I attempted to file a bug using `reportbug`, but since the kernel package is from Armbian and the report went to Debian, I assume that is a dead end.
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=1137721
I will mostly copy/paste from that report, here, but I also ran `armbianmonitor -u`.
https://paste.armbian.com/wenegucita
I run a home backup server with a 1TB SSD attached to an ODroid HC1 board. There is no redundancy, but I do keep a limited history of snapshots, taken hourly and trimmed down to a small number of hourly, daily, weekly, monthly, and yearly snapshots. There should be at most about 20 snapshots existing at a time. I have a daily cron job to run a balance operation. The mount point is `/backup` . Relevant line from /etc/fstab:
/dev/mapper/backup /backup btrfs noatime,noauto,nodev,nosuid,noexec,compress=zlib:9 0 0
Command used for daily balance:
btrfs balance start --full-balance '/backup'
The filesystem only seems to be about half full:
ansible@backup:~ $ sudo btrfs filesystem df --si /backup
Data, single: total=430.57GB, used=428.24GB
System, DUP: total=67.11MB, used=81.92kB
Metadata, DUP: total=3.22GB, used=2.48GB
GlobalReserve, single: total=536.87MB, used=49.15kB
ansible@backup:~ $
My best understanding is that the messages that follow indicate that something is attempting to address space beyond 16TB, and that seems like a bug because my disk is only 1TB total. I would appreciate anyone with a firmer grasp of the topic at least confirming whether that is an accurate reading of the warnings and errors. If not, I might suggest that the warnings and errors could be improved, but I am open to correction if I just failed to understand what they are telling me.
The problem seems to be triggered by any attempt to rebalance metadata or system data with a usage limit of 1 or higher. Excerpt from a command session:
ansible@backup:~ $ time sudo btrfs balance start -musage=1 /backup; echo $?
ERROR: error during balancing '/backup': Read-only file system
There may be more info in syslog - try dmesg | tail
real    0m0.304s
user    0m0.040s
sys     0m0.082s
1
ansible@backup:~ $ sudo umount /backup && sudo mount -o skip_balance /backup && sudo btrfs balance cancel /backup
ansible@backup:~ $ time sudo btrfs balance start -f -susage=1 /backup; echo $?
real    0m0.321s
user    0m0.023s
sys     0m0.096s
1
ansible@backup:~ $
Excerpt from dmesg from that time:
[114023.693265] BTRFS info (device dm-0): balance: start -musage=1 -susage=1
[114023.695656] BTRFS error (device dm-0): extent buffer 18905857064960 is beyond 32bit page cache limit
[114023.695669] BTRFS error (device dm-0): reached 32bit limit for logical addresses
[114023.695677] BTRFS error (device dm-0): due to page cache limit on 32bit systems, metadata beyond 16T can't be accessed
[114023.695686] BTRFS error (device dm-0): please consider upgrading to 64bit kernel/hardware
[114023.695699] ------------[ cut here ]------------
[114023.695706] WARNING: CPU: 4 PID: 30371 at fs/btrfs/space-info.h:208 btrfs_space_info_update_bytes_may_use+0x9c/0x1c0 [btrfs]
[114023.695813] Modules linked in: aes_arm_bs crypto_simd dm_crypt cpufreq_conservative cpufreq_userspace cpufreq_powersave sunrpc zram zsmalloc binfmt_misc evdev sg nfnetlink ip_tables x_tables ipv6 autofs4 btrfs blake2b_generic xor xor_neon raid6_pq li
bcrc32c sd_mod t10_pi crc64_rocksoft uas usb_storage scsi_mod scsi_common gpio_keys
[114023.695959] CPU: 4 PID: 30371 Comm: btrfs Tainted: G        W          6.6.122-current-odroidxu4 #1
[114023.695969] Hardware name: Samsung Exynos (Flattened Device Tree)
[114023.695980]  unwind_backtrace from show_stack+0x10/0x14
[114023.696000]  show_stack from dump_stack_lvl+0x40/0x4c
[114023.696014]  dump_stack_lvl from __warn+0x78/0x154
[114023.696025]  __warn from warn_slowpath_fmt+0x1b4/0x1bc
[114023.696035]  warn_slowpath_fmt from btrfs_space_info_update_bytes_may_use+0x9c/0x1c0 [btrfs]
[114023.696127]  btrfs_space_info_update_bytes_may_use [btrfs] from btrfs_block_rsv_release+0x1f4/0x2f4 [btrfs]
[114023.696300]  btrfs_block_rsv_release [btrfs] from btrfs_alloc_tree_block+0x118/0x6b4 [btrfs]
[114023.696465]  btrfs_alloc_tree_block [btrfs] from btrfs_force_cow_block+0x148/0xa60 [btrfs]
[114023.696628]  btrfs_force_cow_block [btrfs] from btrfs_cow_block+0xe4/0x2bc [btrfs]
[114023.696792]  btrfs_cow_block [btrfs] from btrfs_search_slot+0x6dc/0xc08 [btrfs]
[114023.696957]  btrfs_search_slot [btrfs] from btrfs_update_device+0xa4/0x248 [btrfs]
[114023.697122]  btrfs_update_device [btrfs] from btrfs_chunk_alloc_add_chunk_item+0xcc/0x638 [btrfs]
[114023.697287]  btrfs_chunk_alloc_add_chunk_item [btrfs] from reserve_chunk_space+0xec/0x180 [btrfs]
[114023.697451]  reserve_chunk_space [btrfs] from check_system_chunk+0x6c/0x74 [btrfs]
[114023.697615]  check_system_chunk [btrfs] from btrfs_inc_block_group_ro+0x228/0x234 [btrfs]
[114023.697780]  btrfs_inc_block_group_ro [btrfs] from btrfs_relocate_block_group+0x94/0x48c [btrfs]
[114023.697945]  btrfs_relocate_block_group [btrfs] from btrfs_relocate_chunk+0x3c/0x180 [btrfs]
[114023.698108]  btrfs_relocate_chunk [btrfs] from btrfs_balance+0x864/0x13b8 [btrfs]
[114023.698272]  btrfs_balance [btrfs] from btrfs_ioctl+0x248c/0x28c4 [btrfs]
[114023.698436]  btrfs_ioctl [btrfs] from sys_ioctl+0x288/0xc60
[114023.698533]  sys_ioctl from ret_fast_syscall+0x0/0x54
[114023.698547] Exception stack(0xf2575fa8 to 0xf2575ff0)
[114023.698556] 5fa0:                   00000000 00000003 00000003 c4009420 bebe7fd0 bebe7f70
[114023.698565] 5fc0: 00000000 00000003 bebe7fd0 00000036 005bfb78 bebe86f4 00000001 0058b190
[114023.698572] 5fe0: 00000036 bebe7f58 b6d718b1 b6cdf736
[114023.698580] ---[ end trace 0000000000000000 ]---
[114023.698802] BTRFS error (device dm-0): extent buffer 18905857064960 is beyond 32bit page cache limit
[114023.698821] ------------[ cut here ]------------
[114023.698827] WARNING: CPU: 4 PID: 30371 at fs/btrfs/block-group.c:2783 btrfs_create_pending_block_groups+0x674/0x67c [btrfs]
[114023.698925] BTRFS: Transaction aborted (error -75)
[114064.918054] Modules linked in: aes_arm_bs crypto_simd dm_crypt cpufreq_conservative cpufreq_userspace cpufreq_powersave sunrpc zram zsmalloc binfmt_misc evdev sg nfnetlink ip_tables x_tables ipv6 autofs4 btrfs blake2b_generic xor xor_neon raid6_pq libcrc32c sd_mod t10_pi crc64_rocksoft uas usb_storage scsi_mod scsi_common gpio_keys
[114064.918234] CPU: 5 PID: 30410 Comm: btrfs Tainted: G        W          6.6.122-current-odroidxu4 #1
[114064.918245] Hardware name: Samsung Exynos (Flattened Device Tree)
[114064.918256]  unwind_backtrace from show_stack+0x10/0x14
[114064.918272]  show_stack from dump_stack_lvl+0x40/0x4c
[114064.918284]  dump_stack_lvl from __warn+0x78/0x154
[114064.918296]  __warn from warn_slowpath_fmt+0x130/0x1bc
[114064.918307]  warn_slowpath_fmt from btrfs_create_pending_block_groups+0x674/0x67c [btrfs]
[114064.918399]  btrfs_create_pending_block_groups [btrfs] from __btrfs_end_transaction+0x38/0x2a0 [btrfs]
[114064.918567]  __btrfs_end_transaction [btrfs] from btrfs_inc_block_group_ro+0x1f0/0x234 [btrfs]
[114064.918733]  btrfs_inc_block_group_ro [btrfs] from btrfs_relocate_block_group+0x94/0x48c [btrfs]
[114064.918899]  btrfs_relocate_block_group [btrfs] from btrfs_relocate_chunk+0x3c/0x180 [btrfs]
[114064.919065]  btrfs_relocate_chunk [btrfs] from btrfs_balance+0x864/0x13b8 [btrfs]
[114064.919231]  btrfs_balance [btrfs] from btrfs_ioctl+0x248c/0x28c4 [btrfs]
[114064.919397]  btrfs_ioctl [btrfs] from sys_ioctl+0x288/0xc60
[114064.919491]  sys_ioctl from ret_fast_syscall+0x0/0x54
[114064.919505] Exception stack(0xf26b9fa8 to 0xf26b9ff0)
[114064.919516] 9fa0:                   00000000 00000003 00000003 c4009420 beae9fc0 beae9f60
[114064.919527] 9fc0: 00000000 00000003 beae9fc0 00000036 0057fb78 beaea6f1 00000001 0054b190
[114064.919537] 9fe0: 00000036 beae9f48 b6d118b1 b6c7f736
[114064.919614] ---[ end trace 0000000000000000 ]---
[114064.919632] BTRFS: error (device dm-0: state A) in btrfs_create_pending_block_groups:2783: errno=-75 unknown
[114064.919647] BTRFS info (device dm-0: state EA): forced readonly
[114064.920025] ------------[ cut here ]------------
[114064.920039] WARNING: CPU: 5 PID: 30410 at fs/btrfs/space-info.h:208 btrfs_space_info_update_bytes_may_use+0x9c/0x1c0 [btrfs]
[114064.920182] Modules linked in: aes_arm_bs crypto_simd dm_crypt cpufreq_conservative cpufreq_userspace cpufreq_powersave sunrpc zram zsmalloc binfmt_misc evdev sg nfnetlink ip_tables x_tables ipv6 autofs4 btrfs blake2b_generic xor xor_neon raid6_pq libcrc32c sd_mod t10_pi crc64_rocksoft uas usb_storage scsi_mod scsi_common gpio_keys
[114064.920385] CPU: 5 PID: 30410 Comm: btrfs Tainted: G        W          6.6.122-current-odroidxu4 #1
[114064.920398] Hardware name: Samsung Exynos (Flattened Device Tree)
[114064.920409]  unwind_backtrace from show_stack+0x10/0x14
[114064.920426]  show_stack from dump_stack_lvl+0x40/0x4c
[114064.920441]  dump_stack_lvl from __warn+0x78/0x154
[114064.920454]  __warn from warn_slowpath_fmt+0x1b4/0x1bc
[114064.920466]  warn_slowpath_fmt from btrfs_space_info_update_bytes_may_use+0x9c/0x1c0 [btrfs]
[114064.920559]  btrfs_space_info_update_bytes_may_use [btrfs] from btrfs_block_rsv_release+0x1f4/0x2f4 [btrfs]
[114064.920729]  btrfs_block_rsv_release [btrfs] from btrfs_trans_release_chunk_metadata+0x2c/0x40 [btrfs]
[114064.920900]  btrfs_trans_release_chunk_metadata [btrfs] from __btrfs_end_transaction+0x38/0x2a0 [btrfs]
[114064.921070]  __btrfs_end_transaction [btrfs] from btrfs_inc_block_group_ro+0x1f0/0x234 [btrfs]
[114064.921239]  btrfs_inc_block_group_ro [btrfs] from btrfs_relocate_block_group+0x94/0x48c [btrfs]
[114064.921406]  btrfs_relocate_block_group [btrfs] from btrfs_relocate_chunk+0x3c/0x180 [btrfs]
[114064.921572]  btrfs_relocate_chunk [btrfs] from btrfs_balance+0x864/0x13b8 [btrfs]
[114064.921741]  btrfs_balance [btrfs] from btrfs_ioctl+0x248c/0x28c4 [btrfs]
[114064.921913]  btrfs_ioctl [btrfs] from sys_ioctl+0x288/0xc60
[114064.922009]  sys_ioctl from ret_fast_syscall+0x0/0x54
[114064.922024] Exception stack(0xf26b9fa8 to 0xf26b9ff0)
[114064.922036] 9fa0:                   00000000 00000003 00000003 c4009420 beae9fc0 beae9f60
[114064.922046] 9fc0: 00000000 00000003 beae9fc0 00000036 0057fb78 beaea6f1 00000001 0054b190
[114064.922057] 9fe0: 00000036 beae9f48 b6d118b1 b6c7f736
[114064.922067] ---[ end trace 0000000000000000 ]---
[114064.922111] BTRFS info (device dm-0: state EA): balance: ended with status: -30
I tried balancing data, starting with low usage limits and moving up to no limit. That all went smoothly. The problem still occurred when trying to balance metadata, but the extent buffer number named in dmesg errors changed. I do not know whether that is significant or whether balancing data should be expected to be of any benefit in this situation. I did not keep full context from dmesg, but these are the commands issued:
btrfs balance start -dusage=1 /backup
btrfs balance start -dusage=10 /backup
btrfs balance start -dusage=50 /backup
btrfs balance start -dusage=75 /backup
btrfs balance start -dusage=85 /backup
btrfs balance start -dusage=95 /backup
btrfs balance start -d /backup
Most of those were pretty fast. The last one took several hours.
I also checked my SSD for SMART errors, running a short self test and then a long one. No errors are reported.
I do not know whether this is an architecture specific bug. It may be specific to 32 bit systems, or to ARM 32 bit, or it may not.
I do not know whether this is an upstream bug, but it seems likely. The behavior in question seems to be related to the btrfs kernel component.
The recommended fix is to attach the SSD to a 64 bit system to complete any operations requiring addresses that cannot be handled by the 32 bit system. I have not done that, yet, and I will hold off for a while, as it seems like that will only be a temporary fix.
If I can gather any more relevant information while the system is still in this state, please let me know.
-- System Information:
Debian Release: 13.4
  APT prefers stable-updates
  APT policy: (500, 'stable-updates'), (500, 'stable-security'), (500, 'stable')
Architecture: armhf (armv7l)
Kernel: Linux 6.6.122-current-odroidxu4 (SMP w/8 CPU threads; PREEMPT)
Kernel taint flags: TAINT_WARN
Locale: LANG=en_US.UTF-8, LC_CTYPE=en_US.UTF-8 (charmap=UTF-8) (ignored: LC_ALL set to en_US.UTF-8), LANGUAGE=en_US.UTF-8
Shell: /bin/sh linked to /usr/bin/dash
Init: systemd (via /run/systemd/system)
-- no debconf information
First of all, spamming balance on an SSD will significantly lower the lifespan of it.
What you do is ask btrfs to relocate data-chunks that are occupying the % of a block, so that 1 goes fast is because they are very small (1%), but when you ask it to scan and look for a position to move chunks that occupy +50% it WILL take a long time, a veeeeery long time, not to mention 95%. You are basically just moving around data slowly killing your SSD.
Read here: https://btrfs.readthedocs.io/en/latest/Balance.html#compact-under-used-chunks
Btrfs will do this automatically in the background constantly when your computer is having extra cycles to do so.
The only time it will be useful is if you remove massive amounts of data, then you can notice neither data nor metadata freeing up space.
It can also be useful if you are using RAID because then it can move data between the disks.
IIRC -susage is irrelevant for most users, what you want to move is the data and metadata, ie -musage & -dusage.
If ever run a balance, it's when I remove big, and I mean BIG chunks of data, like 25% of the drive, and when I do, I start with 5, increment by 5 up to 35, NEVER more. But it is ONLY if I actually need the space immediately for something else, otherwise I just wait and let btrfs handle it by itself.
So, with what you are doing with your cron running every day is literally killing your ssd... You should probably stop, IMMEDIATELY.
With a --full-balance, you rewrite ALL DATA on the ENTIRE DRIVE!
Better to have a scrub running once per month or every second week or so to know that your drive is in healthy condition...
So what you are experiencing is not a bug, it's how it works, and in worst case scenario it might be your ssd about to give up...
This link, albeit reddit describes it pretty good: https://www.reddit.com/r/btrfs/comments/hfpot9/what_does_balance_actually_balance
You might be tempted to schedule balances to run often ; but I caution against anything aggressive. A full balance re-writes all data. During a balance with spindles, performance is particularly bad. On SSDs, a regular full balance severely worsens their durability. If anything, the "usage" parameter could be useful to ensure you only clear out near-empty chunks. This ensures balances are short and do very little unnecessary work:
BTW, you can check what it is doing while running by typing: sudo watch -n1 'btrfs balance status /path'
But again, I HIGHLY discourage you do balance unless you ABSOLUTELY need to.
Edit
I missed that the filesystem has become read only when responding to this at 4am so lets edit this with a bit more info.
Well, I'm sorry, it looks like you killed your drive, or at least the filesystem.
The best you can do is try to copy all files on it to another drive (probably not worth trying to save the filesystem), format this one and pray that it's only your filesystem that became corrupt. But after reading how you treated that drive I think you should be prepared for it being damaged beyond a reformat, or that if you manage to format it, it will become corrupted pretty soon again, so I would not rely on that drive for backups...
I have found SMART to not be reliable when it comes to health.
If you like btrfs, I would recommend buying a rpi, a 6TB spinning drive, a hd case and run urbackup on that. That is what I use (rpi4 8gb, which is overkill, it never utilizes more than 2-3G memory on it, even though I use it as a backup server, nfs network drive AND is running a plex server on it) and it has been running flawlessly for years. (that reminds me, I might want to install something newer than rpi os bullseye on it, maybe armbian xD)
I only make file backups, no images.
Not very fast, but what does that matter when you only use it for backups. (I run the NFS network drive from another storage device, but that is beside the point)
If you also use btrfs on the system you backup from, it creates a snapshot at runtime that it transfers files from, so there is no risk of corrupting files while the backup is running due to files changing during the backup. :)
You would probably get all that for the same price as one ssd, or at least close to, spinning dives cost close to nothing.
I have 5 clients connected to that backup solution, with 4 backups daily saved for about 2,5 months (one backup every 5hrs and backups paused between 3am-7am), and one archived every month to save for three years. ie 240 incremental backups per device. One of the clients backing up 1.13T (the others are smaller, between 100-350G each) but all of it only taking up about 5.5TB, and backups runs fast af, only copying changed data due btrfs and de-duplication (COW). I have NEVER had to run a balance on that device (only done it once before for testing).
But since it is getting close to the threshold, let's make an experiment and run a balance on it with chunks up to 30%.
There are 987 snapshots on that device (not all 5 clients has reached 240 backups due to not being constantly turned on, my laptop and my installed "fallback" os for example)
$ sudo btrfs subvol list /media/backup | wc -l
987
This is before balancing:
$ sudo btrfs fi df --si /media/backup
Data, single: total=5.60TB, used=5.60TB
System, DUP: total=33.55MB, used=606.21kB
Metadata, DUP: total=31.14GB, used=27.71GB
GlobalReserve, single: total=536.87MB, used=0.00B
The balance up to 20% took about 5 seconds, then on 25 and 30 it took a while, about 10 minutes (I forgot to run it with time so this is an estimate with me looking at the clock when starting and when saw it had it ended)
It only moved a minimum amount of chunks
$ sudo bin/btrfs-balance.sh --backup
If balancing takes a long time, open another terminal and run:
btrfs balance will run on /media/backup
Do you want to continue? [y/n] y
Dumping filters: flags 0x6, state 0x0, force is off
  METADATA (flags 0x2): balancing, usage=5
  SYSTEM (flags 0x2): balancing, usage=5
Done, had to relocate 1 out of 5253 chunks
Dumping filters: flags 0x1, state 0x0, force is off
Done, had to relocate 0 out of 5253 chunks
  METADATA (flags 0x2): balancing, usage=10
  SYSTEM (flags 0x2): balancing, usage=10
  METADATA (flags 0x2): balancing, usage=15
  SYSTEM (flags 0x2): balancing, usage=15
  METADATA (flags 0x2): balancing, usage=20
  SYSTEM (flags 0x2): balancing, usage=20
  METADATA (flags 0x2): balancing, usage=25
  SYSTEM (flags 0x2): balancing, usage=25
  METADATA (flags 0x2): balancing, usage=30
  SYSTEM (flags 0x2): balancing, usage=30
Done, had to relocate 1 out of 5252 chunks
Done, had to relocate 0 out of 5252 chunks
This is after balancing:
As you can see, no change whatsoever because btrfs does this in the background all by itself. And running higher % would not save any space, only take a ton of time, I'm pretty sure of that.
If you want the script I used, here you go: (I have two btrfs filesystems on that rpi, modify to your liking if adopting)
!/usr/bin/env bash
# Check if script is run as root
if [ "$EUID" != 0 ]; then
  echo 'THIS SCRIPT MUST BE RUN AS ROOT! (WITH SUDO)'
  exit 1
fi
if [ "$1" == '--backup' ]; then
  METHOD='/media/backup'
elif [ "$1" == '--usr' ]; then
  METHOD='/media/usr'
else
  METHOD='all'
fi
echo 'If balancing takes a long time, open another terminal and run:'
echo -e "sudo watch -n1 'btrfs balance status /path'\n"
echo "btrfs balance will run on $METHOD"
read -p "Do you want to continue? [y/n] " -n 1 -r
if ! [[ "$REPLY" =~ ^[Yy]$ ]]; then
  echo ''
  echo 'Aborting...'
  exit 4
fi
echo ''
if [ "$METHOD" == '/media/usr' ] || [ "$METHOD" == 'all' ]; then
  btrfs balance start -v -musage=5 /media/usr
  btrfs balance start -v -dusage=5 /media/usr
  btrfs balance start -v -musage=10 /media/usr
  btrfs balance start -v -dusage=10 /media/usr
  btrfs balance start -v -musage=15 /media/usr
  btrfs balance start -v -dusage=15 /media/usr
  btrfs balance start -v -musage=20 /media/usr
  btrfs balance start -v -dusage=20 /media/usr
  btrfs balance start -v -musage=25 /media/usr
  btrfs balance start -v -dusage=25 /media/usr
  btrfs balance start -v -musage=30 /media/usr
  btrfs balance start -v -dusage=30 /media/usr
  btrfs balance start -v -musage=35 /media/usr
  btrfs balance start -v -dusage=35 /media/usr
fi
if [ "$METHOD" == '/media/backup' ] || [ "$METHOD" == 'all' ]; then
  btrfs balance start -v -musage=5 /media/backup
  btrfs balance start -v -dusage=5 /media/backup
  btrfs balance start -v -musage=10 /media/backup
  btrfs balance start -v -dusage=10 /media/backup
  btrfs balance start -v -musage=15 /media/backup
  btrfs balance start -v -dusage=15 /media/backup
  btrfs balance start -v -musage=20 /media/backup
  btrfs balance start -v -dusage=20 /media/backup
  btrfs balance start -v -musage=25 /media/backup
  btrfs balance start -v -dusage=25 /media/backup
  btrfs balance start -v -musage=30 /media/backup
  btrfs balance start -v -dusage=30 /media/backup
fi
exit 0
This probably means I should manually remove some snapshots, because I did make a few massive changes that caused a lot of new data to be created, I do NOT want it to become filled.
Conclusion:
Don't run btrfs balance unless absolutely necessary, especially on SSD:s!
Edited by bedna
