Ducdanh Nguyen Posted 22 hours ago Author Posted 22 hours ago Hello @Nick A i did everything git cloned now im in setup, heres what i choosed: 1. Do not change kernel configuration And after that, i don't found any compactible for my h313 also note that mine firmware is based off d9 Pro 5g so i think it could use the same dram settings and wifi chip except for the cpu. Hope this helps! 0 Quote
Ducdanh Nguyen Posted 19 hours ago Author Posted 19 hours ago I have identified the ram chip and nand, but don't know where wifi is, i think thats not very important since i have alot of usb wifi and ethernet 0 Quote
Ducdanh Nguyen Posted 19 hours ago Author Posted 19 hours ago @Nick A heres the complete info : 🧠 DRAM Chip 1: Marking: MPF694C4G-P Maker: UniIC (UnilC) Type: DDR3/DDR3L Density: 4 Gb (512 MB) Date code: 2021 (week 11) Chip 2: Marking: SBC13H4G150 Maker: UniIC (UnilC) Type: DDR3/DDR3L Density: 4 Gb (512 MB) Date code: 2020 (week 11) ✅ Total RAM = 1 GB (2 × 512 MB) 💾 Storage (eMMC) Chip: Marking (line 1): NCEMAM60-08G Maker: FORESEE Type: eMMC Flash (not raw NAND) Capacity: 8 GB Marking (line 2): 000 Serial/Batch: Z1S1801147073 Date code: 1802 → Year 2018, Week 02 ✅ Total storage = 8 GB eMMC (manufactured early 2018) 0 Quote
Nick A Posted 16 hours ago Posted 16 hours ago @Ducdanh Nguyen you forgot these steps choose "Show CSC/WIP/EOS/TVB" choose "I understand and agree" you should see a few x96q in the list. 0 Quote
Ducdanh Nguyen Posted 4 hours ago Author Posted 4 hours ago hey @Nick A, i think i found the serial port look at the yellow mark on the image 0 Quote
Nick A Posted 3 hours ago Posted 3 hours ago @Ducdanh Nguyen on the other side of the board it has two capacitors. I don’t think that’s it. 0 Quote
Ducdanh Nguyen Posted 3 hours ago Author Posted 3 hours ago by the way i don't see any options with allwinner h313 and 1gb ram, can i just choose the 2gb x96q? 0 Quote
Ducdanh Nguyen Posted 3 hours ago Author Posted 3 hours ago (edited) @Nick A i choosed x96q-lpddr3 (csc) Allwinner H313 TVB with 2gigs of ram and emmc (my box uses emmc) debian 11 image with desktop enviroment Edited 3 hours ago by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted 3 hours ago Author Posted 3 hours ago (edited) @Nick A full log (failed): [💲|🌱] Starting main configuration [💲|🌱] Using REVISION from [ main VERSION file: '25.05.0-trunk' ] [💲|🌿] Enabling extension [ armbian-config ] [💲|🌱] Sourcing family configuration [ /home/nguye/build/config/sources/families/sun50iw9.conf ] [💲|🌿] Enabling extension [ sunxi-tools ] [💲|✅] change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.12' ] [💲|✅] change-tracking: after sourcing family config [ KERNELBRANCH='tag:v6.12.11' ] [💲|✅] change-tracking: after sourcing family config [ LINUXFAMILY='sunxi64' # (was: 'sun50iw9') ] [💲|✅] change-tracking: after sourcing family config [ KERNELPATCHDIR='archive/warpme-6.12' ] [💲|✅] change-tracking: after sourcing family config [ BOOTBRANCH='tag:v2025.01' ] [💲|✅] change-tracking: after sourcing family config [ BOOTPATCHDIR='u-boot-h616' ] [💲|✅] change-tracking: after sourcing family config [ ATFBRANCH='tag:lts-v2.10.14' ] [💲|✅] change-tracking: after sourcing family config [ NETWORKING_STACK='network-manager' ] [💲|🌱] Sourcing arch configuration [ arm64.conf ] [💲|✅] change-tracking: after sourcing arm64 arch [ ATFDIR='arm-trusted-firmware' ] [💲|🌱] Using NETWORKING_STACK [ NETWORKING_STACK: network-manager ] [💲|🌱] Adding networking extensions [ net-network-manager, net-chrony ] [💲|🌿] Enabling extension [ net-network-manager ] [💲|🌿] Enabling extension [ net-chrony ] [💲|🌱] Extension manager [ processed 17 Extension Methods calls and 27 Extension Method implementations ] [💲|🌱] x96q-lpddr3 [ Using allwinner/sun50i-h313-x96-q-lpddr3.dtb for edge ] [💲|💥] Error 1 occurred in SUBSHELL [ SUBSHELL at /home/nguye/build/lib/functions/configuration/config-desktop.sh:48 ] [💲|💥] Cleaning up [ please wait for cleanups to finish ] [💲|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans ] [💲|🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.com/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.de/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.next.armbian.com/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.eu/log ] nguye@DESKTOP-IFEAUMD:~/build$ EDIT: it continued while i tried Debian 12 Next i choosed xfce config_base (onlyone) internet Edited 3 hours ago by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted 1 hour ago Author Posted 1 hour ago (edited) @Nick A success build log : https://paste.armbian.eu/simirepihe Edited 1 hour ago by Ducdanh Nguyen 0 Quote
