I noticed that the Cubie a5e would reboot when anything that draws moderate power (>100mA) was connected to the USB3 port. Thought it was my power supply or USB cable, but after changing that out and doing some testing, I have determined that the reboot problem doesn't happen with the Radxa Bullseye image, only with the Armbian Trixie. I haven't had a chance to test older Armbian builds to see if it broke somewhere along the way, but that's what I'll do next.
Armbian boot (26.2.0 trunk 385):
U-Boot SPL 2026.01_armbian-2026.01-S127a-P96c6-H560c-Va7f1-B2eb2-R448a (Feb 03 2026 - 12:13:55 +0000)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.13.0(debug):armbian
NOTICE:  BL31: Built : 12:13:32, Feb  3 2026
NOTICE:  BL31: Detected Allwinner A523 SoC (1890)
NOTICE:  BL31: Found U-Boot DTB at 0xa0c06a8, model: Radxa Cubie A5E
INFO:    Configuring SPC Controller
INFO:    BL31: Platform setup done
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    Maximum SPI INTID supported: 287
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a55: CPU workaround for erratum 1530923 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
ns16550_serial serial@2500000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2026.01_armbian-2026.01-S127a-P96c6-H560c-Va7f1-B2eb2-R448a (Feb 03 2026 - 12:13:55 +0000) Allwinner Technology
CPU:   Allwinner A523 (SUN55I)
Model: Radxa Cubie A5E
DRAM:  2 GiB
sunxi_set_gate: (CLK#35) unhandled
Core:  88 devices, 25 uclasses, devicetree: separate
WDT:   Not starting watchdog@2050000
MMC:   mmc@4020000: 0
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
In:    serial@2500000
Out:   serial@2500000
Err:   serial@2500000
Net:   eth0: ethernet@4500000
starting USB...
sun4i_usb_phy phy@4100400: External vbus detected, not enabling our own vbus
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Bus usb@4101000: 1 USB Device(s) found
Bus usb@4101400: 1 USB Device(s) found
Bus usb@4200000: 1 USB Device(s) found
Bus usb@4200400: 1 USB Device(s) found
Hit any key to stop autoboot: 0
PCIe: Acquiring resources...
PCIe: All resources acquired. Starting power-on sequence...
PCIe: Toggling external device reset (PERST#)...
PCIe: Hardware power-on sequence successful.
PCIe: Disabling DBI write protection...
PCIe: DBI  region: 0x04800000-0x04c80000
PCIe: IO   region: 0x21000000-0x22000000
PCIe: MEM  region: 0x22000000-0x30000000
PCIe: CFG  region: 0x20000000-0x21000000
PCIe: Lanes: 1, Max Speed: Gen2
  Link Status: 0x00000004
  RDLH_LINK_UP: 0
  SMLH_LINK_UP: 0
  LINK_SPEED: 0
  LINK_WIDTH: 0
  RDLH_LINK_UP: 0
  SMLH_LINK_UP: 0
  LINK_SPEED: 0
  LINK_WIDTH: 0
  Link Status: 0x00000017
  RDLH_LINK_UP: 1
  SMLH_LINK_UP: 1
  LINK_SPEED: 0
  LINK_WIDTH: 0
pcie link up success
PCIe: Link active at Gen2
Device 0: Vendor: 0x1e0f Rev: 10410105 Prod: X06PD8L0QUM1
            Type: Hard Disk
            Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
... is now current device
Scanning nvme 0:1...
Found U-Boot script /boot.scr
4641 bytes read in 0 ms
U-boot loaded from SD
Boot script loaded from nvme
263 bytes read in 0 ms
Load fdt: /dtb/allwinner/sun55i-a527-cubie-a5e.dtb
37110 bytes read in 1 ms (35.4 MiB/s)
Working FDT set to 4fa00000
Failed to load '/dtb/allwinner/overlay/sun55i-a527-fixup.scr'
16552556 bytes read in 55 ms (287 MiB/s)
39950848 bytes read in 102 ms (373.5 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x42900000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    16552492 Bytes = 15.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 49036000, end 49fff22c ... OK
   Loading Device Tree to 0000000048fc4000, end 0000000049035fff ... OK
Working FDT set to 48fc4000
Starting kernel ...
Armbian_community 26.2.0-trunk.385 Trixie ttyS0
radxa-cubie-a5e login:
Radxa Bookworm Boot:
[207]HELLO! BOOT0 is starting!
[210]BOOT0 commit : 33d8db429a-dirty
[214]periph0 has been enabled
[218]set pll end
[219]PL gpio voltage : 3.3V
[224]PMU: AXP2202
[229]PMU: AXP1530
[234]power mode:33, sys_vol:920
[239]vaild para:1  select dram para0
[242]dram_para[0]:0x4b0
[245]dram_para[1]:0x8
[247]dram_para[2]:0x7070707
[250]dram_para[3]:0xd0d0d0d
[253]dram_para[4]:0xe0e
[256]dram_para[5]:0x84848484
[259]dram_para[6]:0x310a
[262]dram_para[7]:0x10001000
[265]dram_para[8]:0x0
[267]dram_para[9]:0x34
[270]dram_para[10]:0x1b
[272]dram_para[11]:0x33
[275]dram_para[12]:0x3
[277]dram_para[13]:0x0
[280]dram_para[14]:0x0
[282]dram_para[15]:0x4
[285]dram_para[16]:0x72
[287]dram_para[17]:0x0
[290]dram_para[18]:0xe
[292]dram_para[19]:0x0
[295]dram_para[20]:0x0
[297]dram_para[21]:0x26
[300]dram_para[22]:0x80808080
[303]dram_para[23]:0x6060606
[306]dram_para[24]:0x1f0b0503
[309]dram_para[25]:0x0
[312]dram_para[26]:0x3a000000
[315]dram_para[27]:0x802f3333
[318]dram_para[28]:0xc0c0bbbf
[321]dram_para[29]:0x35352f31
[325]dram_para[30]:0xc64
[327]dram_para[31]:0x48484848
[331]board init ok
[353]enable_jtag
[355]card no is 0
[357]sdcard 0 line count 4
[360][mmc]: mmc driver ver 2023-03-24 16:23
[370][mmc]: Wrong media type 0x0
[374][mmc]: ***Try SD card 0***
[395][mmc]: HSSDR52/SDR25 4 bit
[398][mmc]: 50000000 Hz
[401][mmc]: 60906 MB
[403][mmc]: ***SD/MMC 0 init OK!!!***
[414]DRAM BOOT DRIVE INFO: V0.67
[419]DRAM_VCC set to 1100 mv
[545]DRAM retraining ten
[671]DRAM retraining ten
[689][AUTO DEBUG]32bit,1 ranks training success!
[718]Soft Training Version: T2.0
[7773][SOFT TRAINING] CLK=1200M Stable memtest pass
[7778]DRAM CLK =1200 MHZ
[7781]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[7792]phy_dfs_clk1 = 800M
[8078]phy_dfs_clk2 = 400M
[8169]phy_dfs_clk3 = 150M
[8290]phy_dfs_clk0 = 1200M
[8293]DRAM MDFS VERSION INFO: V0.660
[8298]DRAM MDFS time =38892 ns
[8301]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, tpr13 = 6465
[8329]DRAM simple test OK.
[8332]dram size =2048
[8339]nsi init 2023-2-23
[8343]error:bad magic.
[8463]Loading boot-pkg Succeed(index=1).
[8467]Entry_name        = u-boot
[8476]Entry_name        = monitor
[8480]Entry_name        = scp
[8484]Entry_name        = dtb
[8487]mmc not para
[8489]Jump to second Boot.
NOTICE:  BL31: OP-TEE 32bit detected
NOTICE:  BL31: U-BOOT 32bit detected
NOTICE:  BL31: v2.5(debug):a6e1826c1
NOTICE:  BL31: Built : 10:10:43, Mar 28 2025
NOTICE:  BL31: No DTB found.
nsi init ok 2022-11-08
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2018.07-11-boot-aw2501-g4f803d1684e-dirty (Dec 05 2025 - 10:08:58 +0000) Allwinner Technology
[08.641]CPU:   Allwinner Family
[08.644]Model: Radxa Cubie A5E
I2C:   ready
[08.655]DRAM:  2 GiB
[08.659]Relocation Offset is: 75e60000
[08.721]secure enable bit: 0
[08.725]PMU: AXP2202
[08.753][AXP2202] comm status : 0x0 = 0x20, 0x1 = 0x90
[08.758][AXP2202] onoff status: 0x20 = 0x4, 0x21 = 0x0
[08.763][AXP2202] reboot/charge status: 0xf0 = 0x0
[08.768]PMU: AXP1530
[08.771]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=600Mhz
[08.777]gic: sec monitor mode
SPI ALL:   ready
[08.782]flash init start
[08.785]workmode = 0,storage type = 1
[08.788][mmc]: mmc driver ver uboot2018:2024-10-18 9:01:00 -- uboot2018:2025-03-28 10:03:00
[08.796][mmc]: get sdc_type fail and use default host:tm1.
[08.802][mmc]: can't find node "mmc0",will add new node
[08.807][mmc]: fdt err returned <no error>
[08.811][mmc]: Using default timing para
[08.814][mmc]: SUNXI SDMMC Controller Version:0x50500
[08.843][mmc]: card_caps:0x3000000a
[08.846][mmc]: host_caps:0x3000003f
[08.851]sunxi flash init ok
get value error
[08.860]Loading Environment from SUNXI_FLASH... OK
[08.867]No ethernet found.
[08.877]Fail to get de's irq!
[08.915]NOT support bridge yet
[08.918]Warn: no find panel or bridge
[08.921]hdmi@5520000 disconnected
[08.924]drm hdmi get mode: 1920x1080@60Hz
hdmi@5520000: use force output detailed mode clock 148500 kHz, flags[5]
    H: 1920 2008 2052 2200
    V: 1080 1084 1089 1125
bus_format: 0
[09.134]the secure storage item0 copy0 magic is bad
[09.148]the secure storage item0 copy1 magic is bad
[09.152]usb burn from boot
delay time 0
weak:otg_phy_config
[09.163]usb prepare ok
[09.466]overtime
[09.471]do_burn_from_boot usb : no usb exist
cann't get the boot_base from the env
[09.494]update part info
[09.498]update bootcmd
PCIe speed of Gen2
[09.908]change working_fdt 0xbbe0fe18 to 0xbbddfe18
get value error
[09.914][mmc]: get sunxi-mmc0 string failed
[09.918]The storage not support sample function
[09.924]## error: update_fdt_dram_para_from_bootpara : FDT_ERR_NOTFOUND
ret 0
[09.935]chip id : 0x0000ff10 0x00004824 0x0000d710 0x00001d96
[09.940]chip id : 0x0000ff10 0x00004824 0x0000d710 0x00001d96
[09.946]Could not find nodeoffset for used ext pmu:reg-axp1530
[09.951]update dts
curr_device:0
Device: SUNXI SD/MMC
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 59.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
starting USB...
USB0:   start sunxi  USB-DRD...
config usb clk ok
sunxi USB-DRD init ok...
USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
USB1:   start sunxi  USB1-Host...
config usb clk ok
sunxi USB1-Host init ok...
USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
Device 0: device type unknown
** Bad device usb 0 **
mmc0 is current device
Scanning mmc 0:2...
Scanning mmc 0:3...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
ERROR: reserving fdt memory region failed (addr=bbed0000 size=7e9000)
1323 bytes read in 7 ms (184.6 KiB/s)
U-Boot menu
1:      Debian GNU/Linux 11 (bullseye) 5.15.147-13-aw2501
2:      Debian GNU/Linux 11 (bullseye) 5.15.147-13-aw2501 (rescue target)
Enter choice: 1:        Debian GNU/Linux 11 (bullseye) 5.15.147-13-aw2501
Retrieving file: /boot/initrd.img-5.15.147-13-aw2501
7060674 bytes read in 300 ms (22.4 MiB/s)
Retrieving file: /boot/vmlinuz-5.15.147-13-aw2501
20992512 bytes read in 877 ms (22.8 MiB/s)
append: root=UUID=9645203c-b680-44b6-8b18-068d9e110402 console=ttyAS0,115200n8 rootwait clk_ignore_unused mac_addr=08:ef:6c:c7:8b:ad mac1_addr=08:ef:6c:c7:8b:ac quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 kasan=off
Retrieving file: /usr/lib/linux-image-5.15.147-13-aw2501/allwinner/sun55i-a527-cubie-a5e.dtb
161015 bytes read in 18 ms (8.5 MiB/s)
get value error
[16.446]The storage not support sample function
ret 0
[16.563]update dts
stop sunxi USB-DRD ok...
stop sunxi USB1-Host ok...
   Loading Ramdisk to 49944000, end 49fffcc2 ... OK
[16.598]Starting kernel ...
[16.601]total: 16601 ms
[16.603][mmc]: MMC Device 2 not found
[16.606][mmc]: mmc 2 not find, so not exit
NOTICE:  [SCP] :wait arisc ready....
NOTICE:  [SCP] :arisc version: [364dad9bcd34230512f015ab5c6cefa12bd238d0]
NOTICE:  [SCP] :arisc startup ready
NOTICE:  [SCP] :arisc startup notify message feedback
NOTICE:  [SCP] :sunxi-arisc driver is starting
NOTICE:  BL3-1: Next image address = 0x40200000
NOTICE:  BL3-1: Next image spsr = 0x3c5
[    0.071969] AW BSP version: caee29fcb3, 2025-12-09 07:23:49, RadxaOS SDK
[    0.140107] sunxi:twi_sunxi-2502000.twi0:[ERR]: pinctrl_get failed
[    0.140127] sunxi:twi_sunxi-2502000.twi0:[ERR]: TWI failed to get resource
[    0.143734] sunxi:axp2101-6-0036:[ERR]: Unable to match OF ID
[    0.310164] sunxi:ccu_ddr:[ERR]: dram_clk:1200
[    0.310191] sunxi:ccu_ddr:[ERR]: dram_div:0x1f0b0503
[    0.310832] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[    0.310842] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[    0.310886] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[    0.310892] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[    0.311482] sunxi:sunxi_uart-uart0:[ERR]: uart0 error to get fifo size property
[    0.386566] NSI_PMU 2020000.nsi-controller: no topo process for clk path type:0
[    0.394816] no topo process for topo type:0
[    0.402846] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: Could not get mbus clock
[    0.411011] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: Could not get store clock
[    0.419251] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: Could not get msi_lite clock
[    0.457791] sunxi:sunxi_mmc_host-4020000.sdmmc:[ERR]: Could not get mbus clock
[    0.466069] sunxi:sunxi_mmc_host-4020000.sdmmc:[ERR]: Could not get store clock
[    0.474428] sunxi:sunxi_mmc_host-4020000.sdmmc:[ERR]: Could not get msi_lite clock
[    0.475236] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.492239] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.501531] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.510880] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.520159] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.529448] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.538076] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: Could not get mbus clock
[    0.538726] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.546202] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: Could not get store clock
[    0.562758] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: Could not get msi_lite clock
[    0.572128] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.581414] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.590691] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.600035] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.609310] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.617707] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !!
[    0.627037] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !!
[    0.635533] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.644823] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.654111] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.663385] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.672711] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.682003] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.691285] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.700598] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.709898] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.719191] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !!
[    0.727648] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: retry:set phase failed or over retry times
[    0.737523] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: retry:give up
[    0.744833] sunxi:sunxi_mmc_host-4020000.sdmmc:[ERR]: sdc0 :the host don't support tuning in kernel
[    1.235336] sunxi:sunxi_sidefuse init success!
[    1.241281] inno-combphy 4f00000.phy: get select3v3-supply fail
[    1.740355] sunxi-rc-recv 2005000.irrx: sunxi_irrx_resource_get: get ir protocol failed
[    1.771768] sunxi:axp2202_battery:[ERR]: axp2202-battery device is not configed
[    1.794813] sunxi-rfkill soc@3000000:rfkill: get gpio chip_en failed
[    1.804693] [NAND][NE] Not found valid nand node on dts
[    3.128108] cma: cma_alloc: reserved: alloc failed, req-size: 512 pages, ret: -12
[    4.777883] sunxi:VE:[ERR]: 409 map_max_ve_freq_by_vf_sun55iw3(): can not match dvfs[0x1] and vol[900 mv], use default ve_freq
[    4.815646] cma: cma_alloc: reserved: alloc failed, req-size: 512 pages, ret: -12
[    4.827791] sunxipart: failed to parse sunxi_gpt!
[    5.002596] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dai_link_of failed
[    5.046546] sunxi:sound-codec-hdmi:[ERR]: 442 sunxi_codec_dev_probe(): register codec-hdmi success
[    5.064198] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dai_link_of failed
[    5.084859] debugfs: Directory '7114000.i2s2_plat' with parent 'sndhdmi' already present!
[    5.094216] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !!
[    5.105028] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !!
[    5.175761] axp2202-bldo1: Restricting voltage, 3300000-1800000uV
[    5.182730] sunxi-rfkill soc@3000000:rfkill: wlan power[0] (axp2202-bldo1) set voltage failed
[    5.192433] sunxi-rfkill soc@3000000:rfkill: set power failed
[    5.250133] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 7, RTO !!
[    5.258714] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 7, RTO !!
[    5.267263] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 7, RTO !!
[    5.275819] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 7, RTO !!
[    5.310636] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !!
[    5.320383] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !!
[    5.625825] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1404>: bus down
[    6.762994] ieee80211 phy0:
[    6.762994] *******************************************************
[    6.762994] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
Debian GNU/Linux 11 radxa-cubie-a5e ttyAS0
