Hello, everyone.
I'm using Armbian_25.5.2_Orangepizero3_bookworm_current_6.12.30-homeassistant_minimal on 4GB OpiZero3.
When booting from sd, the bluetooth controller is initialized correctly.
I made a boot from usb-ssd via armbian-config: everything works fine, but the bluetooth controller is not initialized.
/sys/class/bluetooth is empty.
Switch back to sd - it works again.
Boot from ssd - no.
I compared whether it transferred the distribution correctly from sd to ssd - all files are the same.
What could be the problem?
