RSS Bot Posted November 12, 2025 Posted November 12, 2025 Armbian Weekly Highlights: Enhanced Compatibility and Toolinghttp://blog.armbian.com/content/images/2025/11/githubhighlights-2.pngThis week in Armbian development saw a range of significant updates and improvements across the project, focusing heavily on expanding hardware support and refining the build framework.Major HighlightsThe Armbian ecosystem saw significant expansion into the emerging micro-compute camera space, notably adding support for new Rockchip RV110x variants, alongside major U-Boot version bumps and the introduction of a dedicated low-memory build architecture.New Low-Memory Build Extension: Introduced the LowMem extension to optimize builds specifically for boards with less than 256MB of RAM.LowMem extension (for boards with < 256MB RAM) (#8839)RV1106: Limit udev children to prevent early OOM (#8915)LowMem: Slim down initramfs and set /run size (#8904)Expanded Rockchip RV110x/RV3506 Support: Added initial support for the new Rockchip visual processing chip family and several specific boards built around them.family: rockchip: add rv1103/rv1106 + first board 'LuckFox Pico Mini' (#8797)rockchip: Add CSC board Luckfox Lyra Plus + adjust RK3506 BOOT_SOC (#8841)rockchip: Add CSC board Luckfox Lyra Ultra W (RK3506B) (#8862)rockchip: Add CSC board Luckfox Pico Pro / Pico Max (RV1106) (#8893)Kernel Update: Bumped the mainline edge kernel version to 6.18-rc5.bump mainline edge to rc5 (#8908)New FeaturesNew hardware support and key functional additions have been merged across the project.New Board SupportAdd support for Hardkernel ODROID M1S (#8846)add new board radxa-e54c (#8849)rockchip: add 9tripod x3568 v4 support (#8823)Radxa Zero 3W: Add ext antenna overlay (#8894)rockchip64: add rk3318-box overlay for T98_RK3318 boards (#8848)BTRFS IntegrationBTRFS: move btrfs support packages from additional to main package list (#8888)odroidm1: u-boot: bump to 2025.10; enable BTRFS support (#8857)odroidhc4: u-boot: bump to v2025.10; enable BTRFS support (#8880)nanopct6(-lts): u-boot: enable BTRFS support (#8856)Networking & Modulesadd Debian Forky as CSC target (#8814)Enable AX25 Kernel Modules (#8882)Enable ath12k module for edge kernel configs (#8812)Security & Storageadd CRYPTROOT_AUTOUNLOCK option and fix CRYPTROOT for uefi builds (#8805)Bug FixesSeveral user-facing and deep-level build fixes were introduced, improving stability and usability.Armbian install progress bar wasn't working for awhile (#8900)fix(armbian-firstlogin): Enable wlan dhcp by default (#8809)IMX8: fix ATF build error (again) (#8843)Revitalize Espressobin - fix atf compilation bug, bump kernels (#8873)config: kernel: linux-sunxi-*: Set CONFIG_PWRSEQ_EMMC=y (Fixes eMMC power sequencing) (#8877)meson64/edge(6.18): .config: recover EXT4 manually (#8868)meson64-6.18: temporary patch for pcie vs aspm woes on Amlogic (#8867)station-p2: fix pcie (#8819)extensions/image-output-utm: fix serial console ttyAMA0 for arm64 (#8851)ImprovementsFramework and board maintenance focused on optimization, reliability, and modernizing U-Boot adoption.Build System & FrameworkKernel config rewrite: use our strong servers for matrix generation (Significantly faster config processing) (#8859)Implement option to skip certain kernel configs that don't want to play along (#8896)Improve first login for automated builds (#8899)framework mmdebstrap, fetch_distro_keyring - use cached keyring pkgs from armbian.github.io (#8881)U-Boot & FirmwareMultiple boards bumped to U-Boot v2025.10 final, enhancing stability and feature sets.qemu-uboot-{x86|arm64}: bump u-boot to v2025.10 final (#8801)cm3588-nas: bump u-boot to v2025.10 final (#8799)RPI: Increase UEFISIZE from 256 MiB to 512 MiB (#8842)uboot: uboot-config now prints diff with pre-menuconfig defconfig (#8855)nanopi-m6: add support for mainline uboot (#8793)khadas-edge2: add support for mainline uboot (#8796)Board Maintenanceyouyeetoo-r1: Add custom ALSA state configuration (#8818)rockchip: x3568 v4: sync changes from mainline and fixes phy leds (#8887)Community ContributionsThank you to all contributors who submitted pull requests this cycle!@igorpecovnik, @vidplace7, @glneo, @EvilOlaf, @HeyMeco, @rpardini, @pyavitz, @tabrisnet, @rbqvq, @F4FXL, @Jookia, @jonaswood01, @kamilsaigol, @paolosabatino, @Jojo-A, @schmiedelm, @chainsx, @SuperKali, @timsurber, @mahdibx, @sylv-io, @belegdol, @sashasimkin, @efectn.Want to dive deeper into the code or contribute? Check out our GitHub repositories!View the full article
