gene1934 Posted Thursday at 10:26 PM Posted Thursday at 10:26 PM This system has been running for several months months as a backup server with a nobel release about a year old, maybe some older, using two usb3 7 port hubs because 1 hub could not handle the current draw of 5 TSMC 4T SSD's using startech usb3.1 cables to connect 5 if them in a /raid6 configuration for an 11.1 Tb drive. But I decided to do an as sudo -i, "apt update" and was advised that would update about 430 files so I figured I'd do an apt update -y, then and apt --purge autoremove". Unforch it went into lala land while making a new initrd. After about 20 minutes I did a powerdown to be greeted by a repeating loop indicating there was no network. So I dl'd & wrote the month old 26.03 release. Which after getting chrony to work using my own local ntpsec, finally got the correct time and I'm able to login both directions using ssh me@machine assigned address, but no outside my local net addresses are found, dhcp isn't working. It is supposed to first query /etc/hosts wich does work, but if that doesn't resolve the name in dnsmasq, the router then query's the dns server at my ISP, which works for the rest of my 8 machines here, but does Not work for the 26.03 just released a month ago. ip a reports: 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether be:63:9c:35:dd:4f brd ff:ff:ff:ff:ff:ff inet 192.168.71.2/24 brd 192.168.71.255 scope global noprefixroute end0 valid_lft forever preferred_lft forever inet6 fe80::bc63:9cff:fe35:dd4f/64 scope link valid_lft forever preferred_lft forever ip r reports: 192.168.71.0/24 dev end0 proto kernel scope link src 192.168.71.2 metric 100 gene@amanda:~$ A ping -c1 yahoo.com kills enough time its several seconds before it reports "network is unreachable" Can you see whats wrong, or give me the newer tracing tools to find the error? Thank you. 0 Quote
gene1934 Posted Thursday at 10:30 PM Author Posted Thursday at 10:30 PM no wireless is configured except the BT mouse, which works fine. 0 Quote
bedna Posted Thursday at 10:35 PM Posted Thursday at 10:35 PM (edited) What's in your /etc/resolv.conf? And what do you mean with "dhcp isn't working"? Is 192.168.71.2 not the correct ip? Where is your dhcp? Your router? Edited Thursday at 10:48 PM by bedna 0 Quote
gene1934 Posted Thursday at 10:47 PM Author Posted Thursday at 10:47 PM the router reflashed with a recent dd-wrt runs dnsmasq, which caches the ISP. If that fails it query's the ISP's server, which works fine for the other 7 machines here. 0 Quote
bedna Posted Thursday at 10:50 PM Posted Thursday at 10:50 PM I repeat, what is in your /etc/resolv.conf? 0 Quote
gene1934 Posted Thursday at 11:06 PM Author Posted Thursday at 11:06 PM untouched and wrong as can be: # # This file might be symlinked as /etc/resolv.conf. If you're looking at # /etc/resolv.conf and seeing this text, you have followed the symlink. # # This is a dynamic resolv.conf file for connecting local clients to the # internal DNS stub resolver of systemd-resolved. This file lists all # configured search domains. # # Run "resolvectl status" to see details about the uplink DNS servers # currently in use. # # Third party programs should typically not access this file directly, but only # through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a # different way, replace this symlink by a static file or a different symlink. # # See man:systemd-resolved.service(8) for details about the supported modes of # operation for /etc/resolv.conf. nameserver 127.0.0.53 options edns0 trust-ad search . Damn, doesn't anyone use /etc/hosts for small home networks anymore? Toss in that you don't install ANY manpages so us users are running blind 99% of the time. Thanks bedna. 0 Quote
gene1934 Posted Thursday at 11:10 PM Author Posted Thursday at 11:10 PM gene@amanda:~$ resolvectl status Global Protocols: -LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported resolv.conf mode: stub Link 2 (end0) Current Scopes: DNS Protocols: +DefaultRoute -LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported Current DNS Server: 192.168.71.0 DNS Servers: 192.168.71.0 0 Quote
bedna Posted Thursday at 11:19 PM Posted Thursday at 11:19 PM (edited) 42 minutes ago, gene1934 said: nameserver 127.0.0.53 Either the config on the device is wrong, there is supposed to be a dns ON the device or the dhcp server is handing out wrong dns to the device. 42 minutes ago, gene1934 said: Damn, doesn't anyone use /etc/hosts for small home networks anymore? Not on every specific device if there is a local dns server available on the network. Then it's normally done on the local dns itself by first checking local configs (like /etc/hosts) and if not available, resolve using online dns servers and then send the response to the device. And the dhcp server is obv configured to point to the local dns server. That way the configs gets propagated via the dhcp lease to all devices on the network. Edit As far as I know, network manager is default on armbian (correct me if I'm wrong) and that should have edited your /etc/resolv.conf. So since it's not, you have made changes outside of default config somehow. Could be that the specific release and device you use does not utilize network manager. But since you have not disclosed that info, hard to know. But it looks like you use systemd-resolved so you should check how that works. Edit2 I was wrong about network manager, see https://docs.armbian.com/User-Guide_Networking/ Edited Thursday at 11:49 PM by bedna 0 Quote
gene1934 Posted Thursday at 11:49 PM Author Posted Thursday at 11:49 PM NetworkManager is how I have been trying of configure end0 but it won't run by itself, ONLY when armbian-config runs it as a client. IDK if I can copy/paste its show me output. 0 Quote
bedna Posted Thursday at 11:58 PM Posted Thursday at 11:58 PM (edited) If you want to use network manager you have to make sure systemd is not overriding your configs, ie disable relevant systemd services. To me, it sounds easier to just use what is installed default, in this case systemd and use networkctl to interact. But it should be irrelevant. If you configure your dhcp server and dns server correctly, both systemd and network manager should pick up correct config in default config state so you should not even have to interact with either of them. (I started assuming you are using a minimal image, therefore systemd as default. You haven't disclosed what version you use, just something 26.3) Edited Friday at 12:20 AM by bedna 0 Quote
gene1934 Posted Friday at 05:19 AM Author Posted Friday at 05:19 AM the xfce4 desktop version, specficallly: Armbian_26.2.1_Bananapim5_noble_current_6.18.15_xfce_desktop.img after unpacking the xz version. The previous version that needed 430 some updates also had the mdadm stuff preloaded and had no trouble recovering the /raid6 once I had created the mount point with a mkdir /raid6. this one fails on all counts so, no entries other than control in /dev/mapper. So I'm assuming the first thing I need to install once networking is working is mdadm. But without an external network I'm locked out of everything else. Very frustrating. gene@amanda:~$ ls /dev/sd* /dev/sda /dev/sdb /dev/sdc /dev/sdd /dev/sdd2 /dev/sde1 /dev/sdf1 /dev/sdg1 /dev/sda1 /dev/sdb1 /dev/sdc1 /dev/sdd1 /dev/sde /dev/sdf /dev/sdg So all the drives are there but not recognized as the raid6. The odd /dev/sdd is probably the 1T 2.5" lappy drive I put in for a faster /swap and had plans for its use as a scratchpad drive for amanda's use but is essentially just 50G of swap now. So what do I edit to fix the network ??? 0 Quote
bedna Posted Friday at 10:57 AM Posted Friday at 10:57 AM 5 hours ago, gene1934 said: the xfce4 desktop version, specficallly: That is supposed to be using network manager, again, see documentation 5 hours ago, gene1934 said: So all the drives are there but not recognized as the raid6. Your question was about networking. How to configure your raid is a completely different question and has nothing to do with network. 5 hours ago, gene1934 said: So what do I edit to fix the network ??? Since both systemd-networkd AND network manager (and you also mention dnsmasq) is enabled, you have most likely done changes to the system way outside of what you should. If you claim the image you downloaded CAME with all that installed and enabled by default, I would suggest you provide proof of that and then report back as a bug. As for your general network setup, I gave you my opinion earlier: 11 hours ago, bedna said: 11 hours ago, gene1934 said: Damn, doesn't anyone use /etc/hosts for small home networks anymore? Not on every specific device if there is a local dns server available on the network. Then it's normally done on the local dns itself by first checking local configs (like /etc/hosts) and if not available, resolve using online dns servers and then send the response to the device. And the dhcp server is obv configured to point to the local dns server. That way the configs gets propagated via the dhcp lease to all devices on the network. 0 Quote
gene1934 Posted Friday at 12:56 PM Author Posted Friday at 12:56 PM In this local network, there is only one name to address configured in dd-wrt. dnsmasq The only true dns server is at my ISP and its been that way here since RH5.0 in 1998. I have NO M$ experience in my personal history, coming into modern computing by way of a TRS-80 Color computer running os-9, to amigados, about 10 of them as I drug WDTV-5 into the computer age when I became the Chief Engineer in 1984, but I started computing in 1978 at KRCR-12 in Redding Kalipornia. Writing a utility to prepare an automatic station break machines tapes for air that ran on an RCA-1802 and 4k os static ram that cost $400 back then. But lets get back on topic. What I want for outside names NOT in /etc/hosts: the query gets passed to the router at 192.168.71,1:53 where dnsmasq checks to see if its in its cache, and failing that, fwds the query to the dns server at my ISP for resolution. That address is not known on my side of the router. This typically adds about 1.5ms to the ping time. And nowhere in that chain fails this sequence EXCEPT this new install on a bananapi-m5. And I don't have to screw around maintaining a separate dns server of any kind. That is several times the amount of monkey business of cp-ing a common hosts file around is. But you want to insist on a dns server behind every RJ-45 jack in the house. I don't understand the Why? This is simple, quick and bulletproof until somebody decides to fix a perceived security hole, WHICH DOES NOT EXIST IF the router is reflashed with dd-wrt. I have not been touched since finding out about it in yr 1999-2000. Including a decade of running my own web page right here on this machine, stopped only because the spiders refused to honor my robots.txt. So I was paying bandwidth penalties of $150 or more a month on an SS income with my upload bandwidth filled by the robots from mj12. Whoever the hell they are. M$ spiders were in there too. People interested in my stuff couldn't get a word in edgewise. So please tell me where in the resolv.conf area what to edit to make it work, cuz I'll do it and a chattr +i on it to make it permanent. But the fix for debian bookworm, didn't fix this. 0 Quote
bedna Posted Friday at 04:06 PM Posted Friday at 04:06 PM (edited) 3 hours ago, gene1934 said: What I want for outside names NOT in /etc/hosts: the query gets passed to the router at 192.168.71,1:53 Does it? 17 hours ago, gene1934 said: nameserver 127.0.0.53 Does not look like 192.168.71.1 to me... And: 17 hours ago, gene1934 said: gene@amanda:~$ resolvectl status Global Protocols: -LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported resolv.conf mode: stub Link 2 (end0) Current Scopes: DNS Protocols: +DefaultRoute -LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported Current DNS Server: 192.168.71.0 DNS Servers: 192.168.71.0 That is not correct, that is the global scope, no ip can end with 0. 3 hours ago, gene1934 said: And I don't have to screw around maintaining a separate dns server of any kind. Ehhh... What do you call dnsmasq on your router then?!? If you don't "maintain" that, yes, things like this can happen, especially since you have set the leases to never expire. I have no idea if this is the case, it's for YOU as sysadmin of your network to know. Nobody knows what you did after install. All that is known after all things written in this thread: You have a dhcp server you have a dns server (dnsmasq) you installed Armbian_26.2.1_Bananapim5_noble_current_6.18.15_xfce_desktop.img (that comes with network manager according to documentation) It seems you have systemd-networkd enabled Unless you can prove the default config was with both systemd AND network manager, YOU have made changes that breaks the installation. Nobody can answer what you did, only you. The normal way if having a local dns server (even if it ONLY forwards request to outside dns server) is to configure the resolving for local domains in the dns server and not touch it at device level. For example a consumer grade router, it will set dns to router ip in the dhcp lease and when requests come in, resolve with asking your ISP dns servers. Hence, if looking up what dns server is used on the devices, they will NOT point to your ISP dns servers (or google or cloudflare etc), it will point to your router ip. Lets say you have a pihole on your network that acts as dns server, then you configure the router (dhcp server) to point to THAT ip for dns, hence, the dhcp lease will deliver THAT ip. And then you configure the pihole to resolve local ip:s and what outside dns servers to use. The DEVICES will ONLY see the local ip where the pihole lives in this situation. Resolving domains to local ip:s (/etc/hosts on your device) has nothing to do with your dns detection failing. This is all pretty basic networking... Edit For reference, this is what your /etc/resolve.conf should look like (or similar) if you configure your dhcp server to point at the ip where dnsmaq lives (same ip as the router itself) then propagate those settings via the dhcp lease. Then nothing has to be done on any device except for resolving local ip:s if you refuse to do that with dnsmasq. If you configure dnsmasq to do that, resolving will be done on the router instead of the devices and absolutely nothing has to be done on any device. With systemd: # Generated by resolvconf domain home nameserver 192.168.71.1 With network manager: # Generated by NetworkManager search home nameserver 192.168.71.1 If you don't want to reinstall again, make sure systemd network services are disabled and network manager is enabled and then reboot. But be mindfull you might need physical access if network completely fails at boot. IIRC relevant services are (I could be wrong here, you should read up on documentation) systemd_networkd.service, systemd_resolved.service & networkmanager.service I'm in the middle of moving, so I only have an arch desktop and laptop up and running at the moment, so I can not confirm on any armbian installation that I provide 100% accurate information. Edited Friday at 04:49 PM by bedna 0 Quote
gene1934 Posted Friday at 08:13 PM Author Posted Friday at 08:13 PM Please forget I ever mentioned dnsmasq, it exists only in the router where its working perfectly for 7 of the 8 machines here. w/o any man pages I haven't a clue how to run any of the systemd stuff so any config changes that need to be done after 1st boot in order to enable /etc/hosts for local lookups is equ to asking 10k monkeys to retype all of Shakespear's work w/o a single typo. We both know that aint gonna happen b4 the universe runs down in another 500 billion years, So, I am going to rewrite that img to a fresh 128G u-sd, change the /etc/hostname to amanda and rewrite the the /etc/hosts file with mine. Then you tell ME what to do via systemd to make a user "ping -c1 yahoo.com translate" to its dns address in <1.5 milliseconds. That rewrite will take at least an hour. maybe into 2 because the only wat to get a boot able image out of that respin is with dd if=/dev/zero bs=512 count=20 of=/dev/sdc to wipe the u-sd card. then dd if=Armbian_26.2.1_Bananapim5_noble_current_6.18.15_xfce_desktop.img bs=512 of=/dev/sdc option bs=4096 is much much faster, only about 12 minutes to write but will NOT boot nor will it mount as /dev/sdc1 to /mnt/sdc1 So ATM its being written at bs=512, hoping it will work. That takes well over an hour. You have an image writer, "Armbian.Imager_1.2.5_amd64.AppImage" which has no manpage, a useless help screen and has never written a bootable .img file to any sd card since I dl'd it in jan 25. I haven't even bothered to try it as it this time as apparently burns up any u-sd card I've tempted it with so good but cantankerous old dd to the rescue. That, and 45 years a DM-II is slowly taking my eyesight because of macular-degeneration, not your problem of coarse, but mine at 91 yrs old. But saying dd is slow is an understatement, glacial is a better description. from the shell doing the writing: root@coyote:/home/gene/Downloads/armbian# dd if=Armbian_26.2.1_Bananapim5_noble_current_6.18.15_xfce_desktop.img bs=512 of=/dev/sdc status=progress 6230856192 bytes (6.2 GB, 5.8 GiB) copied, 2939 s, 2.1 MB/s 0 Quote
gene1934 Posted Friday at 08:41 PM Author Posted Friday at 08:41 PM Because I know little to nothing about systemd, I have not touched it. If it is enabled, and IDK how to fix it if it was enabled in the .img. if so that is a bug & is a reason for a respin. Its finally done but probably won't mount as dmesg says it cannot find the ext4 file system. So another ugly thought crosses my curious mind, what is the DEFAULT file system, btrfs? 0 Quote
gene1934 Posted Friday at 09:11 PM Author Posted Friday at 09:11 PM your card imager needs a CLIBC_2_38, 3 versions newer than my bookworms 2-35, so I'm stuck at dd. 0 Quote
gene1934 Posted Friday at 09:14 PM Author Posted Friday at 09:14 PM So I'm still doing s-thing wrong with dd. What is correct for this later spin? using 128GB cards. 0 Quote
bedna Posted Saturday at 11:24 AM Posted Saturday at 11:24 AM (edited) 16 hours ago, gene1934 said: Please forget I ever mentioned dnsmasq, it exists only in the router where its working perfectly for 7 of the 8 machines here You are telling me to forget the thing I suspect is the reason for the network not working correctly...? If it is "working perfectly", why does it not resolve addresses from the bpi? Why is your bpi setting 127.0.0.53 (witch would be incorrect even if you ran a dns server ON that device, it should then be 127.0.0.1 (or the device ip), potentially at port 53 but IIRC, port 53 IS dns requests and where it will go without defining it) as dns server and not 192.168.71.1? 16 hours ago, gene1934 said: option bs=4096 is much much faster, only about 12 minutes to write but will NOT boot nor will it mount as /dev/sdc1 to /mnt/sdc1 So ATM its being written at bs=512, hoping it will work. That takes well over an hour. There you go, there is another culprit. If writing 4k in each iteration fails, but 512 works, 99,99% chance the reason is the sd card is starting to completely fail. Armbian imager would have told you verification failed when verifying the image after writing it, there is zero verification when using dd. There should be no issue writing 4096 bytes (4k) each iteration with dd on a functioning sd-card. Seems you are more interested in screaming and complaining than actually getting to the bottom of it all and set it up like a NORMAL network where NOTHING has to be done on the devices because the settings will be configured correctly with the dhcp lease. Btw, here is the dev documentation for armbian imager (and the source code ofc), took me 30 seconds to find... https://github.com/armbian/imager/blob/main/DEVELOPMENT.md Not sure what useful things you expect to find in there that is not mentioned in the help. It writes an image and does verification of that image (and you can download images), that's it. Good luck I guess, I have nothing further to add. Edited Saturday at 12:17 PM by bedna 0 Quote
gene1934 Posted Saturday at 06:00 PM Author Posted Saturday at 06:00 PM Ambian-imager requires a glibc 3 versions newer that this bookworm amd64 has, won't run at all. restricting dd to bs=512 gets only 2something megabytes a second, glacially slow. The more usual bs=4096 is 50x faster, niether of which reports any write errors. And its booted and configured. time about a month off. I run ntpsec on this machine so I'll follow the /etc/chrony/README and assign a source address by number. but ip a shows only an active ipv6 address while ip r returns nothing. hostname is bananapi-m5 which is unk on the local net. IOW its booted but network is only ipv6 & no route of either flavor is assigned. Is this exactly how it was spun to be? I've brought the card back to my reader, and will edit the /etc/hostname to match its ID for 192,168,71,2 in the /etc/hosts file I'll install. And reboot it. but the card won't mount despite the fact that it boots. from this bash xfc4 terminal: root@coyote:/etc# mount -t ext4 /dev/sdc1 /mnt/sdc1 mount: /mnt/sdc1: wrong fs type, bad option, bad superblock on /dev/loop0, missing codepage or helper program, or other error. dmesg(1) may have more information after failed mount system call. dmesg however has no additional info. only this: [1618874.568139] sd 37:0:0:0: [sdc] 249737216 512-byte logical blocks: (128 GB/119 GiB) [1618874.568944] sdc: detected capacity change from 0 to 249737216 [1618874.569933] sdc: sdc1 [1619402.494452] loop0: detected capacity change from 0 to 12943360 [1619402.494871] EXT4-fs (loop0): VFS: Can't find ext4 filesystem [1619458.923461] loop0: detected capacity change from 0 to 12943360 [1619458.923910] EXT4-fs (loop0): VFS: Can't find ext4 filesystem as I made two attempts to mount it. it loads and boots normally when installed in the bpi-m5. So other than the extra server line I just put in /etc/chrony/sources.d/ which doesn't work because no ipv4 net is even available AND the nearest ipv6 enabled anything is a minimum of 125 miles from me, its about as useful as the teats on a bore hog. Neither is the thought of editing on that tiny screen, the 40 or so lines of /etc/hosts that make up my /etc/hosts file. Doubly frustrating is the fact that the mouse speed is measurable fraction of C speed and totally disappears when inside the xfce4 terminal borders. But installed in the bpi-m5 it boots normally. back in my reader: root@coyote:/etc# e2fsck /dev/sdc e2fsck 1.47.0 (5-Feb-2023) ext2fs_open2: Bad magic number in super-block e2fsck: Superblock invalid, trying backup blocks... e2fsck: Bad magic number in super-block while trying to open /dev/sdc The superblock could not be read or does not describe a valid ext2/ext3/ext4 filesystem. If the device is valid and it really contains an ext2/ext3/ext4 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock: e2fsck -b 8193 <device> or e2fsck -b 32768 <device> Found a dos partition table in /dev/sdc ???????????? wtf??????????? And I get the same result for /dev/sdc1 obviously something is screwed. So I unpackedca new 200mb writeable sandisk u-sd & wrote the new image to it. fdisk then says its a dos partition table. Can a "dos" table be used at all on a 128gb card? I've heard not but don't know where the failure is. ipa shows only ipv6, ip r shows nothing. The only thing that could be used for net config is armbian.config which I think is NetworkManager . but that's by now known not to work. So whats left????? IOW what the hell is being used to configure network NOW with a 6.18 kernel ???? And how do I use the new tools if any, to set it up for a network address on 192.168.71.2, an ipv4 address THAT WORKS FOR EVERYTHING??????? Or do I go back to the soon to expire Armbian_25.5.1_Bananapim5_noble_current_6.12.28_xfce_desktop.img which I am using 2 more times here in front of klipper driven 3d printers. And which if asked to apt update, now want around 430 new files to do the update but failing in the make a new initrd stage. Start by putting a gpt partition table in the xz with a respin. And stop assuming that the whole planet has ipv6 connectivity, central WV is not the only ipv4 island on this planet so blessed. 0 Quote
bedna Posted Sunday at 01:59 PM Posted Sunday at 01:59 PM (edited) I'm sorry but, lmao, this is entertaining to read. The sd card is OBVIOUSLY corrupt, it even TELLS YOU THAT in what you posted. It's probably a good idea to go back to the basics and learn linux properly if you don't know what a msdos (MBR) partition table is. https://unix.stackexchange.com/questions/289389/what-are-the-differences-between-the-various-partition-tables As for how to NORMALLY SETUP A NETWORK, you can read my earlier responses, no host files on the devices, no hardcoded ip, just a correctly configured dhcp server that delivers the CORRECT IP:s to all devices. Then the dns server on the network (dnsmaq in this case) resolves desired domains to local ip:s. That way, there is NO NEED to do ANY CONFIG on the devices, it is all done on the entire network. Edited Sunday at 02:02 PM by bedna 0 Quote
gene1934 Posted Sunday at 04:11 PM Author Posted Sunday at 04:11 PM I'm sorry but, lmao, this is entertaining to read. The sd card is OBVIOUSLY corrupt, it even TELLS YOU THAT in what you posted. But you think what I am seeing should tell me it fubar. That fact that this configuration works perfectly for 6 or 7 other machines in this house long string of cat5 or cat6 cable seems to be blowing right on by. This can't be true for all 4 u-sd cards I''ve tried. The last 2 were brand new, even faster rated cards, but all are 128gig sandisk's 1: the image itself has a dos table, which doesn't work above 32gigs acc what I have read and this prevents mounting the written images for installation in a card reader, but the used partition is ext4, so it boots ok but takes a long time because the net failure blocks the boot for many minutes 2: so I back up to a 25_05 image, and at one time had it booting the 6_18 kernal, but still no net which is the original problem. ATM I am wasting my time on a 25_05 build image which is running just fine on another bpi-m5 driving a 3d printer about 10x faster than OOTB. So I'd suggest you pass this one off to someone who knows how to make a 50 line /etc/hosts file work without a dhcp because I'm doing it on 2 other wintel boxes, an rpi4b running bookworm and 3 bpi-m5's running noble on 3d printers. The best I can do is post a pix of the 'netplan status --all" screen and somebody tell me whats wrong instead of berating me for not running a dhcp server properly. 0 Quote
gene1934 Posted yesterday at 01:20 AM Author Posted yesterday at 01:20 AM what is installed to be similar to tcpdump since tcpdump is not installed? the date is off about 11 months in the past which disables net resolution in dd-wrt. Apparently ARP is in play here, as I am seeing lots of this in a tcpdump =ieno1|grep amanda here on this machine but I see no answers: 16:42:20.926695 ARP, Request who-has amanda.coyote.den tell 0.0.0.0, length 46 16:42:20.926695 ARP, Request who-has amanda.coyote.den tell 0.0.0.0, length 46 16:42:20.926695 ARP, Request who-has amanda.coyote.den tell 0.0.0.0, length 46 16:42:20.926695 ARP, Request who-has amanda.coyote.den tell amanda.coyote.den, length 46 16:42:21.470873 ARP, Request who-has amanda.coyote.den tell amanda.coyote.den, length 46 16:42:23.288701 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:24.320147 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:25.344176 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:26.370963 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:27.392224 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:28.416249 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:29.445598 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:30.468289 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:31.488315 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:32.513828 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 16:42:33.536356 ARP, Request who-has router.coyote.den tell amanda.coyote.den, length 46 So the protocol is at least transmitting from amanda. This is evidence of dd-wrt ignoring the wrong timestamp because amanda's date is about 11 months out of sync. there is no settime installed so there's no way for be to manually fix that. I got this bit of info by commenting out the "pool" lines forcing chrony to use the "server 192.168.71.3 iburst" in the chrony subdir servers.d/ file. So I wrote another copy of the latest Armbian_26.2.1_Bananapim5_noble_current_6.18.15_xfce_desktop.img to another new 128G card, and fdisk then id's it as having an msdos partition table, skipping 8k and having a 6.4G ext4 as /dev/sdc1 and undefined for the remainder of the card. So I quit fdisk and ran gparted on /dev/sdc/ and selected data recovery. Which warned that it would take a long time, 6.5 hours later its still scanning. blue bar slowly marching back and forth in the progress line at the bottom of the gparted screen. Hopefully recovering enough data to write a valid ext4 partition table & see if /dev/sdc1 is mountable AND bootable. I have since found a cli reboot won't, but a powerdown will if the card was written with a bs=4096. That is where I am with backups of the whole houses still sitting in a /raid6 I can't rebuild w/o net access to install both gfs2 and mdadm from the repo's. So this is a trail report, not a success story. if this fails. I get a 6 pack of 32Giggers which I know WILL work with an msdos table. But that doesn't give the cards adequate room to do housekeeping meaning they will fail in less then a year. Once working I have not had a failure of a 64G card or a 128G card. 0 Quote
eselarm Posted yesterday at 06:27 AM Posted yesterday at 06:27 AM You mix up 2 things: - 'msdos filesystem' which usually means 'FAT' - 'msdos table' which usually means 'MBR partition table' Both can be up to 2 TeraBytes when sector or cluster size is 512 bytes. So no reason to change to GPT. Changing to GPT (with standard 128 entries), will use the same space as where the U-Boot bootloader is located on SD-card for older Arm chips, like Allwinner A20 (original bananapi). So risk is un-bootable. Back to your networking issues: I have not read all, but this BPI-M5 image is Ubuntu based and I see NetworkManager. So that means you also get netplan. I don't want that, so I only use Debian based images as a start. But it seems that if you use 'nmtui' text based tool that you still can quite easily set fixed IP addresses locally. At least that is the case for 'Raspberry Pi OS Trixie' where they also made a dependency between netplan and NetworkManager. Then since this year also Debian by default uses systemd-resolved for their pre-installed (cloud) images for DNS. This means it all won't work out of the box for you. Same was the case for me, I use also my own router and DNS server and that did not work with Armbian (half a year ago). I think now some extra is done, as tests with 26.2 images what Igor asked for, worked OK, but only did boot them via serial console. Look up the forum topic about it if you want to know, I already forgot. So to work with local hosts file on every computer, the whole Linux must prioritize hosts file over DNS resolver. That is determined in /etc/nsswitch.conf I have at least 2 ARM64 computers that need fixed IP (they must work without router) so I have a few entries in hosts file, very limited and dedicated, as rest is all in router. So what I do with new images when some tests or so, is (as root): systemctl disable --now systemd-resolved # this stops the DNS resolver and also makes sure it won't start after reboot rm /etc/resolv.conf # when systemd-resolved is used, this file is a symbolic link to tmpfs in RAM, so if not removed, your next settings are lost after reboot echo nameserver 192.168.71.1 > /etc/resolv.conf Then same as on older (bookworm) Raspberry Pi OS, install openresolv (it handles access to /etc/resolv.conf 😞 apt install openresolv I can not guarantee that it all works the same in Ubuntu when netplan is active, but up to you to figure that out yourself in your network environment. 0 Quote
gene1934 Posted yesterday at 10:07 AM Author Posted yesterday at 10:07 AM You mix up 2 things: - 'msdos filesystem' which usually means 'FAT' - 'msdos table' which usually means 'MBR partition table' agreed Both can be up to 2 TeraBytes when sector or cluster size is 512 bytes. So no reason to change to GPT. Changing to GPT (with standard 128 entries), will use the same space as where the U-Boot bootloader is located on SD-card for older Arm chips, like Allwinner A20 (original bananapi). So risk is un-bootable. which seems to be the case. but it sure as hell blocks mounting and working on the card b4 network is enabled. Why? the error reported is can't find ext4 filesystem. I'll rewrite it just to be sure its pristine. Because it did mount but only lost+found is there. 2 hours ago, eselarm said: systemctl disable --now systemd-resolved done to an untouched image, booted & still with the wrong hostname & no hosts file. rm /etc/resolv.conf done now that cost me about 100 yds of walking on legs slowly being eaten by sugar blisters. echo nameserver 192.168.71.1 > /etc/resolv.conf but i'm working on a different card than the one its booted to atm. so now i'm an going to nano the /etc/hostname to 'amanda' AND I have added a dhcp entry for amanda here on this machine according to the example format but this machine is #3, not #1 for the last digit of its ipv4 address so will it now reply to the ARP query? I guess i'll find out as I'm about to do a powerdown. reboot. after I start a tcpdump capture here on coyote. grepping for amanda, no output from amanda, rebooted twice. change resolv.conf to point at this machine, did not capture a request from amanda during bootup, ip a shows only the assigned mac in ip a output, nothing in ip r. So something isn't right yet. My fingers are at your coomand. next? 0 Quote
eselarm Posted 22 hours ago Posted 22 hours ago 3 hours ago, gene1934 said: ip a shows only the assigned mac in ip a output, nothing in ip r. So something isn't right yet. I assumed your router is 192.168.71.1 and is only doing DNS for internet, so not for your in-house computer. For in-house computers, I assumed want to use a fixed IP address assigned on the local computer and also put a hosts file per local computer so all other computers in your house are known via that. So then, on a new image in a running computer, use: sudo nmtui to assign a fixed IP address. You need to tab through the options. 0 Quote
gene1934 Posted 16 hours ago Author Posted 16 hours ago which of course fails as nmtui it will not accept the dot separators in an ipv4 address needed to be entered in an ipv4 only situation. I'll repeat as I have said quite a few times already, that I, in weston wv, am at least 100 miles from ANY ipv6 enabled net access. There surely are some ipv6 in pittsburg pa., 150 miles north, maybe in Charleston, 100 miles south. I have battled this using armbian-config and in using that microscopecly tiny moving radiation symbol at the top right of the xfce4 screen. If that is a defense to prevent ipv4 addresses where ipv6 is expected, change the box color so we know it can be skipped in real estate not yet blessed with ipv6 addresses. We are NOT mind readers any more than you are, but this particular group off us is about a 3/4 million in the whole state where flat ground to build a house on is measured in the gallons of diesel fuel to make it flat enough to build on. Fix nmtui so its actually usable and do a respin. while at it, fix whatever prevents our mounting it to edit such stuff before 1st boot. That restriction is a huge pain in the ass too. fdisk tells us its dos partition for sdc with an ext4 sdc1, but when we attempt to mount it, the ext4 cannot be found. That restriction is also present in the 25-5 release. Yet it boots & almost runs. next try? 0 Quote
eselarm Posted 4 hours ago Posted 4 hours ago 11 hours ago, gene1934 said: which of course fails as nmtui it will not accept the dot separators in an ipv4 address needed to be entered in an ipv4 only situation. My ISP offers no IPv6, so I usually set IPv6 configuration on disable or ignore. You still might see a link-local IPv6 address (starting with fe80), but that should not matter. I don't know why you can't simply type an IPv4 address in the various fields of nmtui. I have no issues with that. The risks is that you have various other random issues; If you try to do an fsck of /dev/sdc1 and it fails, that is a sign on the wall. It usually is something with SD-card, it might be counterfeit or your SD-card adapter has issues. 0 Quote
bedna Posted 1 hour ago Posted 1 hour ago (edited) It's most likely a local ipv6 op is talking about, not a public. ipv6 in range fe80::/10 is local only. To remove ipv6 in that regard, ipv6 has to be disabled on the device or it will get an address like that. And according to what is provided: 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether be:63:9c:35:dd:4f brd ff:ff:ff:ff:ff:ff inet 192.168.71.2/24 brd 192.168.71.255 scope global noprefixroute end0 valid_lft forever preferred_lft forever inet6 fe80::bc63:9cff:fe35:dd4f/64 scope link valid_lft forever preferred_lft forever Today I learned a bit more about systemd-resolved, seems 127.0.0.53 IS the correct config for systemd-resolved: https://unix.stackexchange.com/questions/612416/why-does-etc-resolv-conf-point-at-127-0-0-53 Quote In both cases, systemd-resolved configures a search list of domain name suffixes, again derived on the fly from its configuration files and DHCP leases (which it is told about via a mechanism that is beyond the scope of this answer) And: Quote It's likely that you have such a symbolic link. In which case, the thing that knows about the 192.168.1.1 setting, that is (presumably) handed out in DHCP leases by the DHCP server on your LAN, is systemd-resolved, which is forwarding query traffic to it as you have observed. Your DNS client libraries, in your applications programs, are themselves only talking to systemd-resolved. If dhcp server is configured correctly, nothing has to be done on the devices (except resolving domains to local ip unless that is done on the LAN by dnsmasq) Edited 1 hour ago by bedna 0 Quote
