local boot to wrong user, works anyway
Go to solution Solved by gene1934,
bananaoi-m5, Armbian 25.8.1 bookworm installed I can login via ssh as first user, gene, and sudo -i just fine. Buuuttttttt, at reboot the local screen ask's for the pw for amandabackup, a user lock down tightly which has never had a pw assigned. as its intended to be pw--less for the amanda backup system.  What miss-configure can cause this?????
Also I ordered 2 more of the keyboard/mouse combo''s which are the same as I'm using with a similar install for klipper running a 3d printer, but the dongle doesn't init when plugged in ack dmesg output, refusing its on discovery assigned address.  So no keyboard/mouse is locally possible. I'll unpack the 2nd identical copy and see if its also broken. Switching back to an ultra- micro sized keyboard with a touchpad mouse works fine. And the second keyboard/mouse works as expected. The pw gizmo ask's for amandabackup's pw, I gave it my first user pw which it accepted logging me in normally. So I typed whoami and it responded gene.  So wth is confusing the login requester?????????
Many Thanks for any assistance. And why do I have  to say solved in order to post when its not solved?? Counter productive to other readers.
  • Solution
That seems to have gone away. ? SNILMERG...  Now using very small but 1920x1080 screen, xfce terminal text is about 7 microns tall, way too small for my ancient eyes, Simplified keyboard. ctrl&shift&+ magnify's text but when big enough to read, bottom of xfce4 terminal is offscreen below bottom of screen, so cannot see command line. Is there a keycode combo that expands text independently from terminal window size?
Thank you.
