Olejka Posted February 18 Posted February 18 I am running Ubuntu 24.04 Noble (Armbian Linux 6.1.115-vendor-rk35xx) and no additional packages affecting VPU performance have been installed; everything is stock. Jellyfin is running in Docker, and transcoding works perfectly, except for some movies. I tried to play a 4K video in Chrome (native HEVC support), set the bitrate to 40mbps, and the video played normally at a transcoding speed of about 3x, but after a while, Orange Pi crashed. In Firefox inside neko (where there is no hardware acceleration and HEVC), the crash happened even faster, after ~2 seconds of playback. The crash happens as if the board loses power: journalctl is not saved, nothing is visible via ssh. I use a 100W Baseus GaN Pro Desktop Power Strip (model CCGAN100-1ACE) and the Orange Pi is the only device connected to it. I also have a 100W cable that shows the current consumption in watts. During transcoding, it showed 10, and then the board hard rebooted again, so I don't think this is related to power issues. Before that, I used Ubuntu 24.04 from Joshua Riek, and there was a problem with the Mali driver crashing under heavy load or simply after a while. A similar hard reboot also occurred if the driver was “too slow” to crash. Here is Jellyfin's video info: Spoiler Video Title: Deepwater Horizon (2016) - 4K - HEVC - Dolby Vision Profile 8.1 (HDR10) Codec: HEVC AVC: No Profile: Main 10 Level: 153 Resolution: 3840x2160 Aspect ratio: 16:9 Anamorphic: No Interlaced: No Framerate: 23.976025 Bitrate: 97917 kbps Bit depth: 10 bit Video range: HDR Video range type: DOVIWithHDR10 DV title: Dolby Vision Profile 8.1 (HDR10) DV version major: 1 DV version minor: 0 DV profile: 8 DV level: 6 DV rpu preset flag: 1 DV el preset flag: 0 DV bl preset flag: 1 DV bl signal compatibility id: 1 Color space: bt2020nc Color transfer: smpte2084 Color primaries: bt2020 Pixel format: yuv420p10le Ref frames: 1 ffprobe: Spoiler Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default) Metadata: title : Deepwater Horizon (2016) BPS : 76184352 DURATION : 01:47:19.350000000 NUMBER_OF_FRAMES: 154390 NUMBER_OF_BYTES : 61322213457 _STATISTICS_WRITING_APP: mkvmerge v67.0.0 ('Under Stars') 64-bit _STATISTICS_WRITING_DATE_UTC: 2022-05-17 10:46:34 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Side data: DOVI configuration record: version: 1.0, profile: 8, level: 6, rpu flag: 1, el flag: 0, bl flag: 1, compatibility id: 1 I also have a 4 GB model of Orange Pi 5 (not B), and there were no problems with transcoding this video; it was just slow due to the small amount of RAM. I don't even know where to start. What should I do to at least understand the cause of this issue? 0 Quote
eselarm Posted February 19 Posted February 19 10 hours ago, Olejka said: The crash happens as if the board loses power: journalctl is not saved, nothing is visible via ssh. I use a 100W Baseus GaN Pro Desktop Power Strip (model CCGAN100-1ACE) and the Orange Pi is the only device connected to it. I also have a 100W cable that shows the current consumption in watts. During transcoding, it showed 10, and then the board hard rebooted again, so I don't think this is related to power issues. You should pipe the output from a serial console cable to another computer where you store it. Make sure kernel cmdline loglevel=7 AFAIR the OPI5+ can only use 5V as input supply power. Your 100W PSU might be a standard spec one so it does only deliver 3A at 5V. This might be a perfect 5.000V, but an extra cable in between will drop that a bit and the risk is then that short higher power drap will either make the 5V goo too low and/or the PSU will cut the power because more than 3A drawn during a short peak. You will need to look at powering first. Usually 5V only SBC's can be powered via other input then the USB-C input. You need to read the instruction for your OPI5+, and also OPi5, those might be different. OPI5+ and also OPi5 should transcode at more or less the same speed, large amount of memory does not really matter as it is just HW processing blocks doing the work in a rather limited memory space. You should do a manual CLI jellyfin-ffmpeg based transcode, see /var/log/jellyfin how commandline arguments for that specific video look like (and simplify it, output to 1 file instead of chunks m3u8). And or search this forum, I at least have posted examples for check/test earlier. You might also try to reproduce it with a publiclicy know video, look for big buck bunny test vids or so. 0 Quote
Solution Olejka Posted February 20 Author Solution Posted February 20 As it turned out, Orange Pi does not support Power Delivery Negotiations and requires a "dumb" power supply providing 5V 4A. My power supply delivered 2A and then went into protection mode; the board itself had nothing to do with it 0 Quote
