smile Posted October 30, 2017 Posted October 30, 2017 Hi, my environment is: Orange Pi One ARMBIAN 5.34.171031 nightly Ubuntu 16.04.3 LTS 4.11.12-sun8i WiringPi fork by WereCatf: git clone https://github.com/WereCatf/WiringOP.git -b h3 ./build small c++ programm: #include <stdio.h> #include <string.h> #include <errno.h> #include <stdlib.h> #include <wiringPi.h> #include <pthread.h> static volatile int globalCounter; void myInterrupt(void) { ++globalCounter; printf("InterruptCounter: %5d\n", globalCounter); //digitalRead(7); } int main(void) { if (wiringPiSetup() == -1) { printf("wiringPiSetup Error\n"); } pinMode(7, INPUT); pullUpDnControl(7, PUD_UP); if (wiringPiISR(7, INT_EDGE_FALLING, &myInterrupt) < 0) { fprintf(stderr, "Unable to setup ISR: %s\n", strerror(errno)); return 1; } for (;;) { //main programm code here... } return 0; } Compile: gcc ./isr.c -o wg-daemon.out -lwiringPi -lwiringPiDev -lpthread -lm and run it... but when I put pin 7 in down state (gpio mode 7 down) ISR function begin fires (triggers) continuously ((((((( Here is output : InterruptCounter: 132371 InterruptCounter: 132372 InterruptCounter: 132373 InterruptCounter: 132374 InterruptCounter: 132375 InterruptCounter: 132376 InterruptCounter: 132377 InterruptCounter: 132378 InterruptCounter: 132379 InterruptCounter: 132380 InterruptCounter: 132381 ^C root@orangepione:~/example# but, when I add to ISR function "digitalRead(7);" program works fine ((( Please tell me, what I do wrong
smile Posted October 30, 2017 Author Posted October 30, 2017 Anyone() I just test this code with Raspberry Pi 3 and Wiring Pi library, all works perfect() But on orange pi one still this problem(
robbit Posted May 19, 2018 Posted May 19, 2018 I am observing the exact same behavior with the Orange Pi PC: Hi, my environment is: Orange Pi PC BOARD=orangepipc BOARD_NAME="Orange Pi PC" BOARDFAMILY=sun8i VERSION=5.38 LINUXFAMILY=sunxi BRANCH=next ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage WiringPi fork by WereCatf: Do you have any newer information/insights on that matter? Anayway, does calling digitalRead() in the interrupt-routine cause any problems? If not, this work around is acceptable for me. Thanks for the hint. :-)
