Is it possible to boot from harddisk (ssd) without the need of the sd-card.
I am using an A20-OLinuXino-MICRO from OLIMEX. After flashing sd wih image and
setting up boot from sata or usb by the use of armbian-config sd card is still needed.
Would the A20 recognize u-boot (bootloader) on diffrent device than sd-card?
Even though a20 has an internal SATA controller, a20's Boot ROM code cannot boot its payload from there. you need NOR/NAND/eMMC/SD where you put the platform FW. The latter could boot OS loader/OS from anywhere. If it is capable enough. :)
THX for your detailed reply @valant.
