RSS Bot Posted November 5, 2025 Posted November 5, 2025 http://blog.armbian.com/content/images/2025/11/D1_v3_face_antenna-2.pngBuilding a serious automation system shouldn’t mean spending days wiring SBCs, shields, USB dongles, level shifters and external power protection. JetHub D1+ offers a clean alternative: a compact, integrated, production-ready controller built for smart buildings, industrial automation, energy management, BMS, dispatching, and reliable IoT deployments.This device is developed and manufactured by JetHome and comes ready for the field: no breadboards, no compatibility guessing, no driver hunting. Every interface is engineered, tested, and electrically protected. Software support includes Armbian Linux or Home Assistant OS out of the box.Why JetHub D1+ instead of SBC + modules?Unlike assembled DIY stacks, JetHub D1+ provides:Integrated and tested hardware – Zigbee, RS-485, isolated I/O and relays work out of the box2. Electrical resilience – galvanic isolation, EMI-safe design, stable power deliveryDIN-rail housing – ready for electrical panels and server cabinetsIndustrial interfaces – RS-485 (Modbus), relay outputs, digital I/OReliable software base – Armbian support and update infrastructureSilent 24/7 operation – fanless and stable in long-term deploymentsThis is hardware you can deploy both at home and in production environments without improvisation.Hardware overviewPowered by the Amlogic A113X quad-core Cortex-A53 SoC, JetHub D1+ delivers efficient performance with a stable thermal profile suitable for enclosure-based installations. SpecificationDetailsCPUAmlogic A113X, quad-core Cortex-A53RAM2 GB DDR4Storage32 GB eMMCWirelessDual-band Wi-Fi + Bluetooth 5.0 (RTL8822CS)ZigbeeZigbee 3.0 module (EFR32MG21)Ethernet10/100 Mbit/sUSBUSB 2.0MountingDIN-railCoolingFanlessPower9–56 V DC Automation interfaces for real projectsJetHub D1+ includes interfaces needed in the real world ready for direct field connection without adapters: InterfacePurpose4 × Digital Inputs (isolated)Sensors, buttons, automation signals3 × Relay Outputs (5 A / 250 V)Lighting, contactors, low-power loads2 × isolated RS-485 busesModbus RTU, PLCs, industrial devices1-Wire (DS2482)Temperature sensorsInternal temperature sensorCPU thermal control Software: Armbian or home Assistant – Your ChoiceJetHub D1+ ships with a preinstalled OS of your choice:ArmbianFull Linux environmentSSH access, Debian ecosystemIdeal for automation gateways, custom servicesDocker, MQTT, Node-RED, Python supportHome assistant OSReady-to-use smart home controllerBuilt-in Zigbee2MQTT compatibilityAdd-ons ecosystemPerfect for automation integratorsBoth are officially supported images from JetHome with regular updates available.Connectivity for modern automationJetHub D1+ provides native Zigbee (no USB dongles required) and can seamlessly combine both wireless and wired field devices in a single automation network:Pair Zigbee sensors and switches nativelyIntegrate RS-485 meters, relays and PLCsCombine Zigbee2MQTT + Modbus + MQTT in one systemRemote control via VPN or SSHMQTT ready gateway functionDocumentation and supportFull documentation is available, including schematics, API interfaces and wiring examples:Technical docs: JetHub D1+ Full SpecificationsSupport community: https://t.me/jethome_iotAvailabilityThe JetHub D1+ is now available for worldwide shipping through JetHome’s official AliExpress store.Order JetHub D1+ on AliExpresshttps://jethome.aliexpress.comJetHub D1+ is a reliable controller for automation deployments where stability matters more than cable experiments. With Armbian support, tested hardware integration and industrial I/O, it bridges the gap between DIY flexibility and professional-grade engineering.Whether you’re building: Smart home hubs, Industrial monitoring, Energy management systems, IoT gateways, BMS / HVAC automation, Remote telemetry controllers, JetHub D1+ is a strong foundation to build on.View the full article
