When trying to rebuild the kernel, the image is not taking the updated kernel image:
 ./compile.sh BOARD=espressobin CLEAN_LEVEL=make-kernel RELEASE=trixie
-rwxrwxr-x   1 root  root  296665952 Apr  7 16:47 vmlinux.unstripped
-rw-rw-r--   1 root  root     220926 Apr  7 16:47 modules.builtin.modinfo
-rw-rw-r--   1 root  root      16667 Apr  7 16:47 modules.builtin
-rwxrwxr-x   1 root  root  296215160 Apr  7 16:47 vmlinux
drwxrwxr-x  23 root  root     12288 Apr  7 16:47 kernel/
drwxrwxr-x  79 root  root     12288 Apr  7 16:47 fs/
drwxrwxr-x   5 root  root     36864 Apr  7 16:47 crypto/
drwxrwxr-x  22 root  root     20480 Apr  7 16:47 lib/
drwxrwxr-x  27 root  root      4096 Apr  7 16:47 sound/
drwxrwxr-x  23 root  root     12288 Apr  7 16:47 scripts/
$ armbian-imager
# installed the new image...
16:55:21 ● custom_image: Check decompression for /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img: false
16:55:21 ● operations: Starting flash: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img -> /dev/sdb (verify: true)
16:55:21 ● flash::linux::writer: Starting flash: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img -> /dev/sdb
16:55:21 ● flash::linux::writer: Image size: 2252341248 bytes (2.10 GB)
16:55:21 ● flash::linux::writer: Unmounting device partitions...
16:55:21 ● flash::linux::writer: Writing image...
16:55:27 ● flash::linux::writer: Write complete: 2148.0 MB in 5.4s (avg 398.9 MB/s)
16:55:27 ● flash::linux::writer: Starting verification...
16:55:27 ● flash::verify: Starting verification of 2252341248 bytes (2.10 GB)
16:55:32 ● flash::verify: Verify complete: 2148.0 MB in 4.9s (avg 441.9 MB/s)
16:55:32 ● flash::linux::writer: Flash complete!
16:55:32 ● operations: Flash completed successfully
16:55:32 ● custom_image: Deleting decompressed custom image: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img
16:55:32 ● custom_image: Attempted to delete file outside custom-decompress cache: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img
$ sudo mount /dev/sdb1 /mnt/
$> ls -ltr /mnt/boot/vmlinux-6.18.21-edge-mvebu64
-rw-r--r-- 1 root root 36108800 Apr  3 18:36 /mnt/boot/vmlinux-6.18.21-edge-mvebu64
When booting:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.18.21-edge-mvebu64 (build@armbian) (aarch64-linux-gnu-gcc (Debian 14.2.0-19) 14.2.0, GNU ld (GNU Binutils for Debian) 2.44) #1 SMP PREEMPT Thu Apr  2 07:23:33 EDT 2026
[    0.000000] KASLR enabled
Even more confusing the file on the disk, written with armbian-imager is a text file, looks like an apt sources file:
> file /mnt/boot/vmlinux-6.18.21-edge-mvebu64
/mnt/boot/vmlinux-6.18.21-edge-mvebu64: ASCII text, with very long lines (1483)
> head /mnt/boot/vmlinux-6.18.21-edge-mvebu64
com/daniel-casanueva/haskell/graphviz
Description-md5: bd02d2c14f791ffca367313e1957b329
Ghc-Package: graphviz-2999.20.2.0-JKUYtUkvYwE3GbOspxTTfB
Section: haskell
Priority: optional
Filename: pool/main/h/haskell-graphviz/libghc-graphviz-dev_2999.20.2.0-1+b1_arm64.deb
MD5sum: 36c93a1f30f0234eadffbf9ae0d2336b
SHA256: 5b95053c25c02020e9eca717df070591259432e5c125435f5514761417bc8879
The built file looks fine:
  1348921 717100 -rw-rw-r--   1 root     root     734305912 Apr  7 17:45 ./cache/sources/linux-kernel-worktree/6.18__mvebu64__arm64/vmlinux.o
> file ./cache/sources/linux-kernel-worktree/6.18__mvebu64__arm64/vmlinux.o
./cache/sources/linux-kernel-worktree/6.18__mvebu64__arm64/vmlinux.o: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), with debug_info, not stripped
