Tuesday at 08:28 AM5 days https://github.com/defcom5-rockchip/pi-desktop/releases/tag/v6.5.0Plaid Pi Plus 6.5: the Orange Pi 5 Plus as a desktop computer. KDE Plasma 6.6 on Mesa's open Panthor GPU driver, Ubuntu 26.04packages, Armbian's Rockchip vendor kernel merged with upstream stable Linux 6.1.191 (tag pi-desktop-6.5). One image forthe Orange Pi 5 Plus; the Orange Pi 5B and 5 stay on 6.0(GNOME) until their 6.5 image has been through the same tests. Checked on an Orange Pi 5 Plus on 2026-11-17: 150 of 150first-boot checks on the board (151 of 151 after Pro Updates, the first-click apps and a reboot), and 115 of 115 checks of the image file.Since 6.0:An Orange Pi 5 Plus image. 4K at 120 Hz on its HDMI 2.1 output (kernel patch 0020 gives the 5 Plus the display clocktree the 5B got in 4.0), hardware video in mpv and the browsers, Wi-Fi and Bluetooth audio on an Intel AX210 card.Tested on one board; what was not tested (eMMC, the Broadcom Wi-Fi module) is inKNOWN-ISSUES HW-2.KDE Plasma 6.6.6 on the open GPU driver (Mesa Panthor), with the Plaid look, Dolphin's Network Drive and disc menus,and the apps as first-click installs like the GNOME image.DVDs and Blu-rays copied to folders play from the desktop. Right-click the folder in Dolphin ▸ Play DVD or Blu-ray,or double-click its VIDEO_TS.IFO: mpv opens the folder in place (0.42 adds ISO images and the disc menus), starts thelongest title and switches its deinterlacer on. In a headless probe from the build PC, 53 of the 55 DVD folders on themaintainer's NAS opened as discs (the two that did not are incomplete copies); Streets of Fire was watched on the 5 Plus.A disc in a USB drive plays with its menu. Cinemosk's Play the disc in the drive starts a DVD in the disc's ownmenu (mpv 0.42). Bought DVDs need libdvdcss, which Plaid Pi cannot include: Cinemosk offers to build it on the computer.On the 5 Plus it took 1 min 50 s from Cinemosk's Disc support and 51 s from the first-time offer (one run each; itincludes downloads, so it varies), and a bought DVD then played from the drive with its menu. Blu-ray discs gothrough the same button, and Disc support adds Java 21 for Blu-ray menus written in Java; no Blu-ray disc was tested.Bought Blu-rays stay encrypted.One Wi-Fi interface per card. Rockchip's kernel gave every Wi-Fi card whose driver uses mac80211 a second, unusableinterface; on the 5 Plus with an Intel AX210 the name of the working one changed between boots and a saved networkstopped reconnecting. Kernel patch 0028 removes it, and the fix is sent to Armbian (linux-rockchip #621).Cinemosk, a picture-settings window for films: Smooth, Balanced or Sharp enlargement with the GPU cost of each measuredon the board shown next to the choice; banding clean-up, screen fill and even 24 fps motion for DVDs; per-folder overrides(Alt+C in mpv) and a meter (Alt+M). Films start on Balanced: at 4K on the 5 Plus it is sharper than Smooth for the sameGPU load (21 %); Sharp costs 28 %.mpv 0.42, libplacebo 7.387, libdvdread 7.1.1, GStreamer 1.28.9, rebuilt from Ubuntu's and Debian's packaging (the Malizero-copy patches, DVD-Audio, the native PipeWire output; GStreamer's FLAC seek and decodebin3 fixes and two securityfollow-ups Ubuntu 26.04 lacks). The frame-pacing findings from the 5 Plus tests are in the defaults (ao=pipewire,alsaand the KDE profile in /etc/mpv/mpv.conf).Kernel 6.1.191 with the stable fixes since 6.1.189, the ext4 NULL dereference its mballoc backport introduced fixed ontop (patch 0027; the same fix is queued upstream for 6.1.193), an upstream Bluetooth MGMT use-after-free fix with its twofollow-ups, and the vendor-driver adaptations the merge needed (the Broadcom Wi-Fi one is sent to Armbian aslinux-rockchip #620).The edition's name everywhere, including KDE's About this System and the system partition (plaid_root, wasArmbian's armbi_root), and the console login banner kept after updates.Panel icons for VSCodium and Audacity: both apps renamed their menu entries (VSCodium 1.143, XtraDeb's Audacity 4),so the panel's icons pointed at nothing; they use the new names now. On 6.0 the dock still uses the old names (nottried on a 6.0 board): if the VSCodium or Audacity icon disappears or does nothing, after installing VSCodium or afteran update brings XtraDeb's Audacity 4, add the app to the dock again from the app grid.Two fixes from the test images: Armbian's November firmware package ships the AP6275P driver's configuration-filelink as a 17-byte text file (the recipe restores the link; checked in the image, not on the air, as the test board has noAP6275P), and Armbian's base-files re-created the login-screen wordmark links on an update (now diverted;DSK-2 has the one-time fix for 6.0).This is kernel held so no easy update path FYIAnd we script the Firefox Install to use hardware which they are waiting to fix with Nvidia bug. Edited Tuesday at 08:29 AM5 days by defcom5-rockchip format
