Hello @Nick A i did everything git cloned now im in setup,
heres what i choosed:
1. Do not change kernel configuration
And after that, i don't found any compactible for my h313
also note that mine firmware is based off d9 Pro 5g so i think it could use the same dram settings and wifi chip except for the cpu. Hope this helps!
@Nick A heres the complete info
🧠 DRAM
Chip 1:
Marking: MPF694C4G-P
Maker: UniIC (UnilC)
Type: DDR3/DDR3L
Density: 4 Gb (512 MB)
Date code: 2021 (week 11)
Chip 2:
Marking: SBC13H4G150
Type: DDR3/DDR3L
Date code: 2020 (week 11)
Total RAM = 1 GB (2 × 512 MB)
💾 Storage (eMMC)
Chip:
Marking (line 1): NCEMAM60-08G
Maker: FORESEE
Type: eMMC Flash (not raw NAND)
Capacity: 8 GB
Marking (line 2): 000
Serial/Batch: Z1S1801147073
Date code: 1802 → Year 2018, Week 02
Total storage = 8 GB eMMC (manufactured early 2018)
Posted (edited)
@Nick A
full log (failed):
[💲|🌱] Starting main configuration
[💲|🌱] Using REVISION from [ main VERSION file: '25.05.0-trunk' ]
[💲|🌿] Enabling extension [ armbian-config ]
[💲|🌱] Sourcing family configuration [ /home/nguye/build/config/sources/families/sun50iw9.conf ]
[💲|🌿] Enabling extension [ sunxi-tools ]
[💲|] change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.12' ]
[💲|] change-tracking: after sourcing family config [ KERNELBRANCH='tag:v6.12.11' ]
[💲|] change-tracking: after sourcing family config [ LINUXFAMILY='sunxi64'  # (was: 'sun50iw9') ]
[💲|] change-tracking: after sourcing family config [ KERNELPATCHDIR='archive/warpme-6.12' ]
[💲|] change-tracking: after sourcing family config [ BOOTBRANCH='tag:v2025.01' ]
[💲|] change-tracking: after sourcing family config [ BOOTPATCHDIR='u-boot-h616' ]
[💲|] change-tracking: after sourcing family config [ ATFBRANCH='tag:lts-v2.10.14' ]
[💲|] change-tracking: after sourcing family config [ NETWORKING_STACK='network-manager' ]
[💲|🌱] Sourcing arch configuration [ arm64.conf ]
[💲|] change-tracking: after sourcing arm64 arch [ ATFDIR='arm-trusted-firmware' ]
[💲|🌱] Using NETWORKING_STACK [ NETWORKING_STACK: network-manager ]
[💲|🌱] Adding networking extensions [ net-network-manager, net-chrony ]
[💲|🌿] Enabling extension [ net-network-manager ]
[💲|🌿] Enabling extension [ net-chrony ]
[💲|🌱] Extension manager [ processed 17 Extension Methods calls and 27 Extension Method implementations ]
[💲|🌱] x96q-lpddr3 [ Using allwinner/sun50i-h313-x96-q-lpddr3.dtb for edge ]
[💲|💥] Error  1 occurred in SUBSHELL [ SUBSHELL at /home/nguye/build/lib/functions/configuration/config-desktop.sh:48 ]
[💲|💥] Cleaning up [ please wait for cleanups to finish ]
[💲|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans ]
[💲|🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ]
[💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.com/log ]
[💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.de/log ]
[💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.next.armbian.com/log ]
[💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.eu/log ]
nguye@DESKTOP-IFEAUMD:~/build$
EDIT: it continued while i tried Debian 12
Next i choosed
xfce
config_base (onlyone)
internet
Edited by Ducdanh Nguyen
Posted (edited)
@Ducdanh Nguyen do you know which axp chip you have on your board? It’s a very small chip with axp written on it.
I don’t see the H313 markings on your SOC chip. Are you sure you have a H313? If you don’t see an axp chip you might not even have a allwinner SOC.
If your android is rooted then it probably has one installed.
Edited by Nick A
Posted (edited)
@Nick A su binary installed, but not working correctly, i don't know why, the chip is def h313 because i used cat /proc/cpuinfo(and others) and with grok commands i can confirm it uses cortex-a53 (which includes in h313) and bigfish manufactor/ or codename idk but it's part of  allwinner, i mean enought to prove that mine is h313
@Nick A oh yea i used aida64 all the time (and with alot of command line commands), that's where i came up with h313 since it uses cortex-a53, the clock speed and the arch is 64bit armv8 (on 32bit mode)
and about the secure boot patch, i think it's too risky (since it is a fake box and diffrent dram settings, etc,....) and i think i will buy a cable and test the su command, if it works, i will dump the boot.img and extract it
Posted (edited)
@Ducdanh Nguyenthe secure boot patch is safe it doesn’t burn any fuses on your SOC
you still haven’t answered the axp chip question. If it doesn’t have one then it’s not a h313. The newer allwinner SOC’s use a axp chip for power management. If I don’t have that information then I don’t know which image to recommend.
Edited by Nick A
Posted (edited)
i didn't found any axp chip in my device, but only a controller, it's very small and that's all i found. Is it ok to dump boot img with adb
