saman Posted January 9, 2018 Posted January 9, 2018 (edited) Hello community, i'm trying to build the image according the instructions _armbian/build_ but my build system is behind a firewall limited to http(80) and https(443). The build scripts are trying to fetch directly from git through different network ports. How can i change the way for cloning the git repositories to https? The same problem appears also for the key server, is there also a way to adapt them to https? There is a workaround by setting in file config-default.conf the options USE_MAINLINE_GOOGLE_MIRROR="yes" USE_GITHUB_UBOOT_MIRROR="yes" They only using implicit https protocol for git. The questions above are still in interest. Thanks ! daniel Edited January 9, 2018 by saman adding workaround
