Peter Quiring Posted November 12, 2025 Posted November 12, 2025 After performing a warm reboot the system fails to start. Get error message boot device not found. Power cycling fixes the issue. Using Armbian 25.8.1 image that is available for download (minimal trixie). Board is a LibreCompter Sweet Potato. Thanks, 0 Quote
eselarm Posted November 12, 2025 Posted November 12, 2025 Make sure you can see and follow kernel messaging when initiating reboot. So another computer that taps serial serial console while you have loglevel=7 for the Potato. 0 Quote
bunducafe Posted November 20, 2025 Posted November 20, 2025 I have a very similar if not the same issue on my Odroid M1. When doing a reboot it won't detect the SATA hdd. The NVME is working fine and I am booting the device via a sdcard anyway. Aparantly it has something to do with the kernel. Once I shut down the odroid and power it on again (cold reboot) the SATA device is just working fine again. I did not find a solution for this so far but I keep on digging... 0 Quote
pquiring Posted March 7 Posted March 7 The reboot issue seems to be fixed with latest Armbian 26.2.1 Thanks! 0 Quote
pquiring Posted March 9 Posted March 9 Ok, after doing more tests the issue was the boot switch on the board. It must be switched to boot from SD/eMMC and not SPI (BIOS). Then reboot works fine. 0 Quote
