Gunwoo Gim Posted October 24, 2025 Posted October 24, 2025 (edited) Version `25.8.2` of kernel, dtb and/or header package on Armbian Ubuntu Noble break `zfs-dkms` (I'm pretty sure kernel module `zfs` was not built with success) I had to run: ```sh sudo apt install linux-image-current-meson64=25.8.1 linux-headers-current-meson64=25.8.1 linux-dtb-current-meson64=25.8.1 && sudo dpkg-reconfigure zfs-dkms ``` I couldn't look in to the problem, because I was busy doing something else when I was just upgrading every package on the system. I had to prioritize quickly fixing it before another user arrives so I just reverted the suspicious packages (the three I mentioned in the title) I can't look into the problem now either because the computer is not being used by me alone.. Edited October 24, 2025 by Gunwoo Gim 0 Quote
The Tall Man Posted October 24, 2025 Posted October 24, 2025 I don't know if this relates, but I recently discovered an issue with a Debian Trixie file system package xfsprogs on the 25.8.1 edge kernel for the Orange PI 5 Plus: https://forum.armbian.com/topic/55599-bug-report-armbian-edge-kernel-6164-xfsprogs-trixie-package-failure-to-start-low-memory-monitorservice/ 0 Quote
Gunwoo Gim Posted October 27, 2025 Author Posted October 27, 2025 Quote I don't know if this relates, but I recently discovered an issue with a Debian Trixie file system package xfsprogs on the 25.8.1 edge kernel for the Orange PI 5 Plus: https://forum.armbian.com/topic/55599-bug-report-armbian-edge-kernel-6164-xfsprogs-trixie-package-failure-to-start-low-memory-monitorservice/ I don't think that's a relevant issue. I couldn't `modprobe zfs` in my case. 0 Quote
The Tall Man Posted October 27, 2025 Posted October 27, 2025 9 hours ago, Gunwoo Gim said: I couldn't `modprobe zfs` in my case. Modproble probes modules built into the kernel itself. An external package (other than the kernel itself) shouldn't affect it. If it was present via modprobe before, and not after, that isn't the zfs package, that would indicate a module that had been built into 25.8.1 kernel, then excluded from the 25.8.2 kernel build for some reason. 0 Quote
Gunwoo Gim Posted October 28, 2025 Author Posted October 28, 2025 (edited) 21 hours ago, The Tall Man said: Modproble probes modules built into the kernel itself. An external package (other than the kernel itself) shouldn't affect it. If it was present via modprobe before, and not after, that isn't the zfs package, that would indicate a module that had been built into 25.8.1 kernel, then excluded from the 25.8.2 kernel build for some reason. Some modules are not included in the kernel package by default. In my case I had to install zfs-dkms built upon Dynamic Kernel Module Support(DKMS). The module gets rebuilt whenever I upgrade the kernel—I'm not sure exactly which package I have to upgrade first though, header? dtb? Somehow the zfs module was not successfully built after I upgraded the kernel, its header files, and the device tree blobs. Edited October 28, 2025 by Gunwoo Gim 0 Quote
The Tall Man Posted October 28, 2025 Posted October 28, 2025 Oh, okay. I'm not familiar with DKMS. But if you're updating multiple packages at once, doesn't apt sort out which need to be done first and second, etc? But if you're somehow rebuilding the kernel upon package installation, I'd install the headers package first - as those would be required for source-code level access. As for the devicetree blobs package, that just provides copies of those (already build) .dtb files to your /boot directory. But they're actually already included in the kernel package itself. The kernel package installs them to: /usr/lib/linux-image-_______/ So on my Orange PI 5 Plus, the dtb directory from the latest kernel package is here: /usr/lib/linux-image-6.18.0-rc3-edge-rockchip64/ Keeping the convention Armbian uses, instead of installing the redundant dtb package, I manually create two links to it in my /boot directory whenever I update the kernel (I have to do this for Debian-sourced kernels anyway): cd /boot ln -s /usr/lib/linux-image-6.18.0-rc3-edge-rockchip64 dtb-6.18.0-rc3-edge-rockchip64 ln -s /usr/lib/linux-image-6.18.0-rc3-edge-rockchip64 dtb Just replace that kernel with whichever one you're using. And if you're booting via uboot, be sure the Armbian.txt remains up to date. 0 Quote
The Tall Man Posted October 28, 2025 Posted October 28, 2025 I have seen kernel updates for my system since you began this thread. You could check for a latest update, and see if the issue self-corrects. Do you know when the latest zfs-dkms package was updated? Perhaps it's just getting too out of sync with the kernels. If all else fails, you can build the kernel yourself: https://docs.armbian.com/Developer-Guide_Build-Preparation/ ...and in the kernel config, be sure that zfs modules are included. From the kernel config screen, you can do a search for zfs, and see what comes up. If there are zfs modules available there, this would be a different approach that would probably replace the use of the zfs-dkms package. 0 Quote
CryBaby Posted October 28, 2025 Posted October 28, 2025 What version of the kernel is being installed? As yet ZFS only supports up to 6.16. 0 Quote
Gunwoo Gim Posted October 29, 2025 Author Posted October 29, 2025 (edited) On 10/29/2025 at 1:47 AM, CryBaby said: What version of the kernel is being installed? As yet ZFS only supports up to 6.16. The new kernel version was `6.12.55` and the previous one was `6.12.44` Edited October 30, 2025 by Gunwoo Gim 0 Quote
Gunwoo Gim Posted October 29, 2025 Author Posted October 29, 2025 19 hours ago, The Tall Man said: Do you know when the latest zfs-dkms package was updated? Perhaps it's just getting too out of sync with the kernels. Quote $ apt show zfs-dkms Package: zfs-dkms Version: 2.3.4-1arter97~ubuntu24.04.1 Priority: optional Section: contrib/kernel Source: zfs-linux Maintainer: Debian ZFS on Linux maintainers <pkg-zfsonlinux-devel@alioth-lists.debian.net> Installed-Size: 18.7 MB Provides: zfs-modules Depends: dkms (>> 2.1.1.2-5), file, libc6-dev | libc-dev, lsb-release, python3-setuptools | python3-distutils | libpython3-stdlib, debconf (>= 0.5) | debconf-2.0 Recommends: zfs-zed, zfsutils-linux (>= 2.3.4-1arter97~ubuntu24.04.1), linux-libc-dev (<< 6.17~), linux-libc-dev (>= 4.18~) Suggests: debhelper Breaks: spl-dkms (<< 0.8.0~rc1) Replaces: spl-dkms Homepage: https://zfsonlinux.org/ Download-Size: 2,514 kB APT-Manual-Installed: yes APT-Sources: http://apt.armbian.com noble/noble-utils arm64 Packages Description: OpenZFS filesystem kernel modules for Linux OpenZFS is a storage platform that encompasses the functionality of traditional filesystems and volume managers. It supports data checksums, compression, encryption, snapshots, and more. . This DKMS package includes the SPA, DMU, ZVOL, and ZPL components of OpenZFS. N: There are 11 additional records. Please use the '-a' switch to see them. 19 hours ago, The Tall Man said: If all else fails, you can build the kernel yourself: I don't want to take that measure.. 0 Quote
Gunwoo Gim Posted March 25 Author Posted March 25 The same issue has occurred again. On 10/24/2025 at 1:28 PM, Gunwoo Gim said: I had to run: ```sh sudo apt install linux-image-current-meson64=25.8.1 linux-headers-current-meson64=25.8.1 linux-dtb-current-meson64=25.8.1 && sudo dpkg-reconfigure zfs-dkms ``` I had to take this measure again today to fix the zfs module. I had to revert the kernel, headers and dtb back to 25.11.2 from 26.2.1 of linux(meson64:arm64) 0 Quote
