Hi everyone,
I recently got an ESP-WROOM-32 Development Board to use as a companion board for my Armbian SBC setup. My goal is to have the ESP32 collect sensor data and send it to the Armbian host over serial or WiFi. It works okay at first, but after a while running a Python script, the ESP32 crashes or stops sending data.
Setup Details:
Armbian running on a Banana Pi (or similar SBC)
ESP-WROOM-32 connected over serial (USB-to-TTL) and also configured via WiFi
Python script (on the Armbian side) reads from the serial port / receives via a simple socket over WiFi
Power supply is stable; using 3.3 V TTL logic on ESP and stable USB power
Now here are my issues:
Script runs fine for some minutes (5–10), then suddenly no data from ESP3. ESP32 sometimes reboots (observed via onboard LED), sometimes appears alive but unresponsive. Logs show no obvious error messages; serial just quiet or times out
I've tried lowering the serial baud rate. Added delays / sleeps in code to reduce data flood. Ensured the USB-power to ESP32 is stable / using good cable. Tried Py serial and different socket listener scripts
Could USB-TTL or serial USB drivers under Armbian be causing issues (overheating, buffer overflows)? Would switching fully to WiFi (TCP/UDP) instead of serial help stability? Any tools or logging tips on Armbian to catch the crash (kernel logs, serial trace, etc.)?
Thanks in advance for any advice.
Jordan
