Wednesday at 11:51 AM3 days I install the image from this page: https://armbian.com/boards/aml-s9xx-box.Choose the version:Debian 13 trixie Minimal (CLI) — current 6.18.60 361 MBroot@aml-s9xx-box:~# uname -a Linux aml-s9xx-box 6.18.60-current-meson64 #1 SMP PREEMPT Fri Oct 30 12:06:41 UTC 2026 aarch64 GNU/LinuxI have successfully run with SDCard, but cannot install it to eMMC.root@aml-s9xx-box:~# ./install-aml.sh Start script create MBR and filesystem /dev/mmcblk1 Start backup u-boot default 4+0 records in 4+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 1.29 s, 3.3 MB/s Start create MBR and partittion Start restore u-boot 442+0 records in 442+0 records out 442 bytes copied, 0.0070075 s, 63.1 kB/s 8191+0 records in 8191+0 records out 4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.499351 s, 8.4 MB/s Done Start copy system for eMMC. Formatting BOOT partition...mkfs.fat 4.2 (2021-01-31) done. Copying BOOT...done. Edit init config...done. sed: can't read /ddbr/install/boot.ini: No such file or directory done. Formatting ROOT partition... /dev/mmcblk1p2 contains a ext4 file system labelled 'ROOT_EMMC' last mounted on /ddbr/install on Wed Nov 4 20:50:00 2026 e2fsck 1.47.2 (1-Jan-2025) ROOT_EMMC: clean, 12/385024 files, 46947/1539328 blocks done. Copying ROOTFS. Copy BIN Create DEV Copy ETC Copy HOME Copy LIB Copy LIB64 tar: lib64: Cannot stat: No such file or directory tar: Exiting with failure status due to previous errors Create MEDIA Create MNT Copy OPT Create PROC Copy ROOT Create RUN Copy SBIN Copy SELINUX Copy SRV Create SYS Create TMP Copy USR Copy VAR Copy fstab rm: cannot remove '/ddbr/install/usr/bin/ddbr': No such file or directory ******************************************* Complete copy OS to eMMC *******************************************Even though it says Complete, but it cannot boot from eMMC, stuck in a loop. I notice it said "sed: can't read /ddbr/install/boot.ini: No such file or directory", which in this system, there is no boot.ini.root@aml-s9xx-box:~# ls / bin boot ddbr dev etc home lib lost+found media mnt opt proc root run sbin selinux srv sys tmp usr var root@aml-s9xx-box:~# ls -la /ddbr total 12 drwxrwxrwx 3 root root 4096 Nov 4 22:35 . drwxr-xr-x 20 root root 4096 Nov 4 20:46 .. drwxr-xr-x 2 root root 4096 Nov 4 22:35 install root@aml-s9xx-box:~# ls -la /ddbr/install total 8 drwxr-xr-x 2 root root 4096 Nov 4 22:35 . drwxrwxrwx 3 root root 4096 Nov 4 22:35 .. root@aml-s9xx-box:~# uname -a Linux aml-s9xx-box 6.18.60-current-meson64 #1 SMP PREEMPT Fri Oct 30 12:06:41 UTC 2026 aarch64 GNU/LinuxI look up and see some suggest using armbian-install, but this image don't have that.I tried to copy the armbian-install raw file from ophub github, but it failed at the checking for ophub release file step.So how can I install it to eMMC?Thank you for your help. Edited Wednesday at 03:36 PM2 days by tyrys
