Hello ,
noticed that on the sbc "apt-get update" takes a long time,
it ignores some sources and sometimes it slow to load.
was wondering if could clean up the process, since it seem to look for "i386" but the sbc is on "arm64"
sudo apt update
[sudo] password for rich:
OK:1 http://ports.ubuntu.com noble InRelease
Holen:2 http://ports.ubuntu.com noble-security InRelease [126 kB]
Holen:4 https://github.armbian.com/configng stable InRelease [5.467 B]
Holen:5 https://dl.winehq.org/wine-builds/ubuntu questing InRelease [5.719 B]
Holen:6 http://ports.ubuntu.com noble-updates InRelease [126 kB]
Holen:7 http://ports.ubuntu.com noble-backports InRelease [126 kB]
Holen:3 http://armbian.lv.auroradev.org/apt noble InRelease [39,2 kB]
Holen:8 https://github.armbian.com/configng stable/main arm64 Packages [437 B]
Holen:9 https://github.armbian.com/configng stable/main i386 Packages [437 B]
Holen:10 https://dl.winehq.org/wine-builds/ubuntu questing/main amd64 Packages [60,8 kB]
Holen:11 http://ports.ubuntu.com noble/main i386 Packages [1.329 kB]
Ign:11 http://ports.ubuntu.com noble/main i386 Packages
Ign:13 http://ports.ubuntu.com noble/restricted i386 Packages
Ign:14 http://ports.ubuntu.com noble/universe i386 Packages
Ign:15 http://ports.ubuntu.com noble/multiverse i386 Packages
Ign:16 http://ports.ubuntu.com noble-security/main i386 Packages
Holen:17 http://ports.ubuntu.com noble-security/main arm64 Packages [2.092 kB]
Holen:18 https://dl.winehq.org/wine-builds/ubuntu questing/main amd64 Contents (deb) [99,8 kB]
Holen:19 http://armbian.lv.auroradev.org/apt noble/noble-utils all Packages [3.136 B]
Holen:20 http://armbian.lv.auroradev.org/apt noble/noble-utils i386 Packages [3.709 B]
Holen:21 http://armbian.lv.auroradev.org/apt noble/noble-utils arm64 Packages [18,3 kB]
Holen:22 http://armbian.lv.auroradev.org/apt noble/noble-desktop arm64 Packages [137 kB]
Holen:23 http://ports.ubuntu.com noble-security arm64 Contents (deb) [191 MB]
Holen:24 http://ports.ubuntu.com noble-security i386 Contents (deb) [61,1 MB]
Ign:25 http://ports.ubuntu.com noble-security/restricted i386 Packages
Holen:26 http://ports.ubuntu.com noble-security/restricted arm64 Packages [4.844 kB]
Ign:27 http://ports.ubuntu.com noble-security/universe i386 Packages
Holen:28 http://ports.ubuntu.com noble-security/universe arm64 Packages [1.505 kB]
Ign:29 http://ports.ubuntu.com noble-security/multiverse i386 Packages
Holen:30 http://ports.ubuntu.com noble-security/multiverse arm64 Packages [44,1 kB]
Ign:31 http://ports.ubuntu.com noble-updates/main i386 Packages
Holen:32 http://ports.ubuntu.com noble-updates/main arm64 Packages [2.451 kB]
Holen:34 http://ports.ubuntu.com noble-updates arm64 Contents (deb) [199 MB]
Holen:36 http://ports.ubuntu.com noble-updates i386 Contents (deb) [66,0 MB]
Holen:37 http://ports.ubuntu.com noble-updates/restricted arm64 Packages [5.019 kB]
Ign:38 http://ports.ubuntu.com noble-updates/restricted i386 Packages
Holen:39 http://ports.ubuntu.com noble-updates/universe arm64 Packages [2.116 kB]
Ign:41 http://ports.ubuntu.com noble-updates/universe i386 Packages
Holen:42 http://ports.ubuntu.com noble-updates/multiverse arm64 Packages [45,7 kB]
Ign:43 http://ports.ubuntu.com noble-updates/multiverse i386 Packages
Ign:44 http://ports.ubuntu.com noble-backports/main i386 Packages
Holen:45 http://ports.ubuntu.com noble-backports arm64 Contents (deb) [786 kB]
Ign:46 http://ports.ubuntu.com noble-backports/universe i386 Packages
Holen:47 http://ports.ubuntu.com noble-backports/universe arm64 Packages [36,1 kB]
Ign:48 http://ports.ubuntu.com noble-backports/multiverse i386 Packages
Fehl:11 http://ports.ubuntu.com noble/main i386 Packages
  404  Not Found [IP: 91.189.92.20 80]
Fehl:16 http://ports.ubuntu.com noble-security/main i386 Packages
Fehl:31 http://ports.ubuntu.com noble-updates/main i386 Packages
Fehl:44 http://ports.ubuntu.com noble-backports/main i386 Packages
Es wurden 537 MB in 2 min 2 s geholt (4.394 kB/s).
Paketlisten werden gelesen… Fertig
E: Fehlschlag beim Holen von http://ports.ubuntu.com/dists/noble/main/binary-i386/Packages 404  Not Found [IP: 91.189.92.20 80]
E: Fehlschlag beim Holen von http://ports.ubuntu.com/dists/noble-security/main/binary-i386/Packages 404  Not Found [IP: 91.189.92.20 80]
E: Fehlschlag beim Holen von http://ports.ubuntu.com/dists/noble-updates/main/binary-i386/Packages 404  Not Found [IP: 91.189.92.20 80]
E: Fehlschlag beim Holen von http://ports.ubuntu.com/dists/noble-backports/main/binary-i386/Packages 404  Not Found [IP: 91.189.92.20 80]
E: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
thank you
Posted (edited)
I see wine, so you likely have let some tool mess up your Debian packaging setup. See what the following shows:
sudo dpkg --print-architecture
sudo dpkg --print-foreign-architectures
For the rest , this is standard Debian methods, I forgot it a bit, but I see google AI shows all other commands w.r.t. this issue. But make sure you understand it. I at least don't know how to fix it, unless you just accept to remove all that wine stuff I guess. But see what your goal is or what you want.
Edited by eselarm
