Orangepi0 Posted November 17, 2017 Share Posted November 17, 2017 (edited) Hello everyone, I'm having some trouble with i2c between orangepi zero and ina219. Here is i2cdetect -y 0 respons: " 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: 40 -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- --" I'm using https://github.com/chrisb2/pi_ina219 and also installed https://github.com/adafruit/Adafruit_Python_GPIO and both of them installed without any problem, but when I run: "from ina219 import INA219, DeviceRangeError from time import sleep SHUNT_OHMS = 0.1 MAX_EXPECTED_AMPS = 2.0 ina = INA219(SHUNT_OHMS, MAX_EXPECTED_AMPS, address=0x40) ina.configure(ina.RANGE_16V) def read_ina219(): try: print('Bus Voltage: {0:0.2f}V'.format(ina.voltage())) print('Bus Current: {0:0.2f}mA'.format(ina.current())) print('Power: {0:0.2f}mW'.format(ina.power())) print('Shunt Voltage: {0:0.2f}mV\n'.format(ina.shunt_voltage())) except DeviceRangeError as e: # Current out of device range with specified shunt resister print(e) while 1: read_ina219() sleep(1)" I get: "Traceback (most recent call last): File "zero.py", line 7, in <module> ina.configure(ina.RANGE_16V) File "/root/pi_ina219/ina219.py", line 164, in configure self._max_expected_amps) File "/root/pi_ina219/ina219.py", line 282, in _calibrate self._calibration_register(calibration) File "/root/pi_ina219/ina219.py", line 328, in _calibration_register self.__write_register(self.__REG_CALIBRATION, register_value) File "/root/pi_ina219/ina219.py", line 360, in __write_register self._i2c.writeList(register, register_bytes) File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/I2C.py", line 128, in writeList File "build/bdist.linux-armv7l/egg/Adafruit_PureIO/smbus.py", line 274, in write_i2c_block_data IOError: [Errno 70] Communication error on send" So does anyone know what to do to fix this error. Thanks Edited November 17, 2017 by Orangepi0 Link to comment Share on other sites More sharing options...
