Joe Posted December 15, 2017 Posted December 15, 2017 Hi all, I'm currently running Armbian 5.36 Ubuntu 16.04.3 LTS 4.11.1-sun50iw2. This was / is a local armbian build that I performed a few months ago to resolve an issue that I saw at that time in the network stack that prevented ipsec working correctly. I've performed apt update / apt upgrade since however cat /proc/version still reports the version as that which I manually built back in June. Fast forward to today and I'd like to try out some traffic shaping tc rules but I'm running into some difficulty, which is making me doubt if my kernel has the support needed for iproute2. The following works without any issue to list existing rules on eth0: root@nanopineo2:~# tc -s qdisc ls dev eth0 qdisc pfifo_fast 0: root refcnt 2 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1 Sent 1109245 bytes 4725 pkt (dropped 0, overlimits 0 requeues 26) backlog 0b 0p requeues 26 ..where pfifo_fast is the default qdisc (queuing discipline) for eth0 If I attempt to remove this rule I see an RTNETLINK error: root@nanopineo2:~# sudo tc qdisc del dev eth0 root RTNETLINK answers: No such file or directory If I attempt to add a new rule I see the same RTNETLINK error: root@nanopineo2:~# tc qdisc add dev eth0 root tbf rate 1000kbit latency 50ms burst 5000 RTNETLINK answers: No such file or directory iproute2 is installed: root@nanopineo2:~# apt list --installed | grep iproute2 WARNING: apt does not have a stable CLI interface. Use with caution in scripts. iproute2/xenial-updates,now 4.3.0-1ubuntu3.16.04.2 arm64 [installed] ..however I read here http://lartc.org/howto/lartc.iproute2.package.html that kernel netlink support is required for iproute2 to work properly and I'm not sure that I have it. I'm almost sure that sch_netem should be present for it to work but this is not installed and as far as I can tell by looking at kernel source that I can find in github, this is not included as part of the sunxi kernel: root@nanopineo2:~# modprobe sch_netem modprobe: FATAL: Module sch_netem not found in directory /lib/modules/4.11.1-sun50iw2 Does anyone have any idea what I need to do to get this working? Thanks for any help Joe
Joe Posted December 23, 2017 Author Posted December 23, 2017 I thought it would sensible to get things to a more standard position so I formatted an sd card and flashed the latest armbian ubuntu mainline as-is. I'm now running: Armbian 5.34.171121 nightly Ubuntu 16.04.3 LTS 4.13.14-sunxi64 and most of the problems that I mentioned above have gone away. I apologize for wasting anyone's time, please ignore this.
