bhouseski Posted August 18 Posted August 18 hey all, I have been running three Rock 5B+ for some time now with Proxmox arm port, and last night I did a kernel update to the latest, and now all three SBC are running extremely slow, PVE does not load, and there are a bunch of system errors (see below). I tried going back to an older kernel, but the same errors remain. any thoughts? Aug 18 07:13:00 PMOX2 kernel: rk806 spi2.0: no dvs-setting pinctrl state Aug 18 07:13:00 PMOX2 kernel: cpu cpu0: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: cpu cpu0: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: cpu cpu0: Failed to get leakage Aug 18 07:13:00 PMOX2 kernel: cpu cpu4: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: cpu cpu4: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: cpu cpu4: Failed to get leakage Aug 18 07:13:00 PMOX2 kernel: cpu cpu6: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: cpu cpu6: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: cpu cpu6: Failed to get leakage Aug 18 07:13:00 PMOX2 kernel: arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. Aug 18 07:13:00 PMOX2 kernel: debugfs: File 'Capture' in directory 'dapm' already present! Aug 18 07:13:00 PMOX2 kernel: debugfs: File 'Capture' in directory 'dapm' already present! Aug 18 07:13:00 PMOX2 kernel: rk-multicodecs es8316-sound: ASoC: Property 'rockchip,audio-routing' does not exist or its length> Aug 18 07:13:00 PMOX2 kernel: dw-pcie fe190000.pcie: invalid resource Aug 18 07:13:00 PMOX2 kernel: dw-pcie fe190000.pcie: Failed to initialize host Aug 18 07:13:00 PMOX2 kernel: mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! Aug 18 07:13:00 PMOX2 kernel: rkvdec2_init:1198: No niu aclk reset resource define Aug 18 07:13:00 PMOX2 kernel: mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! Aug 18 07:13:00 PMOX2 kernel: rkvdec2_init:1201: No niu hclk reset resource define Aug 18 07:13:00 PMOX2 kernel: mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! Aug 18 07:13:00 PMOX2 kernel: rkvdec2_init:1198: No niu aclk reset resource define Aug 18 07:13:00 PMOX2 kernel: mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! Aug 18 07:13:00 PMOX2 kernel: rkvdec2_init:1201: No niu hclk reset resource define Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbd0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbd0000.rkvenc-core: Failed to get leakage Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbd0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbd0000.rkvenc-core: failed to set opp config Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init opp info Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init_opp_table Aug 18 07:13:00 PMOX2 kernel: rkvenc_init:2147: failed to add venc devfreq Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbe0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbe0000.rkvenc-core: Failed to get leakage Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbe0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbe0000.rkvenc-core: failed to set opp config Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init opp info Aug 18 07:13:00 PMOX2 kernel: mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init_opp_table Aug 18 07:13:00 PMOX2 kernel: rkvenc_init:2147: failed to add venc devfreq Aug 18 07:13:00 PMOX2 kernel: rockchip-dmc dmc: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: rockchip-dmc dmc: Failed to get leakage Aug 18 07:13:00 PMOX2 kernel: rockchip-dmc dmc: failed to get vop bandwidth to dmc rate Aug 18 07:13:00 PMOX2 kernel: rockchip-dmc dmc: failed to get vop pn to msch rl Aug 18 07:13:00 PMOX2 kernel: mali fb000000.gpu: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: mali fb000000.gpu: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: mali fb000000.gpu: Failed to get leakage Aug 18 07:13:00 PMOX2 kernel: debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! Aug 18 07:13:00 PMOX2 kernel: debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! Aug 18 07:13:00 PMOX2 kernel: RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] Aug 18 07:13:00 PMOX2 kernel: RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] Aug 18 07:13:00 PMOX2 kernel: RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] Aug 18 07:13:00 PMOX2 kernel: RKNPU fdab0000.npu: RKNPU: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: RKNPU fdab0000.npu: Failed to get specification_serial_number Aug 18 07:13:00 PMOX2 kernel: RKNPU fdab0000.npu: Failed to get leakage Aug 18 07:13:00 PMOX2 kernel: debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! Aug 18 07:13:00 PMOX2 kernel: debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! Aug 18 07:13:00 PMOX2 kernel: rk_hdmirx fdee0000.hdmirx-controller: hdmirx_cancel_cpu_limit_freq freq qos nod add Aug 18 07:13:00 PMOX2 systemd-tmpfiles[765]: Setting file flags is only supported on regular files and directories, cannot set > Aug 18 07:13:00 PMOX2 blkmapd[786]: open pipe file /run/rpc_pipefs/nfs/blocklayout failed: No such file or directory Aug 18 07:13:01 PMOX2 pmxcfs[1241]: [quorum] crit: quorum_initialize failed: 2 Aug 18 07:13:01 PMOX2 pmxcfs[1241]: [quorum] crit: can't initialize service Aug 18 07:13:01 PMOX2 pmxcfs[1241]: [confdb] crit: cmap_initialize failed: 2 Aug 18 07:13:01 PMOX2 pmxcfs[1241]: [confdb] crit: can't initialize service Aug 18 07:13:01 PMOX2 pmxcfs[1241]: [dcdb] crit: cpg_initialize failed: 2 Aug 18 07:13:01 PMOX2 pmxcfs[1241]: [dcdb] crit: can't initialize service Aug 18 07:13:01 PMOX2 pmxcfs[1241]: [status] crit: cpg_initialize failed: 2 Aug 18 07:13:01 PMOX2 pmxcfs[1241]: [status] crit: can't initialize service Aug 18 07:13:20 PMOX2 kernel: [GTP-ERR][__do_register_ext_module:79] Module [goodix-fwu] timeout 0 Quote
bhouseski Posted August 18 Author Posted August 18 v25.8.1 for Rock 5B Plus running Armbian Linux 6.1.115-vendor-rk35xx 0 Quote
