prash Posted September 17, 2025 Posted September 17, 2025 (edited) Armbianmonitor: https://paste.armbian.com/jadenukexu Hi, I’m new to the forum and just wanted to take a moment to appreciate the incredible work Armbian has done for the community. I have been tinkering around with Radxa rock 5 ITX SBC and Armbian. I flashed UEFI EDK2 for Radxa rock 5 ITX v1.1 from EDK2 porting to RK3588 initiative. While I can install ARM64 version of Ubuntu and Debian, none of them had support for H/W transcoding. So I decided to build an Armbian which used vendor kernel and had `uefi-edk2-3588` extension. Full build report is linked in this Armbian paste ./compile.sh \ BOARD=rock-5-itx \ RELEASE=trixie \ BRANCH=vendor \ BUILD_MINIMAL=yes \ BUILD_DESKTOP=no \ KERNEL_CONFIGURE=no \ NETWORKING_STACK=systemd-networkd \ EXPERT=yes \ CLEAN_LEVEL=extras \ ENABLE_EXTENSIONS=mesa-vpu,uefi-edk2-rk3588 \ KERNEL_BTF=yes \ SHARE_LOG=yes \ CONSOLE_AUTOLOGIN=no \ build I flashed the resulting image to a usb stick and booted system off it. This is when I had encountered problems. armbian-upgrade complained about a readonly system root@rock-5-itx:~# armbian-upgrade Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://security.debian.org trixie-security InRelease Hit:4 http://deb.debian.org/debian trixie-backports InRelease Hit:5 https://github.armbian.com/configng stable InRelease Ign:6 http://mirror.twds.com.tw/armbian-apt trixie InRelease Err:7 http://mirror.twds.com.tw/armbian-apt trixie Release Could not open file /var/lib/apt/lists/partial/apt.armbian.com_dists_trixie_Release - open (30: Read-only file system) [IP: 103.147.22.36 80] Warning: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chown to _apt:root of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chmod 0755 of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: Not using locking for read only lock file /var/lib/apt/lists/lock Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.foxhPQ - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.ZQLLDs - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.k64ifr - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.kWgd4F - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.pSkidL - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.PoF76X - IsAccessibleBySandboxUser (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/deb.debian.org_debian_dists_trixie_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/deb.debian.org_debian_dists_trixie-updates_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/security.debian.org_dists_trixie-security_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/security.debian.org_dists_trixie-security_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/security.debian.org_dists_trixie-security_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/security.debian.org_dists_trixie-security_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/security.debian.org_dists_trixie-security_InRelease failed - 201::URIDone (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/deb.debian.org_debian_dists_trixie-backports_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/github.armbian.com_configng_dists_stable_InRelease - PrepareFiles (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chown to _apt:root of file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chmod 0600 of file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_InRelease failed - Item::QueueURI (30: Read-only file system) Warning: chown to root:root of file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_InRelease failed - 201::URIDone (30: Read-only file system) Warning: chmod 0644 of file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_InRelease failed - 201::URIDone (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/apt.armbian.com_dists_trixie_InRelease - PrepareFiles (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/partial/apt.armbian.com_dists_trixie_Release - PrepareFiles (30: Read-only file system) Error: The repository 'http://apt.armbian.com trixie Release' no longer has a Release file. Notice: Updating from such a repository can't be done securely, and is therefore disabled by default. Notice: See apt-secure(8) manpage for repository creation and user configuration details. Warning: Problem unlinking the file /var/lib/apt/lists/github.armbian.com_configng_dists_stable_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_contrib_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_non-free_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_non-free-firmware_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_contrib_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_non-free-firmware_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_non-free_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_contrib_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_non-free_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-updates_non-free-firmware_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_non-free_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_non-free-firmware_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_non-free_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_contrib_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/deb.debian.org_debian_dists_trixie-backports_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_non-free_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_main_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_non-free-firmware_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_contrib_binary-all_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_non-free-firmware_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_non-free_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Problem unlinking the file /var/lib/apt/lists/security.debian.org_dists_trixie-security_contrib_binary-arm64_Packages - TransItem::TransactionCommit (30: Read-only file system) Warning: Not using locking for read only lock file /var/lib/dpkg/lock-frontend Warning: Not using locking for read only lock file /var/lib/dpkg/lock Error: Archives directory /var/cache/apt/archives/partial is missing. - Acquire (2: No such file or directory) Warning: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chown to _apt:root of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: chmod 0755 of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system) Warning: Not using locking for read only lock file /var/lib/apt/lists/lock Warning: Not using locking for read only lock file /var/lib/dpkg/lock-frontend Warning: Not using locking for read only lock file /var/lib/dpkg/lock Error: Archives directory /var/cache/apt/archives/partial is missing. - Acquire (2: No such file or directory) armbian-install only shows /dev/ but lsblk and blkid can see all drives. I am sorry for the long post. Edited September 17, 2025 by Prashant Sinha 0 Quote
laibsch Posted September 17, 2025 Posted September 17, 2025 show the output of "mount|grep ro" 0 Quote
prash Posted September 17, 2025 Author Posted September 17, 2025 (edited) Following is the output of "mount|grep ro" root@rock-5-itx:~# mount|grep ro proc on /proc type proc (rw,nosuid,nodev,noexec,relatime) /dev/sda2 on / type ext4 (ro,relatime) cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot) systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=37,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=19056) ramfs on /run/credentials/systemd-resolved.service type ramfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,mode=700) ramfs on /run/credentials/systemd-networkd.service type ramfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,mode=700) /dev/sda1 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime) ramfs on /run/credentials/systemd-journald.service type ramfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,mode=700) ramfs on /run/credentials/getty@tty1.service type ramfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,mode=700) ramfs on /run/credentials/serial-getty@ttyFIQ0.service type ramfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,mode=700) Following is the output of "lsblk" root@rock-5-itx:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 1 7.5G 0 disk ├─sda1 8:1 1 256M 0 part /boot/efi ├─sda2 8:2 1 7.2G 0 part / └─sda3 8:3 1 8M 0 part sdb 8:16 0 465.8G 0 disk ├─sdb1 8:17 0 1M 0 part ├─sdb2 8:18 0 512M 0 part ├─sdb3 8:19 0 16G 0 part └─sdb4 8:20 0 449.3G 0 part mtdblock0 31:0 0 16M 0 disk mmcblk0 179:0 0 29.1G 0 disk mmcblk0boot0 179:32 0 4M 1 disk mmcblk0boot1 179:64 0 4M 1 disk zram0 253:0 0 11.6G 0 disk [SWAP] zram1 253:1 0 50M 0 disk zram2 253:2 0 0B 0 disk nvme0n1 259:0 0 1.9T 0 disk ├─nvme0n1p1 259:1 0 1G 0 part └─nvme0n1p2 259:2 0 1.9T 0 part Edited September 17, 2025 by prash 0 Quote
laibsch Posted September 18, 2025 Posted September 18, 2025 13 hours ago, prash said: /dev/sda2 on / type ext4 (ro,relatime) OK, this is the line that is problematic. You need to find out why sda2 is mounted read-only. Go through the logs, for example "sudo grep sda2 /var/log/syslog". If you can, boot from a different medium and fsck sda2. 0 Quote
prash Posted September 18, 2025 Author Posted September 18, 2025 I flashed same image to a SD card and tried to boot from it. Following is the result of `grep mmcblk1p2 /var/log/syslog` 2025-09-17T09:52:44.015489+00:00 rock-5-itx armbian-resize-filesystem[947]: ### [resize2fs] Trying to resize ext4 filesystem on /dev/mmcblk1p2: 2025-09-17T09:52:44.015493+00:00 rock-5-itx armbian-resize-filesystem[947]: Running 'resize2fs /dev/mmcblk1p2' now... 2025-09-17T09:52:44.015508+00:00 rock-5-itx armbian-resize-filesystem[947]: Filesystem at /dev/mmcblk1p2 is mounted on /; on-line resizing required 2025-09-17T09:52:44.021891+00:00 rock-5-itx kernel: EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Quota mode: none. 2025-09-17T09:52:44.021891+00:00 rock-5-itx kernel: EXT4-fs (mmcblk1p2): unmounting filesystem. 2025-09-17T09:52:44.021893+00:00 rock-5-itx kernel: EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Quota mode: none. I will try booting from a different medium and running `fsck mmcblk1p2` too. 0 Quote
