Armbian on Allwinner H313 (In Xplus) – system boots but no Wi-Fi or Ethernet
Hey everyone!
I have a TV Box labeled “In Xplus”, running on an Allwinner H313 (most likely a generic/rebranded device).
I was able to install Linux on it using Armbian 26.2.0-trunk (Trixie). The system boots normally, but I’m facing network issues:
- Wi-Fi is not working (no interface detected)
- Ethernet is also not working (only interface is lo)
So basically, the system runs fine, but I have no network connectivity at all.
My questions:
- Is this a current limitation of Armbian support for the H313?
- Is there any specific DTB or patch that could fix Wi-Fi/Ethernet?
- Is there a more stable Armbian version or another distro with better support?
- Has anyone managed to get networking working on this chip?
Any help or shared experience would be greatly appreciated.
Thanks!
I think I may have found the Wi-Fi info from the board label.
It is an Allwinner H313 board, and the sticker says **1+8 (SV625 6P)**, so I believe the Wi-Fi chip/module is **SV6256P**.
I still can't read the marking directly on the IC itself, but the board label strongly suggests that this is the Wi-Fi chip being used.
1000205791.thumb.jpg.6d8c8241858adb3b50b9da6bdccbcd3c.jpg1000205796.thumb.jpg.9e940ffe4cf2259ee7270225a508ea67.jpg1000205798.thumb.jpg.0d149a7b2bc61123c2d5e59dffc152e7.jpg1000205797.thumb.jpg.7da7268e546c84cb2f3b71a7a79fb611.jpg1000205795.thumb.jpg.4d7e008a80554095327c5999d2c170ea.jpg1000205794.thumb.jpg.15d8eee6a19feed313b21bc5135bf117.jpg1000205792.thumb.jpg.9c62bce26cf770e8fc4b0a45cf01959d.jpg1000205793.thumb.jpg.14f8f68bcf91c264d421869b9036e39b.jpg
