0jay Posted November 27, 2025 Posted November 27, 2025 (edited) I'm having trouble with the raspberry omv builds. The latest build I can get working is 24.11.1 which doesn't survive an upgrades (I've tried holding the various packages that seem to cause issues which used to work but doesn't work anymore. The suggested trouble shooting on the download page doesn't work either. Currently the 25.11.1 build is stuck in a bootloop, the only irregularity I can identify is failure to load console-setup.service message. I had a working system that lost my soundcard/DAC-hat after trying to address update error messages which's what started this whole refresh process Edited November 27, 2025 by 0jay 0 Quote
geoW Posted November 27, 2025 Posted November 27, 2025 vor einer Stunde schrieb 0jay: Currently the 25.11.1 build is stuck in a bootloop, the only irregularity I can identify is failure to load console-setup.service message. I confirm, here it is failing setting up openssh service, it starts rebooting after root autologin prompt, tested on rpi5. 1 Quote
0jay Posted November 27, 2025 Author Posted November 27, 2025 13 minutes ago, geoW said: I confirm Thanks geoW, I look to be having some success with the 25.2.3 build I just have to see if it survives the ugrades 0 Quote
0jay Posted November 27, 2025 Author Posted November 27, 2025 25.2.3 build fine after upgrade though I had to hold rpi-eeprom, raspi-firmware and raspberrypi-sys-mods Also still getting the Method gave a blank filename apt error 1 Quote
