I can't install mpd on Armbian v26.2 rolling for NanoPi Air running Armbian Linux 6.12.76-current-sunxi Packages: Ubuntu stable (noble)
user@nanopiair:~$ sudo apt install mpd
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 mpd : Depends: libavcodec61 (>= 7:7.0) but it is not installable
       Depends: libavfilter10 (>= 7:7.0) but it is not installable
       Depends: libavformat61 (>= 7:7.0) but it is not installable
       Depends: libavutil59 (>= 7:7.0) but it is not installable
       Depends: libflac14 (>= 1.5.0) but it is not installable
       Depends: libfmt10 (>= 10.1.1+ds1) but it is not installable
       Depends: libicu76 (>= 76.1-1~) but it is not installable
       Depends: libiso9660-12 (>= 2.2.0) but it is not installable
       Depends: libsidplayfp6 (>= 2.12.0) but it is not going to be installed
       Depends: libjs-sphinxdoc (>= 8.1) but it is not going to be installed
       Depends: sphinx-rtd-theme-common (>= 3.0.2+dfsg) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
What is the issue with missing packages ?
