Ducdanh Nguyen Posted Friday at 06:26 AM Author Posted Friday at 06:26 AM Hello @Nick A i did everything git cloned now im in setup, heres what i choosed: 1. Do not change kernel configuration And after that, i don't found any compactible for my h313 also note that mine firmware is based off d9 Pro 5g so i think it could use the same dram settings and wifi chip except for the cpu. Hope this helps! 0 Quote
Ducdanh Nguyen Posted Friday at 09:09 AM Author Posted Friday at 09:09 AM I have identified the ram chip and nand, but don't know where wifi is, i think thats not very important since i have alot of usb wifi and ethernet 0 Quote
Ducdanh Nguyen Posted Friday at 09:20 AM Author Posted Friday at 09:20 AM @Nick A heres the complete info : 🧠 DRAM Chip 1: Marking: MPF694C4G-P Maker: UniIC (UnilC) Type: DDR3/DDR3L Density: 4 Gb (512 MB) Date code: 2021 (week 11) Chip 2: Marking: SBC13H4G150 Maker: UniIC (UnilC) Type: DDR3/DDR3L Density: 4 Gb (512 MB) Date code: 2020 (week 11) ✅ Total RAM = 1 GB (2 × 512 MB) 💾 Storage (eMMC) Chip: Marking (line 1): NCEMAM60-08G Maker: FORESEE Type: eMMC Flash (not raw NAND) Capacity: 8 GB Marking (line 2): 000 Serial/Batch: Z1S1801147073 Date code: 1802 → Year 2018, Week 02 ✅ Total storage = 8 GB eMMC (manufactured early 2018) 0 Quote
Nick A Posted Friday at 11:51 AM Posted Friday at 11:51 AM @Ducdanh Nguyen you forgot these steps choose "Show CSC/WIP/EOS/TVB" choose "I understand and agree" you should see a few x96q in the list. 0 Quote
Ducdanh Nguyen Posted Saturday at 12:03 AM Author Posted Saturday at 12:03 AM hey @Nick A, i think i found the serial port look at the yellow mark on the image 0 Quote
Nick A Posted Saturday at 12:49 AM Posted Saturday at 12:49 AM @Ducdanh Nguyen on the other side of the board it has two capacitors. I don’t think that’s it. 0 Quote
Ducdanh Nguyen Posted Saturday at 12:52 AM Author Posted Saturday at 12:52 AM by the way i don't see any options with allwinner h313 and 1gb ram, can i just choose the 2gb x96q? 0 Quote
Ducdanh Nguyen Posted Saturday at 12:54 AM Author Posted Saturday at 12:54 AM (edited) @Nick A i choosed x96q-lpddr3 (csc) Allwinner H313 TVB with 2gigs of ram and emmc (my box uses emmc) debian 11 image with desktop enviroment Edited Saturday at 12:55 AM by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted Saturday at 12:55 AM Author Posted Saturday at 12:55 AM (edited) @Nick A full log (failed): [💲|🌱] Starting main configuration [💲|🌱] Using REVISION from [ main VERSION file: '25.05.0-trunk' ] [💲|🌿] Enabling extension [ armbian-config ] [💲|🌱] Sourcing family configuration [ /home/nguye/build/config/sources/families/sun50iw9.conf ] [💲|🌿] Enabling extension [ sunxi-tools ] [💲|✅] change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.12' ] [💲|✅] change-tracking: after sourcing family config [ KERNELBRANCH='tag:v6.12.11' ] [💲|✅] change-tracking: after sourcing family config [ LINUXFAMILY='sunxi64' # (was: 'sun50iw9') ] [💲|✅] change-tracking: after sourcing family config [ KERNELPATCHDIR='archive/warpme-6.12' ] [💲|✅] change-tracking: after sourcing family config [ BOOTBRANCH='tag:v2025.01' ] [💲|✅] change-tracking: after sourcing family config [ BOOTPATCHDIR='u-boot-h616' ] [💲|✅] change-tracking: after sourcing family config [ ATFBRANCH='tag:lts-v2.10.14' ] [💲|✅] change-tracking: after sourcing family config [ NETWORKING_STACK='network-manager' ] [💲|🌱] Sourcing arch configuration [ arm64.conf ] [💲|✅] change-tracking: after sourcing arm64 arch [ ATFDIR='arm-trusted-firmware' ] [💲|🌱] Using NETWORKING_STACK [ NETWORKING_STACK: network-manager ] [💲|🌱] Adding networking extensions [ net-network-manager, net-chrony ] [💲|🌿] Enabling extension [ net-network-manager ] [💲|🌿] Enabling extension [ net-chrony ] [💲|🌱] Extension manager [ processed 17 Extension Methods calls and 27 Extension Method implementations ] [💲|🌱] x96q-lpddr3 [ Using allwinner/sun50i-h313-x96-q-lpddr3.dtb for edge ] [💲|💥] Error 1 occurred in SUBSHELL [ SUBSHELL at /home/nguye/build/lib/functions/configuration/config-desktop.sh:48 ] [💲|💥] Cleaning up [ please wait for cleanups to finish ] [💲|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans ] [💲|🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.com/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.de/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.next.armbian.com/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.eu/log ] nguye@DESKTOP-IFEAUMD:~/build$ EDIT: it continued while i tried Debian 12 Next i choosed xfce config_base (onlyone) internet Edited Saturday at 01:00 AM by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted Saturday at 03:04 AM Author Posted Saturday at 03:04 AM (edited) @Nick A success build log : https://paste.armbian.eu/simirepihe Edited Saturday at 03:06 AM by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted Saturday at 06:06 AM Author Posted Saturday at 06:06 AM @Nick A i flashed it to my card and it's not booting to armbian... 0 Quote
Ducdanh Nguyen Posted Saturday at 06:49 AM Author Posted Saturday at 06:49 AM Wait @Nick A when a device is rooted, do i need a root manager??? 0 Quote
Nick A Posted Saturday at 12:50 PM Posted Saturday at 12:50 PM (edited) @Ducdanh Nguyen do you know which axp chip you have on your board? It’s a very small chip with axp written on it. I don’t see the H313 markings on your SOC chip. Are you sure you have a H313? If you don’t see an axp chip you might not even have a allwinner SOC. If your android is rooted then it probably has one installed. Edited Saturday at 01:13 PM by Nick A 0 Quote
Ducdanh Nguyen Posted Saturday at 02:30 PM Author Posted Saturday at 02:30 PM (edited) @Nick A su binary installed, but not working correctly, i don't know why, the chip is def h313 because i used cat /proc/cpuinfo(and others) and with grok commands i can confirm it uses cortex-a53 (which includes in h313) and bigfish manufactor/ or codename idk but it's part of allwinner, i mean enought to prove that mine is h313 Edited Saturday at 02:30 PM by Ducdanh Nguyen 0 Quote
Nick A Posted Saturday at 05:09 PM Posted Saturday at 05:09 PM (edited) @Ducdanh Nguyen can you see your axp chip? never heard of bigfish. Is that a heat sink on your SOC? Not sure why it has no writing on it. Install this android app it should give you more information https://play.google.com/store/apps/details?id=com.finalwire.aida64&hl=en_CA&pli=1 Did you apply the secure boot patch? Edited Saturday at 06:18 PM by Nick A 0 Quote
Ducdanh Nguyen Posted yesterday at 12:54 AM Author Posted yesterday at 12:54 AM @Nick A oh yea i used aida64 all the time (and with alot of command line commands), that's where i came up with h313 since it uses cortex-a53, the clock speed and the arch is 64bit armv8 (on 32bit mode) and about the secure boot patch, i think it's too risky (since it is a fake box and diffrent dram settings, etc,....) and i think i will buy a cable and test the su command, if it works, i will dump the boot.img and extract it 0 Quote
Nick A Posted yesterday at 04:56 AM Posted yesterday at 04:56 AM (edited) @Ducdanh Nguyenthe secure boot patch is safe it doesn’t burn any fuses on your SOC. you still haven’t answered the axp chip question. If it doesn’t have one then it’s not a h313. The newer allwinner SOC’s use a axp chip for power management. If I don’t have that information then I don’t know which image to recommend. Edited yesterday at 05:18 AM by Nick A 0 Quote
Ducdanh Nguyen Posted yesterday at 06:15 AM Author Posted yesterday at 06:15 AM @Nick A sorry, i haven't got any information about the axp chip, i will do the reseacrch 0 Quote
Nick A Posted 21 hours ago Posted 21 hours ago (edited) @Ducdanh Nguyen you should be able to see it on the board https://linux-sunxi.org/AXP_PMICs Edited 21 hours ago by Nick A 0 Quote
Ducdanh Nguyen Posted 17 hours ago Author Posted 17 hours ago @Nick Ai don't see any h313 on the page, maybe i will just tear it down again 0 Quote
Nick A Posted 16 hours ago Posted 16 hours ago @Ducdanh Nguyen H313 is basically the same chip as H616. 0 Quote
Nick A Posted 16 hours ago Posted 16 hours ago @Ducdanh Nguyenyour axp chip should look similar to this 0 Quote
Ducdanh Nguyen Posted 8 hours ago Author Posted 8 hours ago Thanks, i will tear it down and see what axp chip mine is using 0 Quote
Ducdanh Nguyen Posted 1 hour ago Author Posted 1 hour ago i didn't found any axp chip in my device, but only a controller, it's very small and that's all i found. Is it ok to dump the boot.img from the android (i have usb to usb cable) 0 Quote
