SHARE_LOG=yes". You will then share your logs and you can paste a link here if the build fails. "qmicli: command not found" means you do not have the package installed that provides the command. So, you need to find out what package that is and then install it. I suggest you install "sudo apt install command-not-found" first and then this information will come up automatically in the future. # from my computer $ qmicli Command 'qmicli' not found, but can be installed with: sudo apt install libqmi-utils This situation will be a learning experience for you, it is not very likely somebody will come out here and fix your situation for you (unless they have the same problem and want to fix it for themselves and then change something in Armbian for everyone's benefit). People are very willing to help and guide you, but you will essentially need to fix this for yourself and then hopefully share what you did so that others will benefit from your work. That is the power of open source. 0 Quote
meco Posted August 9, 2025 Posted August 9, 2025 There’s some patches from radxa I'll add this weekend. Maybe it’ll work after that 0 Quote
swthpk32 Posted August 9, 2025 Author Posted August 9, 2025 So I had a guy from Fiverr take a look at it and this is what he said he found. I'm not sure if this rings and bells or not? But he is still digging. Regarding the quectel card, it's extremely weird. Both images have the exact same dtbs, overlays and drivers, but it works on both Joshuas and the official image but not on armbian. One thing I have found different between those is the gpio pin states. Armbian image has different gpio states from the other. But idk if that is a side effect or the cause. 0 Quote
