vr@m Posted October 21, 2017 Share Posted October 21, 2017 Good night, I have the sound problem but with hdmi audio, de default is the 3.5 mm audio jack, then I looked for the asound.conf in /etc, then I found that this file doesn't exist and after that I've created it with the following content: pcm.!default { type hw card 1 device 0 } ctl.!default { type hw card 1 } the problem is that even created this way the sound output still being the 3.5 mm jack and I don't know if I need to change some setting to mpv player to output the sound through hdmi. What else can I do to change the sound from audio jack to hdmi? Link to comment Share on other sites More sharing options...
