tutralex Posted 1 hour ago Posted 1 hour ago Armbianmonitor: https://paste.armbian.com/siboxacixo After upgrading to Armbian 26.2, I noticed that if I mounted a network drive (samba, cifs) and even accessed it, and then tried to unmount it (sudo umount -t cifs ...), the system would freeze. Upgrading from Debian 12 (bookworm) to Debian 13 (trixie) didn't help. I did a rollback to Armbian 25.x via backup, and this problem doesn't exist there. 0 Quote
tutralex Posted 54 minutes ago Author Posted 54 minutes ago (edited) I tried various parameters when mounting and unmounting, such as: sudo umount -f /media/..., but the system still hangs. You can't connect to the device via SSH in a new session. If you force a reboot (or sudo systemctl poweroff ) without unmounting it, it won't happen, and you won't be able to connect via SSH. Physically disconnecting the cable also doesn't help. Edited 25 minutes ago by tutralex 0 Quote
